Vantage Patches for version 5.00
Steve, I believe that when you load a patch it has all of the other patch fixes already in it. So, you don't need to load all of the concurrent patches. When I have loaded patches in the past it has only taken about 10-20 minutes even when it's a major patch jump. But, we only have a 250 mb database.
My philosophy is: "If it's not broken, don't fix it." So, I only apply patches if we absolutely need it. Right now we're still on .317. I suppose if the error that you received is significant enough to warrant updating to the latest patch, then I would. But, if we received a minor error every once in a while, I wouldn't update ours. That's just my opinion.
~Wendy
----- Original Message -----
Sent: Monday, June 04, 2001 2:43 PM
Subject: [Vantage] Vantage Patches for version 5.00
We have been running pretty well lately without any problems on patch
5.00.310. We did just get an error the other day, that I was told by
support has been corrected in the most recent patch. I just have a
couple of questions for the group regarding the patches:
1. I know that the current patch is .322, if I choose to patch the
system, do I need to load all of the preceding patches, and if so,
about how long do they take? I currently have about a 1.5GB database.
2. What are your feelings about the recent patches? Is it worth it
for me to apply them, or has there been more trouble then anything
else after updating. Like I stated above, our system has been
running pretty smoothly and I really do not want to rock the boat.
Thanks in advance for your replies.
Steve
Yahoo! Groups Sponsor
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
Steve
We're running the .322 patch as of last night. No problems with the patch thus far, and it fixed some MRP errors we were having.
I believe you can install this patch over the .310 patch that you have. The patch.wri file will tell you for sure. The longest time may be for the schema changes that have to be run the first time you log in. This may take a lot of time for you since you are jumping from .310 to .322. I didn't have any schema changes when going from .320 to .322.
Troy Funte
Liberty Electronics
Steve
Hi Guys,
I was wondering how long are the Patches taking to run, I have about 2
hours in the morning when its quiet. My data base size is about 200meg.
Shirley Graver
(End User)
Sys Admin
Rubber associates Inc.
Cleveland/Akron
Sent: Monday, June 04, 2001 2:57 PM
Subject: Re: [Vantage] Vantage Patches for version 5.00
Troy Funte
Liberty Electronics
Steve
Don't let someone get your domain name!
www. .com
Going from .320 to .322 took less than 10 minutes. And there were no schema changes. If you are reaching further back from an older patch, it could take longer once you login for the first time.
Troy Funte
Liberty Electronics
Sent: Monday, June 04, 2001 3:17 PM
Subject: RE: [Vantage] Vantage Patches for version 5.00
Hi Guys,
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
Troy Funte
Liberty Electronics
Steve
www. .com
I went from 317 to 322 with a 622,000+ MB Database. I didn't time the
schema change, because I thought it would go fast. It must have taken
around 1.5 hours.
Nancy Dunn
Winco Ind. Inc.
Sent: Monday, June 04, 2001 2:18 PM
Hi Guys,
Shirley Graver
(End User)
Sys Admin
Cleveland/Akron
Troy Funte
Liberty Electronics
Steve
www. .com
