Thanks Joshua and Jose for your responses. Jose example will work perfect for the new entry and I may also use the EXT UD for a different application.
Thanks again
Steve
Sent: Wednesday, March 18, 2015 8:32 AM
Subject: RE: [Vantage] UD table entry from BPM
Womp Womp… bummer… then yeah use a UD table but not any in the 100/100A range that would be a waste. Just use something UD01 and use the wizard to attach it as a child table in customization entry.
Joshua Giese
CIO
Direct: 920.593.8299
IT Dept: 920.437.6400 Ext. 337
Site ID: 27450-E905702A-SQL64
Wisconsin Converting, Inc.
Sent: Wednesday, March 18, 2015 8:30 AM
We do not have the CRM module
Sent: Wednesday, March 18, 2015 8:27 AM
Why not use CRM and link the invoice? You could add a UD field to CRM with a follow-up date and that is what your BAQ would run on.
Joshua Giese
CIO
Sent: Wednesday, March 18, 2015 8:24 AM
I am trying to put together a system so when the invoice due date is reached accounting can contact customer and document the conversation. They can then set a new date for that invoice for the next follow up if the invoice is not paid.
My thoughts are to use the UD100 so I get a child entry for each of the Invoice customer conversations and then create a BAQ for accounting to use the would show what Invoice are past due date or new date that is created in the UD table entry.
Steve
Sent: Wednesday, March 18, 2015 8:11 AM
What are you trying to store and how will it be used? So far what you have described you could use an EXT UD table to do that. By their very nature it’s a one to one with the parent table.
Joshua Giese
CIO
Sent: Wednesday, March 18, 2015 8:08 AM
Subject: [Vantage] UD table entry from BPM
Does anyone have an example of a New UD table entry from BPM running in another table.
I am trying to create a new UD table entry when and every time a new invoice is created.
Steve
