We use Zebra S4 printers, I think you can get them for around 750. We
have both thermal transfer and direct thermal printing applications in
use. They have been in use for about 18 months with no issues. They
can be hooked up with USB or ethernet and print up to 4" wide. I am
quite happy with them so far.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
http://www.dsmfg.com/>
(Click the logo to view our site) <
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of Gerry Loranger
Sent: Wednesday, October 07, 2009 12:52 PM
To:
Subject: RE: [Vantage] Thermal Printer for non conformance tags
If you're looking at printing a 4" label, the Intermec PB50 is great for
mobile printing. You can check out a demo on youtube.
Bear in mind that mobile printers use direct thermal as opposed to
thermal
transfer. Thermal transfer printing uses a heated ribbon to produce
durable,
long-lasting images on a wide variety of materials. No ribbon is used in
direct thermal printing, which creates the image directly on the printed
material. Direct thermal media is more sensitive to light, heat and
abrasion, which reduces the life of the printed material.
The PB50 cost about 1000 USD and the batteries are around $100 each, a
separate battery charger would cost about $350.
I use mobile printers for internal bar code labels. I use the 2 x 4"
adhesive label to allow enough area to clearly read and scan the
information
on them. 2 x 4" labels cost $90 a roll which has 338 labels. I would not
use
direct thermal for shipping labels as they fade too quickly.
Gerry
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
[mailto:
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf Of
Charlie Wilson
Sent: Wednesday, October 07, 2009 1:02 PM
To:
That is what I'm towards is something network attached, much easier to
manage this way. IMO
I'm just not up to speed on the world of the thermal printers. From just
looking around I think something with a 4 inch print width would be more
than enough. What's in my head is basically a Point of sale receipt
printer
that I can network attach. I just was looking for suggestion on what you
all
are using.
USB / Parallel seem to be fairly common / cheaper but network attached
seems
to be fairly new to thermal printer world and not very common.
~Charlie
_____
[mailto:
Behalf Of
Cliff Drumeller
Sent: Wednesday, October 07, 2009 12:57 PM
To:
Charlie
I have two buildings running on thin clients. My finding is either a
printer with a parallel port of a network printer to have no problems.
USB printers are sometimes found, sometimes multiplied -- just
problematic over RDP.
Cliff
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Charlie Wilson
Sent: Wednesday, October 07, 2009 9:30 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: [Vantage] Thermal Printer for non conformance tags
We are looking to set a couple small thermal printers out on our
production
floor so that when production staff enter a non conformance via MES that
they can print a small tag for It immediately instead of hand writing a
tag
and attaching it to the rejected parts. I have found some from a company
called Datamax-O'niel that can connect to our network via Ethernet or
wireless. This is appealing because our MES units are HP thin clients
and
they don't seem to play well with USB printers that I have plugged into
them. I was wondering if any one was doing something similar and what
kind
of printer were you using. The pricing on these ones I have found is a
bit
steep for us.
~Charlie
