I have never seen this happen before. Anyone else ever see this?
I created a BAQ, filtered on a custom field, and tested the BAQ. All worked fine. I then went and tried to create a dashboard with the BAQ and every time I tested the dashboard, Epicor hung and crashed. After the second time I went back into the BAQ and the UD table had appeared! Never seen this before and am not sure if I should re-do the BAQ, delete the UD table, or something else. Thanks.
That happens sometimes is a bug, usually requires to delete and re-create. It happens sometimes on Tuesdays when the sky is pink so I haven’t been able to report it / set it as a problem.
I have reported it, but until someone can figure out how to consistently make it happen, it will probably not get fixed. I can never get it to do this “on demand”… but if you ever go in and find one of those odd blue boxes to the _UD table, it simply needs deleted. I believe you will also find that the connection to that _UD is blank, causing an odd "everything to everything’ connection.
