We have 50+ Vista64 workstations, all with Vantage installed. We have
run 5.0 - 6.1 on 64 bit machines with no issues. These older versions do
require some tweaks to get Vantage installed. Once installed all is
good. I believe 8.x installs with no issues. You can check the
Yahoogroups archives for more info there has been many threads about MS
Vista and Vantage.
If you are using ODBC that may take a special install. For the older
versions of Vantage we had to use the 32bit ODBC Data Source
administrator located in: C:\Windows\SysWow64\odbcad32.exe. This is not
the same one in "Administrative Tools".
Hth,
Jim
Of randyduly
Sent: Wednesday, November 19, 2008 8:46 PM
Subject: [Vantage] Vantage 8.03 client and Vista 64-bit OS
We are currently running Vantage 8.03.405a on Progress Database on a
Windows 2003 Server. I don't have any experience or much knowledge
about Vista 64-bit OS. We are wanting to put a CAD Workstation with
Vista 64-bit on our network. Will the Vantage 8.03 32-bit client work
on Vista 64-bit OS?
Has anybody done this yet? Anything to watch out for on Vista 64-bit OS?
Thanks!
Vista and Vantage.
Hth,
Jim
Of randyduly
on Vista 64-bit OS?
Thanks!
