Update Table From VB Code Solved
Thanks for all your help.
The solution was:
edv.dataView(edv.Row).BeginEdit()
edv.dataView(edv.Row)("Character01") = "Test"
edv.dataView(edv.Row).EndEdit()
My final code browses for a file path on a button click and saves it in Character01. Then a second button will open the file with the default application.
Private Sub epiButtonC1_Click(ByVal sender As Object, ByVal args As System.EventArgs)
' ** Place Event Handling Code Here **
Dim edv As EpiDataView = CType(oTrans.EpiDataViews("UD02"), EpiDataView)
'Check to see if the file in Character01 exsists and if it does open it with the default viewer
If My.Computer.FileSystem.FileExists(edv.dataView(edv.Row)("Character01")) Then
Process.Start(edv.dataView(edv.Row)("Character01"))
Else
MsgBox("File not found.")
End If
End Sub
Private Sub epiButtonC2_Click(ByVal sender As Object, ByVal args As System.EventArgs)
Dim fd As OpenFileDialog = New OpenFileDialog()
Dim strFileName As String
'Open a dialog box to browes to a file
fd.Title = "Open File Dialog"
fd.InitialDirectory = "C:\"
fd.Filter = "All files (*.*)|*.*|All files (*.*)|*.*"
fd.FilterIndex = 2
fd.RestoreDirectory = True
If fd.ShowDialog() = DialogResult.OK Then
'If we found a file store it in Character01
edv.dataView(edv.Row)("Character01") = fd.FileName
edv.Notify(New EpiNotifyArgs(oTrans, edv.Row, edv.Column))
End If
End Sub
--- In vantage@yahoogroups.com, "Kevin Simon" <simstrak@...> wrote:
> That's a great idea by bw. The other thing you may want to try is:
> edv.dataView(edv.Row)("RowMod") = "U"
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> bw2868bond
> Sent: Thursday, October 06, 2011 7:26 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Update Table From VB Code
> Did you try putting the row into edit mode before assigning a value?
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "carson251" <carsonepicor@> wrote:
> > Kevin,
> > I confirmed the code was hit with a pop up and I am in UD02 Maint. I tried
> the same code in Part maint hitting the part table and it worked. I'll try
> contacting support to see if it's a bug in 9.04.507A.
> > Thanks fr your help.
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Kevin
> Simon" <simstrak@> wrote:
> > > And, I assume this is a UD02 maint program you're in?
> > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of
> > > carson251
> > > Sent: Wednesday, October 05, 2011 3:36 PM
> > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > Thanks for the quick answer.
> > > I tried:
> > > System.EventArgs)
> > > 'edv.Notify(New EpiNotifyArgs(oTrans, edv.Row, edv.Column))
> > > otrans.update()
> > > End Sub
> > > And
> > > System.EventArgs)
> > > otrans.update()
> > > End Sub
> > > With no luck.
> > > Any other thoughts?
> > > Thanks
> > > > Try: otrans.update()
> > > > In place of the notify, or after the notify.
> > > Behalf Of
> > > > carson251
> > > > Sent: Wednesday, October 05, 2011 2:35 PM
> > > > Subject: [Vantage] Update Table From VB Code
> > > > Hi,
> > > > I'm trying to update a UD table with VB code on a button press. I can
> get
> > > > the screen to change, but saving doesn't do anything.
> > > > Here is the code.
> > > > System.EventArgs)
> EpiDataView)
> > > > End Sub
> > > > I feel like I'm missing something really simple, but I've been
> searching
> > > for
> > > > hours with no luck.
> > > > Any help would be appreciated.
> > > > Thanks
> > > > Carson
> > > > [Non-text portions of this message have been removed]
Hi,
I'm trying to update a UD table with VB code on a button press. I can get the screen to change, but saving doesn't do anything.
Here is the code.
End Sub
I feel like I'm missing something really simple, but I've been searching for hours with no luck.
Carson
carson251
Hi,
Here is the code.
System.EventArgs)
End Sub
hours with no luck.
Carson
I tried:
otrans.update()
End Sub
And
otrans.update()
End Sub
With no luck.
Any other thoughts?
> carson251
> Hi,
> Here is the code.
> System.EventArgs)
> End Sub
> hours with no luck.
> Thanks
> Carson
Are you sure this is getting executed? Try putting in a
MessageBox.Show("Got here") to ensure the codes getting executed.
carson251
I tried:
System.EventArgs)
otrans.update()
End Sub
And
System.EventArgs)
otrans.update()
End Sub
With no luck.
Any other thoughts?
Behalf Of
> carson251
> Hi,
> Here is the code.
> System.EventArgs)
> End Sub
for
> hours with no luck.
> Thanks
> Carson
carson251
I tried:
System.EventArgs)
otrans.update()
End Sub
And
System.EventArgs)
otrans.update()
End Sub
With no luck.
Any other thoughts?
Behalf Of
> carson251
> Hi,
> Here is the code.
> System.EventArgs)
> End Sub
for
> hours with no luck.
> Thanks
> Carson
Kevin,
I confirmed the code was hit with a pop up and I am in UD02 Maint. I tried the same code in Part maint hitting the part table and it worked. I'll try contacting support to see if it's a bug in 9.04.507A.
> carson251
> I tried:
> System.EventArgs)
> otrans.update()
> End Sub
> And
> System.EventArgs)
> otrans.update()
> End Sub
> With no luck.
> Any other thoughts?
> Thanks
> Behalf Of
> > carson251
> > Hi,
> > Here is the code.
> > System.EventArgs)
> > End Sub
> for
> > hours with no luck.
> > Thanks
> > Carson
--- In vantage@yahoogroups.com, "carson251" <carsonepicor@...> wrote:
> Kevin,
> > carson251
> > I tried:
> > System.EventArgs)
> > otrans.update()
> > End Sub
> > And
> > System.EventArgs)
> > otrans.update()
> > End Sub
> > With no luck.
> > Any other thoughts?
> > Thanks
> > Behalf Of
> > > carson251
> > > Hi,
> > > Here is the code.
> > > System.EventArgs)
> > > End Sub
> > for
> > > hours with no luck.
> > > Thanks
> > > Carson
bw2868bond
> Kevin,
Behalf Of
> > carson251
> > I tried:
> > System.EventArgs)
> > otrans.update()
> > End Sub
> > And
> > System.EventArgs)
> > otrans.update()
> > End Sub
> > With no luck.
> > Any other thoughts?
> > Thanks
> > Behalf Of
> > > carson251
> > > Hi,
get
> > > Here is the code.
> > > System.EventArgs)
EpiDataView)
> > > End Sub
searching
> > for
> > > hours with no luck.
> > > Thanks
> > > Carson
