UD Table - Numeric field won't allow negative number
I have a UD table and I'm trying to import some records using
Paste/Insert on the List tab. Everything works fine until I try to
import a negative number into the Number02 field.
I get an error that says: The value -454.75 for column: Number02 is
not valid. The import has been canceled.
In customization the properties for Number02 are:
Mask Input -nnnn,nnn,nnn.nnnnn
MaxValue 1.79769313486232E+308
MinValue -1.79769313486232E+308
NumericType Double
If I add the record manually Vantage will allow me to enter a negative
value.
Anyone have any idea why I can't paste/insert a negative value?
Regards,
Linda Lowney
Pride Signs
255 Pinebush Road
Cambridge, ON N1T 1B9
P 519 622 4040 ext. 258
F 519 622 4031
www.pridesigns.com <http://www.pridesigns.com>
