Trying to use a BAQ search-show to fill data fields
Hi Charles, I’m trying to perform something similar with JobHead/JobOper instead of Customer/ShipTo. If I create by quick search on JobHead.JobNum, but set the BAQ return to be JobOper.SysRowID the search window won’t close after clicking OK because the “GetList?whereClause=JobNum in (‘c0edb4e0-2c68-466d-a74a-592e61466a93’)…” obviously doesn’t return any results. Did you need to change anything else on the search-show parameters to get the ShipTo.SysRowID returned and available? Override?
If I could get the JobOper SysRowID back I could then do something similar as you did and call a BAQ or function to obtain the necessary values I need.
Hi Chris, havnt read the whole thread but you may be able to override the default you’re experiencing by setting SysRow id in the search-show validation prop like so:
