Nigel,
In addition to the previous poster's observations, it also appears that you
have no BI buffers allocated and are not using spin lock retries. Also, how
may asynchronous page writers do you have configured? It is entirely
possible that the BI log is simply being overrun with write requests and is
unbuffered placing the entire burden upon your I/O subsystem which, as
others have correctly pointed out, is a highly non-optimal configuration for
write intensive applications. Set you BI Buffers to a minimum of 25 and
start from there. Additionally, make sure your spin lock retries is set to
approximately 20000 per processor or you will be effectively limiting the
database to the resources of a single CPU.
Good Luck,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
<http://www.aspacia.com/> http://www.aspacia.com/
This email, and any attachments thereto, is intended only for use by the
addressee(s) named herein and may contain legally privileged and/or
confidential information. If you are not the intended recipient of this
email, you are hereby notified that any dissemination, distribution or
copying of this email, and any attachments thereto, is strictly prohibited.
If you have received this email in error, please immediately notify me by
telephone and permanently delete the original and any copy of any email and
any printout thereof.
Nigel Kerley
Sent: Friday, July 20, 2007 1:15 PM
Subject: [Vantage] Re: Vantage 8.03 Speed Issue
Hi Stephen,
Answers below.
Nigel.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Stephen
Edginton" <stephene@...>
wrote:
behind Europe so the overlap is no more than 2 hours.
Receipt: 15secs (112 lines)
on a seperate mirror array.
"-Mm 4096 -mmax 65534 -Bt 5000 -s 200 -yy 1970 -stsh 31 -inp 32000 -
tok 4000 -TB 31 -TM 32 -D 500 -l 13000
-T d:\epicor\mfgwrk803
-db f:\epicor\mfgsys803\db\mfgsys
-cpinternal utf-8 -cpstream utf-8 -cprcodein utf-8"
Blocks in DB buffer = 20,000.
It has been configured to only use 1 processor and 1GB of RAM.
Approx 4 secs per line - pasting in.
from there.
Entering SO (90 lines): 10 mins
Didn't try a Goods Received - too painful!
Good Luck,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
Nigel Kerley
Hi Stephen,
Answers below.
Nigel.
wrote:
>We're on 305H.
> Hi Nigel,
> What patch are you running?
>Approx 30 users in Europe, 15 in USA. The USA office is 8 hours
> Number of users?
>entry,
> What is the speed to retrieve these entries i.e pull up in order
> po entry?To pull up SO: 15secs (133 lines), PO: 23secs (112 lines), PO
>I suspect we didn't create large enough docs during testing.
> Did you experience the same speed during piloting of these larger
> orders?
>Application, OpenEdge and OS are on a Raid5 array. The DB itself is
> What is your disk configuration?
>.pf file:
> Can you post your .pf file and how much of the DB are you buffering?
>SQL is running on the same server, but not for any intensive tasks.
> Are you running other services on the server?
>Approx 5 secs per line - entering manually.
> What is the average speed to add a line initially?
>No, not really. Becomes noticeable after c.15 lines and gets worse
> Is there a point where adding new lines becomes slower?
from there.
>are
> Also try the same operations running the client on the server, what
> the figures then?Entering PO (112 lines): 22mins
>[Non-text portions of this message have been removed]
> Regards,
> Stephen Edginton
