Prior to upgrade, copy your existing BPMExec folder to your test server's same location.
Although, I recommend that everyone do that step automatically as part of an upgrade in the first place.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of melissa hietala
Sent: Monday, November 05, 2012 6:29 PM
Subject: Re: [Vantage] Re: Upgrade to 9.05.700C issue
That was it. I had to recompile everything even though they didn't show outdated. I had no vision they were not updated correctly. Any way to see that in the future without testing to see if we get error messages?
Thanks to all for your help!
Melissa Hietala
UMC, Inc.
melissah@...
Sent: Monday, November 5, 2012 8:58 AM
Subject: RE: [Vantage] Re: Upgrade to 9.05.700C issue
Try re-compiling all your BPMs: System Management -> BPM -> Operations -> Directive Update -> Directive Recompile Setup -> “both outdated and up-to-date directives†-> Start.
Brian.
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of melissa hietala
Sent: Monday, November 05, 2012 9:48 AM
To: mailto:vantage%40yahoogroups.com
I called epicor this morning and it looks like there is something wrong with server\bpmexec\bo files. I did verbose logging for them and that seems to be a common theme. They are looking at the logs now. But I will mention the customization scripting in the mfgsys folder you mentioned before because mine do say 905.607.1 still.
Big picture all of my customizations seem to launch fine at the moment. I had a couple personalizations I needed to revalidate but nothing big.
Melissa Hietala
UMC, Inc.
mailto:melissah%40ultramc.com <mailto:melissah%40ultramc.com>
From: Greg Payne <mailto:gpayne%40compulink-usa.com <mailto:gpayne%40compulink-usa.com> >
To: "mailto:vantage%40yahoogroups.com <mailto:vantage%40yahoogroups.com> " <mailto:vantage%40yahoogroups.com <mailto:vantage%40yahoogroups.com> >
Sent: Monday, November 5, 2012 8:00 AM
Epicor.Mfg.BO.Labor.dll is in my patch directory with 9.5.700.2 version and the original releaseclient.zip with 9.5.700.14.
Can you do MES from the server? if you can and the releaseclient has all of the files from the server, then you can force an upgrade by changing the version on either the client or server default.mfgsys.
I would do on client first to get an new set of files on that client. Once MES is good on one client, then change on the server side to force for all stations. This is a tip from John Driggers that I used a lot to get my 700C working.
Good Luck.
Greg Payne
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of jgiese1988
Sent: Monday, November 05, 2012 8:26 AM
Subject: [Vantage] Re: Upgrade to 9.05.700C issue
i feel your pain 607 to 700 gave me the same trouble. I eventually gave up and went to every machine and did a reinstall (after ensuring the //app/Epicor905/Client/config files were exactly the same as the ones in my clientrelease.zip file) You will likely also have to pull the files out of the /custom/patch folders in the server folder and add them to the clientrelease.zip. We had an issue with that the patch files were never included in the client release at 700.
Melissa Hietala
UMC, Inc.
melissah@...
Brian.
Melissa Hietala
UMC, Inc.
Good Luck.
Greg Payne
--- In mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>, melissa hietala <kevmel822@...<mailto:kevmel822@...>> wrote:
> it did show 905.607.1 still in that folder. I updated it and launched the system and it still gave me same errors.
> Melissa Hietala
> UMC, Inc.
> melissah@...
> From: Greg Payne <gpayne@...<mailto:gpayne@...>>
> To:
> "mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>"
> <mailto:vantage%40yahoogroups.com<mailto:vantage%40yahoogroups.com>>
> Sent: Sunday, November 4, 2012 3:16 PM
> Subject: RE: [Vantage] Upgrade to 9.05.700C issue
> Â
> There is an issue with the update and releaseclient.zip not getting updated. I made releaseclient.zip from client folder on server and deployed that.
> Verify that the default.mfgsys file has the line below. support had me
> add the .3
> <customizations>
> <customization name="Patch" directoryName="Patch" version="9.05.700.3"
> deploymentType="XCOPY" /> </customizations>
> You can use the clientzipinstaller program in the clientzipinstall directory to be sure your mfgsys files are in the zip file.
> You can always just force copy the client folder to the workstations.
> Good Luck.
> Greg
> Sent: Saturday, November 03, 2012 12:05 AM
> Subject: [Vantage] Upgrade to 9.05.700C issue
> Ugraded to 700C tonigt and E9 opens and runs fine on server, but when we run the client side and it goes through the autoupdate I get an error:
> Version mismatch between client (9.05.700) and server (9.05.700C)
> What did we miss?
> Thanks
> Melissa Hietala
> UMC, Inc.
> mailto:melissah%40ultramc.com<mailto:melissah%40ultramc.com<mailto:mel
> issah%40ultramc.com%3cmailto:melissah%40ultramc.com>>
> CONFIDENTIALITY NOTICE
> The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
> "This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior approval form the U.S. Department of State."
