Mainmenu.w not found
Hi all,
I reinstalled the client software again. I'd swear I did everything the
same way as the last few times I tried, except this time I told it to
create a Report Builder icon on the desktop. Then I opened a report with
it, successfully. Then I tried my Vantage icon again, and it worked.
Maybe I did something wrong the first few times I installed it, or maybe
this time, the Report Builder icon placement jogged something in the other
one. It hadn't created the Vantage.vtg icon the first times I'd tried. No
idea why...
Thanks for your help everyone!
Best Regards,
Gary Grenier (IT Manager)
SML Bell
Tel #: (+1)-207-784-2961 x245
Fax #: (+1)-207-784-9838
"Jim Mediger"
<JimM@...
> To
Sent by: <vantage@yahoogroups.com>
vantage@yahoogrou cc
ps.com
Subject
RE: [Vantage] Mainmenu.w not found
2009-02-12 01:32
PM
Please respond to
vantage@yahoogrou
ps.com
-H = host. Check your Host, LMHost, Wins and/or DNS for old and new
server names. Make sure the ip address matches.
Another option:
Create a shortcut something like the following.
V:\Progress\bin\prowin32.exe -db V:\Vantage\db\Vantage.db -N TCP -H
ServerName -S Epic50
Start in: V:\Progress\bin
You can try the Server ip instead of servername for the -H.
Jim
Of garygrenier@...
Sent: Thursday, February 12, 2009 12:17 PM
Subject: RE: [Vantage] Mainmenu.w not found
Done, but I get the same issue. There must me another file or files that
I
should edit for the server name?
Best Regards,
SML Bell
Paul Lipham
<pml@... <mailto:pml%40alspi.com> >
Sent by: To
vantage@yahoogrou "vantage@yahoogroups.com
<mailto:vantage%40yahoogroups.com> "
ps.com <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
cc
2009-02-12 10:24 Subject
AM RE: [Vantage] Mainmenu.w not found
Please respond to
vantage@yahoogrou
ps.com
Anchor is my server name, so try updating with the new server name.
Behalf Of
garygrenier@... <mailto:garygrenier%40sml.com>
Sent: Thursday, February 12, 2009 9:06 AM
Hi Paul,
This is what mine looks like:
[Vantage Startup]
Executable=V:\PROGRESS\bin\prowin32.exe
Database=V:\VANTAGE\db\vantage
IniFile=V:\VANTAGE\vantage.ini
ParameterFile=V:\VANTAGE\db\Vantage.pf
ConnectOptions=-N TCP -H vantage -S epic51 -ld vantage
TempDirectory=C:\Vntgwork
StartupProcedure=mainmenu.w
OtherParameters=-rand 2 -q -basekey ini
What is -H for? You have "anchor" in there. I was wondering if that's
supposed to be the server name. If so, then it's one error on mine, as
"vantage" is the name of the old server.
Best Regards,
SML Bell
Paul Lipham
<pml@... <mailto:pml%40alspi.com> <mailto:pml%40alspi.com>>
Sent by: To
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>"
<mailto:vantage%40yahoogroups.com>>
cc
2009-02-12 09:17 Subject
Please respond to
vantage@yahoogrou
ps.com
Gary,
From your desktop, right click on the Vantage shortcut you are using and
select
properties. On the shortcut tab click on "find target". This should show
you the
icon on your mapped drive to the server.
Verify this is the correct MFG file you want to use to start Vantage. If
so, right
click on it and select edit. Verify that the mapped drives are correct,
etc. and
that you have permission to them.
I've copied and pasted ours from Vantage 6.1, yours should be similar.
We use "P:"
drive for our mapped drive letter.
[MFG Startup]
Executable=P:\PRGS91D\bin\prowin32.exe
Database=P:\mfgsys61\db\MFGSYS
IniFile=P:\mfgsys61\mfgsys.ini
ParameterFile=P:\mfgsys61\db\mfgsys.pf
ConnectOptions=-N TCP -H anchor -S 6100 -ld MFGSYS
TempDirectory=C:\Epicor\MfgWrk61
mfgsys=VN
mfglanguage=enu
mfgtranslator=yes
unicode=true
;MFGODBCpasswd=sysprogress
;MFGODBCUser=sysprogress
;MFGODBCDbse=mfgsys
;MFGODBCServer=Progress91D
<mailto:vantage%40yahoogroups.com> [mailto:
<mailto:vantage%40yahoogroups.com>] On Behalf Of
Sent: Thursday, February 12, 2009 8:12 AM
Jim,
Thank you, I verified that mainmenu.r exists on the new server.
I verified that I did not mistakenly map to the old server. The V: drive
is definitely mapped to the local epic51 folder on the new server.
I verified that there were no entries in the hosts or services files
referencing the old server.
This server is brand new, so the IP address it has is its original (that
I
assigned to it).
Todd,
The client I am using is installed on the new server. I have users who
connect remotely and will need to use Vantage while on the server.
They've
been running that way on the old server for years.
Paul,
I verified that I am connected to the correct share, but is there more
to
what you said than verifying that I'm mapping to the new server epic51
folder as opposed to the old server share?
Best Regards,
SML Bell
"Jim Mediger"
<JimM@... <mailto:JimM%40Holaday.com>
<mailto:JimM%40Holaday.com><mailto:JimM%40Holaday.com>
> To
Sent by: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com><
ps.com
Subject
2009-02-11 02:35
PM
Please respond to
vantage@yahoogrou
ps.com
The file you are looking for is Mainmenu.r ".w" is the source code
version and ".r" is the compiled version. The file should be located in
the epic51/vantage folder.
You don't mention the client, mapped drive (share) etc. If you are using
the same client that connected to the old server make sure to uninstall
old client then install/reinstall client from new server. Also make sure
the old server is not mapped. As someone else mentioned make sure to
check your Host and Services file. Remove the entries for the old
server.
Assuming you have changed the IP address on the new server search the
Registry for the old IP address. If you are comfortable with it, delete
the entries - backup first if needed.
Jim
Of garygrenier@... <mailto:garygrenier%40sml.com>
<mailto:garygrenier%40sml.com><mailto:garygrenier%40sml.com>
Sent: Wednesday, February 11, 2009 11:58 AM
Subject: [Vantage] Mainmenu.w not found
Hi all,
We're running 5.1. We haven't upgraded in years, as we were purchased by
another company who uses their own homegrown ERP package. We continue to
use Vantage only for data collection, job entry and materials
management.
The new company told us we could use it that way "until it breaks" at
which
point, we will be out of luck. Anyway, I am setting up a new server and
am
having trouble getting Vantage to work on it. It's all installed, and
the
DB is running, but when I double click the Vantage icon, I get a gray
box
with the messages:
mainmenu.w not found (293)
Unable to run startup procedure mainmenu.w (492)
I did a search for that on the server and came up with nothing, but I
had
the same result when searching on the soon-to-be-retired old server, so
I'm
assuming it's not a free-standing file.
Any help would be greatly appreciated.
Best Regards,
SML Bell
Confidentiality Notice: The information in this email is confidential.
It is intended only for the use of the named recipient. Any use or
disclosure of this email is strictly prohibited, if you are not the
intended recipient. In case you have received this email in error,
please notify us immediately and then delete this email.
To help reduce unnecessary paper wastage, we would request that you do
not print this email unless it is really necessary - thank you.
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.0.234 / Virus Database: 270.10.20/1943 - Release Date:
02/10/09 07:20:00
It is
intended only for the use of the named recipient. Any use or disclosure
of this
email is strictly prohibited, if you are not the intended recipient. In
case you
have received this email in error, please notify us immediately and then
delete
this email.
not print
It is
of this
case you
delete
this email.
not print
02/10/09 07:20:00
Confidentiality Notice: The information in this email is confidential. It is intended only for the use of the named recipient. Any use or disclosure of this email is strictly prohibited, if you are not the intended recipient. In case you have received this email in error, please notify us immediately and then delete this email.
To help reduce unnecessary paper wastage, we would request that you do not print this email unless it is really necessary - thank you.
Hi all,
use Vantage only for data collection, job entry and materials management.
The new company told us we could use it that way "until it breaks" at which
point, we will be out of luck. Anyway, I am setting up a new server and am
having trouble getting Vantage to work on it. It's all installed, and the
DB is running, but when I double click the Vantage icon, I get a gray box
with the messages:
I did a search for that on the server and came up with nothing, but I had
the same result when searching on the soon-to-be-retired old server, so I'm
Best Regards,
SML Bell
It seems that we use to get this when the network drive was not connected properly to the DB share.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of garygrenier@...
Hi all,
with the messages:
Best Regards,
SML Bell
Switching servers can introduce a bunch of issues. Not the least of which are registry settings on the clients that still point to the old server. Works somewhat better if the new server has the same name as the olde server but that can be a problem if you want both on the network still. Sometimes there are also old entries in the HOSTS and SERVICES files on the clients that will confuse things. When possible (and may be too late now) it is good to uninstall all the clients with only the old server running and then shut that server down (for awhile) and re-install the clients from the new server. If the old server is not available the uninstall of the clients will fail and leave debri in the client registries.
So first try to uninstall a client , then delete all Vantage entries from client's HOSTS and SERVICES files, then re-install the client from new server and see if that fixed at least one of them.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Paul Lipham
Sent: Wednesday, February 11, 2009 12:05 PM
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of garygrenier@... <mailto:garygrenier%40sml.com>
Hi all,
with the messages:
Best Regards,
SML Bell
server.
Jim
Of garygrenier@...
Hi all,
management.
which
am
the
box
with the messages:
had
I'm
Best Regards,
SML Bell
02/10/09 07:20:00
Jim,
This server is brand new, so the IP address it has is its original (that I
assigned to it).
Todd,
connect remotely and will need to use Vantage while on the server. They've
Paul,
I verified that I am connected to the correct share, but is there more to
Best Regards,
SML Bell
"Jim Mediger"
<JimM@...
> To
ps.com
Subject
2009-02-11 02:35
PM
Please respond to
vantage@yahoogrou
ps.com
server.
Jim
Of garygrenier@...
Hi all,
management.
which
am
the
box
with the messages:
had
I'm
Best Regards,
SML Bell
02/10/09 07:20:00
Gary,
From your desktop, right click on the Vantage shortcut you are using and select properties. On the shortcut tab click on "find target". This should show you the icon on your mapped drive to the server.
Verify this is the correct MFG file you want to use to start Vantage. If so, right click on it and select edit. Verify that the mapped drives are correct, etc. and that you have permission to them.
I've copied and pasted ours from Vantage 6.1, yours should be similar. We use "P:" drive for our mapped drive letter.
[MFG Startup]
mfgsys=VN
mfglanguage=enu
mfgtranslator=yes
unicode=true
;MFGODBCDbse=mfgsys
Jim,
assigned to it).
Todd,
Paul,
Best Regards,
SML Bell
"Jim Mediger"
<JimM@...<mailto:JimM%40Holaday.com>
> To
Sent by: <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
ps.com
Subject
2009-02-11 02:35
PM
Please respond to
vantage@yahoogrou
ps.com
server.
Jim
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of garygrenier@...<mailto:garygrenier%40sml.com>
Hi all,
management.
which
am
the
box
with the messages:
had
I'm
Best Regards,
SML Bell
02/10/09 07:20:00
If I remember right way back there was a version that whenever I wanted my server to connect I had to use UNC (\\server\folder<file://\\server\folder>) notation rather than a mapped drive letter and I had to have a special version of the vantage.mfg file (or whatever it was called in 5.1...the file the desktop icon points to). This was just on the server itself but my current 6.1 setup uses the regular vantage.mfg file. Local clients all installed and used the V: mapped letter. Not sure if that may be worth trying jsut to see.
-Todd C.
Jim,
assigned to it).
Todd,
Paul,
Best Regards,
SML Bell
"Jim Mediger"
> To
ps.com
Subject
2009-02-11 02:35
PM
Please respond to
vantage@yahoogrou
ps.com
server.
Jim
Hi all,
management.
which
am
the
box
with the messages:
had
I'm
Best Regards,
SML Bell
02/10/09 07:20:00
Hi Paul,
[Vantage Startup]
Best Regards,
SML Bell
Paul Lipham
<pml@...>
Sent by: To
vantage@yahoogrou "vantage@yahoogroups.com"
ps.com <vantage@yahoogroups.com>
cc
Please respond to
vantage@yahoogrou
ps.com
Gary,
[MFG Startup]
mfgsys=VN
mfglanguage=enu
mfgtranslator=yes
unicode=true
;MFGODBCDbse=mfgsys
garygrenier@...
Jim,
assigned to it).
Todd,
Paul,
Best Regards,
SML Bell
"Jim Mediger"
> To
ps.com
Subject
2009-02-11 02:35
PM
Please respond to
vantage@yahoogrou
ps.com
server.
Jim
Hi all,
management.
which
am
the
box
with the messages:
had
I'm
Best Regards,
SML Bell
02/10/09 07:20:00
this email.
I'll jump in for Paul...Yes, -H is the server name.
-Todd C.
Hi Paul,
[Vantage Startup]
Best Regards,
SML Bell
Paul Lipham
<pml@...<mailto:pml%40alspi.com>>
Sent by: To
vantage@yahoogrou "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>"
ps.com <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
cc
Please respond to
vantage@yahoogrou
ps.com
Gary,
[MFG Startup]
mfgsys=VN
mfglanguage=enu
mfgtranslator=yes
unicode=true
;MFGODBCDbse=mfgsys
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Jim,
assigned to it).
Todd,
Paul,
Best Regards,
SML Bell
"Jim Mediger"
<JimM@...<mailto:JimM%40Holaday.com><mailto:JimM%40Holaday.com>
> To
Sent by: <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>>
ps.com
Subject
2009-02-11 02:35
PM
Please respond to
vantage@yahoogrou
ps.com
server.
Jim
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:
vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf
Of garygrenier@...<mailto:garygrenier%40sml.com><mailto:garygrenier%40sml.com>
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Hi all,
management.
which
am
the
box
with the messages:
had
I'm
Best Regards,
SML Bell
02/10/09 07:20:00
this email.
Hi Paul,
[Vantage Startup]
Best Regards,
SML Bell
Paul Lipham
Sent by: To
cc
Please respond to
vantage@yahoogrou
ps.com
Gary,
[MFG Startup]
mfgsys=VN
mfglanguage=enu
mfgtranslator=yes
unicode=true
;MFGODBCDbse=mfgsys
Jim,
assigned to it).
Todd,
Paul,
Best Regards,
SML Bell
"Jim Mediger"
> To
ps.com
Subject
2009-02-11 02:35
PM
Please respond to
vantage@yahoogrou
ps.com
server.
Jim
Hi all,
management.
which
am
the
box
with the messages:
had
I'm
Best Regards,
SML Bell
02/10/09 07:20:00
this email.
Done, but I get the same issue. There must me another file or files that I
Best Regards,
SML Bell
Paul Lipham
<pml@...>
Sent by: To
cc
Please respond to
vantage@yahoogrou
ps.com
garygrenier@...
Hi Paul,
[Vantage Startup]
Best Regards,
SML Bell
Paul Lipham
Sent by: To
cc
Please respond to
vantage@yahoogrou
ps.com
Gary,
[MFG Startup]
mfgsys=VN
mfglanguage=enu
mfgtranslator=yes
unicode=true
;MFGODBCDbse=mfgsys
Jim,
assigned to it).
Todd,
Paul,
Best Regards,
SML Bell
"Jim Mediger"
> To
ps.com
Subject
2009-02-11 02:35
PM
Please respond to
vantage@yahoogrou
ps.com
server.
Jim
Hi all,
management.
which
am
the
box
with the messages:
had
I'm
Best Regards,
SML Bell
02/10/09 07:20:00
this email.
this email.
Another option:
Jim
Of garygrenier@...
I
Best Regards,
SML Bell
Paul Lipham
Sent by: To
cc
Please respond to
vantage@yahoogrou
ps.com
Behalf Of
Hi Paul,
[Vantage Startup]
Best Regards,
SML Bell
Paul Lipham
Sent by: To
cc
Please respond to
vantage@yahoogrou
ps.com
Gary,
select
you the
so, right
etc. and
We use "P:"
[MFG Startup]
mfgsys=VN
mfglanguage=enu
mfgtranslator=yes
unicode=true
;MFGODBCDbse=mfgsys
Jim,
I
assigned to it).
Todd,
They've
Paul,
to
Best Regards,
SML Bell
"Jim Mediger"
> To
ps.com
Subject
2009-02-11 02:35
PM
Please respond to
vantage@yahoogrou
ps.com
server.
Jim
Hi all,
management.
which
am
the
box
with the messages:
had
I'm
Best Regards,
SML Bell
02/10/09 07:20:00
It is
of this
case you
delete
this email.
not print
It is
of this
case you
delete
this email.
not print
02/10/09 07:20:00
