I am trying to make the Standard-SSRS report style on my AR Invoice Form invalid, since I want everyone to use the custom form. I am able to unclick it in the UI and save
Clicking refresh, the report style is valid again.
I’ve had to set the default report style via direct SQL since there is an bug in the system for that, but is this also a bug where I cannot disable a report style?
Yeah I had to do that with the SQL to make set the default style. It doesn’t work quite as nicely with setting valid/invalid since it uses a delimited list of companies. We aren’t a multi-company setup, which he was saying to create a dummy company and then set it that way.
Oh, I always will let Epicor update the database however they want and all-day-long. They’re taking the responsibility for the results and know better than I do about the effects for these kinds of maneuvers.
The “Hidden” style still shows in Report Style Maint, and can make other changes to it. Including re-enabling it by simply marking the Valid field and saving.
Edit:
Not sure if it is related, but after using the uBAQ, the Default flag was clear on all styles for the ReportID that was updated.
We only have one company, so I was trying to make it invalid for “all” my companies. Can yo make that report not valid for both companies - at the same time?
I thought it might have been a bug that happened when you had only a single company. But in 10.2.300, I can save styles with the valid box unchecked while having just one company setup.
