Weird dashboard behavior
Anybody know what causes this? Not easy to get rid of! That grid is supposed to be full width and height and sometimes it just decides to do this!
It’s an anchor issue and can be caused by messes up personalization which can be deleted , or a messed up customization. Usually to fix it, you have to find the anchor properties in the xml editor and delete them so that they reset. It can be a pain.
There are no personalizations or customizations attached to these, the only way I’ve been able to fix them is by removing the queries and re-adding them to the dashboard. They even look like this in dashboard designer!
If you open the dashboard, then resize before you activate the tab, it can get stuck like that. Make sure you activate (click on) the tab before you resize the window.
