Task Agent
Dear experts, while generating SSRS report below mentioned error is coming
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: System.Web.Services.Protocols.SoapException: The permissions granted to user ‘IIS APPPOOL\EpicorTest’ are insufficient for performing this operation. —> Microsoft.ReportingServices.Diagnostics.Utilities.AccessDeniedException: The permissions granted to user ‘IIS APPPOOL\EpicorTest’ are insufficient for performing this operation.
Does that user have read permissions on the reports database?
That account needs permissions be set in the reports folder in SSRS (along with subfolders)
Deploy the Application Server Setting using Admin Console. Now it is working fine. Thanks for your support.
I think I discovered today that when you deploy with the Application Server Settings, but use a different Domain Account than what you end up using for IIS App Pools after the fact, the deployment scripts do that setting of SSRS folder permissions for you. So you have to go back and manually fix them if you set app pools to run as a different user.
