Using API to Successfully Start Activity Then Errors
I am able to successfully start an activity on multiple jobs from a web app I have created, but only once. If I try a second time to select a couple more jobs I get the following back from /api/v2/odata/t300/Erp.BO.LaborSvc/SelectForWork
  1. ErrorMessage: “Employee ID must be unique.”
  2. ErrorType: “Ice.BLException”
  3. HttpStatus: 400
  4. ReasonPhrase: “REST API Exception”
I can refresh the page which causes me to log in again and those same job numbers I just tried a second time will now work when I select them and start activity.
Any ideas, thoughts, questions, or concerns?
Need to bring up the dev tools and look at what you are sending when it errors out.
I needed to clear the LaborDtl array after Update is called otherwise I was just appending new LaborDtl object to one that had already been created.
So all good now?
Appears so, thanks for the tip
