Mr. Calvin: That report is a pure ODBC report. You will have to
setup your ODBC driver and then change the datasource location in
Crystal (to match your ODBC DSN name) and then inside crystal change
the company ID to match your Company ID.
You can then add the ODBC report to your menu system.
Later,
Dave Olender dolender@...
Ph:651-246-3281
Later,
Ph:651-246-3281
--- In vantage@yahoogroups.com, "Calvin Krusen" <ckrusen@...> wrote:
> I too am looking for a way to change the quote worksheet. Since it
> cant' be done, I'll give Rich's Crystal Report a try.
> I've only been using CR for a about a week now, so forgive the
> newbie nature of my questions.
> How are Rich's reports implemented? Are they added as report
styles
> to the existing Quote Form report group, using the QuotForm data
> definition?
> Or do you have to create new data defeinitions and a new report
> group? If so, how do you link the new report to the Print Quote
> Worksheet dialog box?
> Thanks,
> Calvin
> --- In vantage@yahoogroups.com, "Todd Hofert" <todd@> wrote:
> > Rich,
> > This is perfect. Thank You.
> > Now what to do this weekend?
> > Todd
> > ________________________________
> > From: vantage@yahoogroups.com on behalf of ermc_v
> > Sent: Fri 4/13/2007 10:44 AM
> > Subject: [Vantage] Re: V8x Custom Crystal based Quote Worksheet
> > I just posted a zip file (ERMC_QuoteRpt) containing 2 quote
> reports.
> > One is a summary report which rolls up all operations and
> summarizes
> > the hours for each operation as a single line total per OP CODE.
> The
> > other is a detail worksheet that eliminates the gobblygook of the
> > progress report and replaces it with our own. Material
information
> > is included in both. Contact me offline if you have other
> questions.
> > Hope you can get it to work. You will at least need to change the
> > company ID. Good luck
> > Rich J
> > ERMC
> <snip>
> > > Our estimators do not like the Standard Quote Worksheet form
> that
> > comes
> > > with Vantage 8. The report is a non-editable Progress report
and
> > does
> > > not include any information regarding production hours at the
> > operation
> > > level. If it were a Crystal based report, this info would be
> > fairly easy
> > > to incorporate, since it is not, I am wondering if anyone has
> > created a
> > > Quote Worksheet that includes estimated production hours per
> > operation?
> > > If so, do you mind sharing it?
> > > Thank You
> > > Todd Hofert
> <snip>
