Below is my Data Directive BPM in test mode and the error. Firing from changing a UD14 record just for testing.
I will eventually be firing this from a dashboard. I am trying to change the MtlBurUnitCost for inbound freight because I want to use the actual inbound freight amount after the part is received instead of the percent option in the part or using landed cost.
Please help!
Richard
DateTime dt = DateTime.Parse("2026/08/11");
this.CallService<Erp.Contracts.PartTranSvcContract>(pt =>
var pts = pt.GetByID(dt, 45390, 540691);
var rows = pts.PartTran
.ToList();
**foreach** (var ptr **in** rows)
ptr.MtlBurUnitCost = 123.45M;
ptr.RowMod = "U";
this.PublishInfoMessage(ptr.PartNum, Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, "", "");
pt.Update(**ref** pts);
## System Information
Business Layer Exception
Asm is required.
Type is required.
Pack ID is required.
Order is required.
Line is required.
Rel is required.
Rev is required.
Invoice is required.
Dimension is required.
Fiscal Period is required.
Journal is required.
DMR Number is required.
Action Number is required.
RMA is required.
Call is required.
Line is required.
Line is required.
Customer is required.
RMA Line is required.
Rcv is required.
Pack Line references invalid value.
PO references invalid value.
## Error Detail
##!Correlation ID:##! a2d71001-af22-45d6-909d-0aeaf9e56590
##!Message No.:##! 1
##!Description:##! Asm is required.
##!Program:##! Epicor.Ice.dll
##!Method:##! ValidateColumn
##!Line Number:##! 256
##!Column Number:##! 17
##!Table:##! PartTran
##!Field:##! AssemblySeq
##!Message No.:##! 2
##!Description:##! Type is required.
##!Field:##! JobSeqType
##!Message No.:##! 3
##!Description:##! Pack ID is required.
##!Field:##! PackNum
##!Message No.:##! 4
##!Description:##! Order is required.
##!Field:##! OrderNum
##!Message No.:##! 5
##!Description:##! Line is required.
##!Field:##! OrderLine
##!Message No.:##! 6
##!Description:##! Rel is required.
##!Field:##! OrderRelNum
##!Message No.:##! 7
##!Description:##! Rev is required.
##!Field:##! RevisionNum
##!Message No.:##! 8
##!Description:##! Invoice is required.
##!Field:##! InvoiceNum
##!Message No.:##! 9
##!Description:##! Dimension is required.
##!Field:##! DimCode
##!Message No.:##! 10
##!Description:##! Fiscal Period is required.
##!Field:##! FiscalPeriod
##!Message No.:##! 11
##!Description:##! Journal is required.
##!Field:##! JournalNum
##!Message No.:##! 12
##!Description:##! DMR Number is required.
##!Field:##! DMRNum
##!Message No.:##! 13
##!Description:##! Action Number is required.
##!Field:##! ActionNum
##!Message No.:##! 14
##!Description:##! RMA is required.
##!Field:##! RMANum
##!Message No.:##! 15
##!Field:##! JournalCode
##!Message No.:##! 16
##!Description:##! Call is required.
##!Field:##! CallNum
##!Message No.:##! 17
##!Field:##! CallLine
##!Message No.:##! 18
##!Field:##! MatNum
##!Message No.:##! 19
##!Description:##! Customer is required.
##!Field:##! CustNum
##!Message No.:##! 20
##!Description:##! RMA Line is required.
##!Field:##! RMALine
##!Message No.:##! 21
##!Description:##! Rcv is required.
##!Field:##! RMADisp
##!Message No.:##! 22
##!Description:##! Pack Line references invalid value.
##!Method:##! ValidateReferentialIntegrity
##!Line Number:##! 600
##!Column Number:##! 21
##!Field:##! PackLine
##!Message No.:##! 23
##!Description:##! PO references invalid value.
##!Field:##! PONum
## Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase.CallWithCommunicationFailureRetry(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, RestRpcValueSerializer serializer)
at Epicor.ServiceModel.Channels.ImplBase.CallWithMultistepBpmHandling(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
at Epicor.ServiceModel.Channels.ImplBase.Call(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
at Ice.Proxy.BO.UD14Impl.Update(UD14DataSet ds)
at Ice.Adapters.UD14Adapter.OnUpdate()
at Ice.Lib.Framework.EpiBaseAdapter.Update()
at Ice.UI.App.UD14Entry.Transaction.AdapterUpdate()
at Ice.UI.Shared.UDSupport.UDSingleViewTransaction.Update()
