Vantage 8.03.407 Customer.Number01 field linked to UD02
Hi Rob,
I added the dashboard to the Warranty sheet and I can see the dashboard
name beside the Add Dashboard button. I save the customization and exit
Vantage. When I go back into customization the space beside Add
Dashboard is blank. Do you have any idea why it would disappear?
Linda
Of Rob Bucek
Sent: Thursday, January 07, 2010 9:23 AM
Subject: RE: [Vantage] Vantage 8.03.407 Customer.Number01 field linked
to UD02
You could put in an embedded dashboard...build a simple BAQ, customer
table, UD table, link via shortchar10 and custID, put it in a dashboard
and then drop it on your new sheet, and link it to your combo box...
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Behalf
Of Linda Lowney
Sent: Thursday, January 07, 2010 7:17 AM
to UD02
Hi Rob,
Thanks Rob. The Customer.ShortChar10 field is equal to the UD02.key1
field.
Linda
Behalf
Of Rob Bucek
Sent: Wednesday, January 06, 2010 5:25 PM
to UD02
In order to pull in data you need to have some sort of logical link
between customer and warranty info in your UD table. What column in
your UD table associates to a particular customer, or in your instance
is it not a customer relationship thing?
Rob Bucek
FAX: (715)284-4084
Behalf
Of Linda Lowney
Sent: Wednesday, January 06, 2010 2:30 PM
Subject: [Vantage] Vantage 8.03.407 Customer.Number01 field linked to
UD02
Hi Group,
I am using the UD02 table to store warranty information. I need to
display this information on the customer setup screen, but I can't
figure out how to do this. The UD02 table does not have a customer
number.
I have added a new tab to the customer entry screen called warranty. I
added a combo box (ShortChar10) that uses the UD02 adapter to select the
warranty. This is working fine, but I need to pull in all the warranty
information from the UD02 table and display it on the customer warranty
screen.
I've tried using FKV, but I've never had much luck with FKVs as they
don't make much sense to me.
How can I use the Customer.ShortChar10 field to pull in the information
in the UD02 table?
Regards,
Linda Lowney
Pride Signs
255 Pinebush Road
Cambridge, ON N1T 1B9
P 519 622 4040 ext. 258
F 519 622 4031
www.pridesigns.com <http://www.pridesigns.com>
Hi Group,
number.
screen.
in the UD02 table?
Regards,
Linda Lowney
Pride Signs
255 Pinebush Road
F 519 622 4031
Rob Bucek
FAX: (715)284-4084
Of Linda Lowney
UD02
Hi Group,
number.
screen.
in the UD02 table?
Regards,
Linda Lowney
Pride Signs
255 Pinebush Road
F 519 622 4031
Hi Rob,
field.
Linda
Of Rob Bucek
to UD02
Rob Bucek
FAX: (715)284-4084
Behalf
Of Linda Lowney
UD02
Hi Group,
number.
screen.
in the UD02 table?
Regards,
Linda Lowney
Pride Signs
255 Pinebush Road
F 519 622 4031
Rob Bucek
FAX: (715)284-4084
Of Linda Lowney
to UD02
Hi Rob,
field.
Linda
Behalf
Of Rob Bucek
to UD02
Rob Bucek
FAX: (715)284-4084
Behalf
Of Linda Lowney
UD02
Hi Group,
number.
screen.
in the UD02 table?
Regards,
Linda Lowney
Pride Signs
255 Pinebush Road
F 519 622 4031
Thanks Rob.
I tried adding a dashboard once before and could not get it to work, but
I'll give it a try again.
Linda
Of Rob Bucek
to UD02
Rob Bucek
FAX: (715)284-4084
Behalf
Of Linda Lowney
to UD02
Hi Rob,
field.
Linda
Behalf
Of Rob Bucek
to UD02
Rob Bucek
FAX: (715)284-4084
Behalf
Of Linda Lowney
UD02
Hi Group,
number.
screen.
in the UD02 table?
Regards,
Linda Lowney
Pride Signs
255 Pinebush Road
F 519 622 4031
