That looks like it might be worth while to try. I will tinker with it and
see what pops out.
Thanks Todd
Shirley
_____
rfc822 Compliance issue From: added by system POTENTIAL SPAM
Sent: Wednesday, July 05, 2006 2:23 PM
Subject: RE: [Vantage] Re: Ver5 - Starting Vantage Menu Items without a
mouse
Slim long shot that might be worth playing with....
In what is the vantage.mfg file (was vantage.vtg back in 5.0???) there is a
line:
StartupProcedure=mainmenu.w
that might have been there back in 5.0. Long shot part is looking in
Utilities/Menu Structure Maint. and identifying the program you want to
start at vantage startup and making a custom version of the file - then link
desktop shortcut to the custom version. I don't think it would hurt anything
but rather either work or not work - so maybe worth trying.
The LaborCollection.mfg file has:
StartupProcedure=de\lbrupld.w
so it looks like this can maybe be done.
Once Vantage is started on the right screen for the automated processing,
using custom startup routine, maybe the rest of the navigation would be
constant?
-Todd C.
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com]On
Behalf Of Shirley Graver
Sent: Wednesday, July 05, 2006 12:29 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
mouse
Nope, not a selection on V5, Thanks anyway.
Shirley
_____
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto:
vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On Behalf Of
Sent: Wednesday, July 05, 2006 1:23 PM
Subject: [Vantage] Re: Ver5 - Starting Vantage Menu Items without a mouse
I'm on 6.1. Don't remember if 5 had that option or not. In 6.1 it
is on the main menu screen at the top under View and then Tree Only.
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Shirley
Graver" <shirleyg@...> wrote:
Behalf Of
see what pops out.
Thanks Todd
Shirley
_____
mouse
line:
constant?
-Todd C.
mouse
Shirley
_____
Brian Stenglein
Clow Stamping Co.
>earlier
> That doesnt seem to be an option for version 5. Do you have an
> version? If you are on 5.0 where are you making your TREE ONLYchange?
>[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
> Shirley
> _____
Behalf Of
> rfc822 Compliance issue From: added by system POTENTIAL SPAMmouse
> Sent: Wednesday, July 05, 2006 11:21 AM
>screen
> Try changing your view to Tree Only. It will remove the split
> and place those items that usually appear on the right in the tree.40yahoogroups.com> .com, "Shirley
> The Enter Key will launch them then.
> HTH,
> Brian Stenglein
> Clow Stamping Co.
> Graver" <shirleyg@> wrote:When
> > A standard >Return< will open up The Main Menu and sub menus.
> you getselection
> > to a Menu Item like "Job Adjustment" or "Labor Entry", a
> that40yahoogroups.com> .com] On
> > activates a data entry window, Keystrokes wont start that window.
> > Shirley Graver
> > Rubber Associates
> > _____
> Behalf Ofa
> > Sent: Wednesday, July 05, 2006 10:55 AM
> mousefrom
> > Are you talking about the main Vantage Menu (Tree) or the Menu's
> > inside a certain screen like Sales Order Entry? Can you give an
> > example of where you want to get to?
> > Brian Stenglein
> > Clow Stamping Co.
> > > I'm working on an automation project. Is there a way to start a
> > Vantage
> > > Menu selection strictly from the keyboard, or alternatively
> anwith
> > external
> > > bit of vb code. I know my automation can trigger a menu item
> > mouse[Non-text portions of this message have been removed]
> > > clicks but that rely's on screen/window coordintates. Over a
> > series of
> > > loops those coordinates can "drift".
> > > Shirley Graver
> > > Rubber Associates
