> You get 2 checks. If the 1st check info includes a credit memo , thusNot a Vantage solution but maybe an enhancement request for Epicor...
> creating a negative check, that check net negative does not roll over to
> the 2nd check.
> If anyone has found a way to add all the invoices together to get one
> check, we would all be grateful to you if you were willing to share your
> solution.
In an ERP system from a galaxy not too far away, the first check (or however
many checks) that were filled with just invoice information would get voided
and the final check number would be recorded for payment against all invoices.
This way all credit memos are netted against all invoices for that run.
A cheesy way to do it in Vantage would be to do a separate check run and
choose enough Invoices to offset the credit memo. That may not always be
possible but it's worth a looksy.
Mark W.
