>>We use mostly non-stock configurators and with this the average >>costing was recommendedOne more thing.. this may or may not apply in your case but...
We have very deep BOM's, with lots of materials (manufactured and purchased).
When we tried the combination of non-stock with average costing, we ran into issues. We ended up changing a LOT of parts to stock to reduce these.
One that I remember....
The costed BOM and the mtl estimates on the PDR don't match.
I learned they use different calculatins. The costed BOM rolls all the costs at runtime, but the PDR pulls the average part costs from the part cost table. The problem.... average cost is only updated when a part moves to stock so... nonstock cost estimates are no good on the PDR.
--- In vantage@yahoogroups.com, "brad_boes" <bboes@...> wrote:
> At Metalworks, we are on 9.05.603 and we are all Average costing.
> Our prior MRP system was standard costing.
> We use mostly non-stock configurators and with this the average costing was recommended. We did have some manufactured component type parts with standard cost yet, but found that the way the cost roll-up was working we needed to switch them to average also.
> Prior to implementing we had financial consulting from Epicor run through with our Mgt group the pros and cons of each method.
> I like the average costing for our quick turn around, make to order business model. I can see it is probably not for everyone though.
> I would run some tests if you can to understand how a negative inventory and out of sequence process steps (like the job backflushing the part before it is received) affects the average.
> Overall it fits our business needs.
> Brad Boes
> Metalworks
> --- In vantage@yahoogroups.com, Travis Late <tlate@> wrote:
> > Thank you all for your comments. Very helpful!
> > Travis Late
> > Divisional IT Manager
> > +1 619 216 2217 Office
> > +1 920 960 0062 Mobile
> > tlate@
> > Doncasters GCE Industries, Inc.
> > 1891 Nivana Avenue, Chula Vista, CA 91911
> > From: "cooner_55421" <cooner_55421@>
> > Date: 07/27/2011 03:32 PM
> > Subject: [Vantage] Re: Switch from Standard Cost to Actual
> > Sent by: vantage@yahoogroups.com
> > We were Std in Dataflo & went to Actual when we converted to Vantage.
> > > When I made the switch in a pass life, we had to come up with
> > > customizations that would prevent these types of transactions.
> > Same here.
> > If we couldn't cover it with a BPM then...
> > We also built reports to run daily and address cost issues as soon as
> > possible.
> > I'd pilot more if I had to do it over.
> > We talked about the differences before the change, but I think it can be a
> > little too abstract until you start making transactions.
> > --- In vantage@yahoogroups.com, Joe Rojas <jrojas@> wrote:
> > > It can be a finance nightmare too.
> > > Standard cost allows a lot of process errors to go unnoticed or at least
> > > with little impact.
> > > For example, zero dollar po receipts, where zero dollars is incorrect,
> > > can cause havoc on your inventory value.
> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > > Of Travis Late
> > > Sent: Wednesday, July 27, 2011 12:21 PM
> > > Subject: [Vantage] Switch from Standard Cost to Actual
> > > Has anyone out there ever made the switch from Standard to Actual? What
> > > are the ramifications of making this move? We are on Epicor 9.05.604A.
> > > Any help is appreciated.
> > > Travis Late
> > > tlate@ <mailto:tlate%40doncasters.com>
> > > This e-mail is sent on behalf of Doncasters. Its contents are
> > > confidential to the recipient and may be legally privileged.
> > > If you are not the intended recipient:
> > > (1) You must not disclose, copy or distribute its contents to any other
> > > person nor use its contents in any way;
> > > (2) Please contact Doncasters IT on +44 (0) 1332 694143 quoting the name
> > > and sender and the addressee then delete it from your system.
> > > For general enquiries please contact +44 (0) 1332 864900
> > > Doncasters has scanned this e-mail for viruses but does not accept any
> > > responsibility for viruses once this e-mail has been transmitted. You
> > > should scan attachments (if any) for viruses.
> > > Doncasters Limited, registered in England no. 321992 at Millennium
> > > Court, First Avenue, Burton-upon-Trent, Staffordshire, DE14 2WH, UK
> > > Joe Rojas | Director of Information Technology | Mats Inc
> > > dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
> > > jrojas@ | www.matsinc.com Ask us about our clean, green and beautiful
> > matting and flooring
> > > This message is intended only for the individual named. If you are not
> > the named addressee you should not disseminate, distribute or copy this
> > e-mail. Please notify the sender immediately by e-mail if you have
> > received this e-mail by mistake. Please note that any views or opinions
> > presented in this email are solely those of the author and do not
> > necessarily represent those of the company.
> > This e-mail is sent on behalf of Doncasters. Its contents are confidential to the recipient and may be legally privileged.
> > (1) You must not disclose, copy or distribute its contents to any other person nor use its contents in any way;
> > (2) Please contact Doncasters IT on +44 (0) 1332 694143 quoting the name and sender and the addressee then delete it from your system.
> > Doncasters has scanned this e-mail for viruses but does not accept any responsibility for viruses once this e-mail has been transmitted. You should scan attachments (if any) for viruses.
> > Doncasters Limited, registered in England no. 321992 at Millennium Court, First Avenue, Burton-upon-Trent, Staffordshire, DE14 2WH, UK
