Tracking Info/Question
Here’s a link to how to use tokens to build up a path. This one specifically is going to the internet to get QR codes, but the premise is the same to go look for image files. If you can make the BAQ to look at your resource groups, then you can build up the file location using the tokens, or alternately you can make the location in a calculated field in the BAQ. Lots of options.
