uBAQ - What is RowMod = "P"?
I’ve used RowMod of A, U, and even D but never heard of P. This code is a modified copy of the auto generated base code of the UDTable method. It works but what is rowMod P? I’ve used A / D / and U even but never seen a P
I know, usually don’t go with auto-code is recommended but what i was trying wasn’t working.
using (var svc = Ice.Assemblies.ServiceRenderer.GetService<Ice.Contracts.UD32SvcContract>())
    var ttResultQuery = ttResults
        .Where(row => !string.IsNullOrEmpty(row.RowMod) && row.RowMod != "P");
    foreach (var ttResult in ttResultQuery)
        var ds = new Ice.Tablesets.UpdExtUD32Tableset();
        bool errorOccurred;
        // Query to object mapping
            var UD32 = new Ice.Tablesets.UD32Row
                Company = Session.CompanyID,
                Key1 = ttResult.InvcHead_InvoiceNum.ToString(),
                Key2 = "ARStatus",
                Key3 = "",
                Key4 = "",
                Key5 = "",
                ShortChar01 = ttResult.UD32_ShortChar01,
            ds.UD32.Add(UD32);
        BOUpdErrorTableset boUpdateErrors = svc.UpdateExt(ref ds, true, true, out errorOccurred);
        if (this.BpmDataFormIsPublished()) return;
        ttResult.RowMod = "P";
        // Object to query mapping
            var UD32 = ds.UD32.FirstOrDefault(
                tableRow => tableRow.Company ==  Session.CompanyID
                    && tableRow.Key1 == ttResult.InvcHead_InvoiceNum.ToString()
                    && tableRow.Key2 == "ARStatus"
                    && tableRow.Key3 == ""
                    && tableRow.Key4 == ""
                    && tableRow.Key5 == "");
            if (UD32 == null)
                UD32 = ds.UD32.LastOrDefault();
            if (UD32 != null)
                ttResult.UD32_Company = UD32.Company;
                ttResult.UD32_Key1 = UD32.Key1;
                ttResult.UD32_Key2 = UD32.Key2;
                ttResult.UD32_Key3 = UD32.Key3;
                ttResult.UD32_Key4 = UD32.Key4;
                ttResult.UD32_Key5 = UD32.Key5;
                ttResult.UD32_ShortChar01 = UD32.ShortChar01;
        if (errorOccurred && boUpdateErrors?.BOUpdError != null)
            ttErrors
                .AddRange(
                    boUpdateErrors.BOUpdError
                        .Select(
                            e => new ErrorsUbaqRow
                                TableName = e.TableName,
                                ErrorRowIdent = ttResult.RowIdent,
                                ErrorText = e.ErrorText,
                                ErrorType = e.ErrorType
var ttResultsForDelete = ttResults
    .Where(row => row.RowMod != "P")
    .ToArray();
foreach (var ttResult in ttResultsForDelete)
    ttResults.Remove(ttResult);
foreach (var ttResult in ttResults)
    ttResult.RowMod = "";
Possibly “Unchanged” since “U” was reserved for “Updated”?
That’s my 2 cents.
Quite possible.
Essentially saying “Give me all rows that exist and have a changed value, whether it’s Add, Update, or Deleted”.
Processed?
That’s a trick. UBAQ code use this special RowMod to mark a row as processed and not infer with standard RowMods.
Thanks Dmitry,
I don’t usually do custom code for uBAQs but this one the stock wasn’t working and the code I had tried from non uBAQ BPMs wasn’t quite working.
