Until it forgets the context and deletes half of your files
but it is magical and I love how fast it makes me
Working as designed. ![]()
yes, it is piling up very fast
I would not want to save it as final code.
But for the test script I need to run couple of times and communicate with LLM, database and files on disk it is so faster than to write myself
My wifeโs company just had an all hands meeting where it told all their Engineering Staff to come up with โprototypesโ of how to use Ai in their product. They scrapped their entire road map and this is their new one.
Literally told go make something with Ai in our product and weโll pick which one to implement. Just find a problem that needs solving. She is besides herself (sad/frustrated). The mandate is literally โImplement Aiโโฆ whatever that means.
EDIT - should have really included below quote for context. Implementing an AI app just for the sake of doing itโฆnot good for an IT personโs nerves.
For our org, I developed a chat application that has multiple functions. Knowledge base, SQL queries (through Azure Relay), web search, and image gen for fun. One reason we opted for this route is cost control and observability. Most providers expect enterprise subscriptions to grant access to usage information for your own org, which means you could be throwing $30 per user a month into a fire when they use $0.05 a week. Your heaviest users, like developers, will cost you more than the subscriptions.
Streaming is key for users to understand why the request appears to be taking forever.
GPT-5โs recent launch was aimed at reducing hallucinations, deception, while increasing safety and performance across the board. The ability for these AIs to call tools (local functions or MCP servers, and provider functions) has improved drastically starting with o4-mini and o3. GPT-5 is the next level of this.
AI models, mostly proprietary ones, usually hallucinate because they do not have the information, but youโll be amazed at the results when provided all relevant info. Prompting matters and evaluation matters in this non-deterministic setting.
Second @TomAlexander 's comments. Github Copilot in VSCode is a dream - pleasantly suprized at the improvement over just a few months ago - well worth the $10.
Some users have enabled M365 Copilot add-on so it can learn on Email, SharePoint, etc. Havenโt checked in with them or tried it myself, but, while it seems expensive at $30, if it saves a user an hour a month, I figure we break even. While weโd adopt more widly if the cost came down, itโs a fairly easy case to make for customer-facing employees and developers, IMO.
I find in Github Copilot for VSCode, it sometimes stops applying diffs to my active files but doesnโt forget. Especially when you ask it to generate md files documenting the project, To Dos, ideas, etc. If I sense it wandering, we go back to the docs and itโs back on track. I ask it to suggest updates to docs after most sessions and when I come back prompt โwhereโd we leave offโ?
Third. And a year for $100.
I saved the console log from F12 into a file, opened it in VSCode, and asked Copilot to summarized the events:
Based on my analysis of the log file, hereโs a summary of the key events that occurred:
ERP Application Part Management Workflow Summary
This log captures a comprehensive workflow in an ERP application for managing part information, specifically for Part Number R1037. Here are the main events:
1. Session Initialization
- Debug logging was enabled (hotkey 15 executed)
- EP-binding logging was toggled off
2. UI Clear Operation
- User initiated a โClear UIโ action with confirmation dialog
- System cleared multiple datasets:
Part,KeyFields,KeyFieldParams,GlbPart,PartUOMPlasticTax - UI was reset and navigation occurred to the โDetailsโ page
3. Part Number Processing (R1037)
- Part Cross-Reference Lookup: System called
GetPartXRefInfoservice to validate part number - Part Validation: Confirmed part number โR1037โ exists and matches user input
- Part Data Retrieval: Called
GetByIDservice to fetch complete part information
4. Data Loading Sequence
The system loaded various related data for part R1037:
- Plant Authorization: Set authorized plants to โMfgSysโ
- Part-Plant Relationships: Configured plant-specific settings
- Cost Data: Loaded part cost information via
PartCostSearchSvc - Bin Information: Retrieved warehouse bin data via
PartBinSearchSvc - UOM & Tax Data: Fetched Unit of Measure and plastic tax information
- Image Data: Attempted to load part images
- Global Part Settings: Checked for global part configurations
5. Key Calculations & Settings
- COO (Country of Origin) Totals: Calculated percentage totals (both set to 0)
- Conversion Factor: Set to โ1 BTL * 1 = 1.0000000 LBโ (Bottle to Pound conversion)
- BackFlush Setting: Determined part is not set for backflushing (false)
- Inventory Attributes: Configured filters for inventory tracking
6. Final State
- Part R1037 successfully loaded with all related data
- UI re-enabled for user interaction
- System ready for further part management operations
Notable Technical Details
- Multiple REST API calls to ERP services (PartSvc, ImageSvc, PartCostSearchSvc, etc.)
- Extensive data binding operations with asynchronous updates
- Conditional logic evaluation throughout the workflow
- Plant โMfgSysโ appears to be the primary manufacturing facility
This represents a typical ERP part lookup and data loading sequence, ensuring all related information is available for the user to view or modify the part record.
And for kicks, I asked it to map out events:
ERP Application Event Flow Map
Part Number R1037 Processing Workflow
๐ SESSION START
โ
โโโ ๐ง Debug Logging Enabled (Hotkey 15)
โโโ ๐ EP-Binding Logging Disabled
โ
โโโ ๐ UI CLEAR OPERATION
โ
โโโ ๐ฑ๏ธ OnClick_toolClearUI
โโโ โ Confirm_ClearUI (Dialog)
โโโ ๐งน Execute_ClearUI
โ โโโ Clear Dataset: Part
โ โโโ Clear Table: KeyFields
โ โโโ Clear Table: KeyFieldParams
โ
โโโ ๐ง System Initialization
โโโ SysInitTemplateViews
โโโ initKeyFields (empty PartNum)
โโโ Clear Dataset: GlbPart
โโโ Clear Dataset: PartUOMPlasticTax
โโโ ๐งญ Navigate to "Details" Page
๐ PART NUMBER INPUT & VALIDATION
โ
โโโ ๐ ColumnChanging_PartNum (User enters R1037)
โโโ ๐ SearchForSimilarPart
โโโ ๐ API Call: GetPartXRefInfo
โ โโโ โ
Response: Part R1037 found
โ โโโ โ No serial warnings
โ โโโ โ No question strings
โ โโโ โ No multiple matches
โ
โโโ โ
Part Number Validation Complete
๐ KEY FIELD PROCESSING
โ
โโโ ๐ KeyField_Changed Event
โโโ ๐ Validation Checks
โ โโโ โ
Not on landing page
โ โโโ โ
Not read-only
โ โโโ โ
Value length > 0
โ โโโ โ
Part not in add mode
โ
โโโ ๐ PerformUpdate Check
โ โโโ โ No changes detected (return-error)
โ
โโโ ๐ฏ KeyField_Changed_GetByID
โโโ ๐ซ Disable Details row
โโโ ๐พ Set SysProposedValue: R1037
โโโ ๐ API Call: GetByID
๐ฅ PART DATA RETRIEVAL
โ
โโโ ๐ Execute_GetByID (PartSvc/GetByID)
โโโ โ
Response received successfully
โโโ ๐ Update_KeyFields_ViewName
โ โโโ ๐ซ Disable column events
โ โโโ ๐พ Set KeyFields.PartNum: R1037
โ โโโ โ
Enable column events
โ
โโโ ๐ GetByID_OnSuccess Event
๐ญ PLANT & AUTHORIZATION SETUP
โ
โโโ ๐ InitializeTracker
โ โโโ ๐ญ AuthorizedPlants: (Plant='MfgSys')
โ โโโ ๐ InTransitPlants: (ToPlant='MfgSys' OR FromPlant='MfgSys')
โ
โโโ ๐ฏ SetPartPlantRowToDefault
โ โโโ ๐ Find current plant row (index 0)
โ โโโ ๐ Set current row to plant data
โ โโโ ๐พ SetPartPlantToCurrent: R1037
โ
โโโ ๐ GetRowNumberbyUOM (UOM row #6, not default)
๐ DATA CALCULATIONS & LOADING
โ
โโโ ๐ CalcPartCOOTotal (Country of Origin)
โ โโโ ๐พ QtyPercTotal: 0
โ โโโ ๐พ ValuePercTotal: 0
โ โโโ ๐พ Commit TotalPerc data
โ
โโโ ๐ผ๏ธ Set_Part_ImageID
โ โโโ ๐ API Call: ImageSvc/GetRows
โ
โโโ ๐ฆ CreatePartBinInfoBinList
โ โโโ ๐พ Initialize empty bin list
โ โโโ ๐ง Execute join function
โ
โโโ ๐ GlobalPartEnablement
โ โโโ ๐พ PartGlobalFields: (empty)
โ โโโ โ Part not flagged as global
โ
โโโ ๐ GetGlbPartsExist
โโโ ๐ API Call: PartSvc/GlbPartsExist
โโโ โ
Result: false (no global parts)
โโโ ๐พ GlbLinkActivate: false
๐ฐ COST & INVENTORY DATA
โ
โโโ ๐ฐ LoadPartCostData
โ โโโ ๐ API Call: PartCostSearchSvc/GetRows
โ
โโโ ๐ท๏ธ GetPartUOMPlasticTax
โ โโโ ๐ API Call: PartSvc/GetPartUOMPlasticTax
โ
โโโ ๐ฆ GetBins
โ โโโ ๐ API Call: PartBinSearchSvc/GetFullBinSearch
โ
โโโ ๐ GetInventoryAttributeValues
โ โโโ โ No inventory tracking enabled
โ
โโโ ๐ง SetInventoryAttributesFilter
โ โโโ ๐ Filter: InventoryDynAttrValues
โ
โโโ ๐งฎ BuildEquation
โ โโโ ๐พ ConversionFactor: "1 BTL * 1 = 1.0000000 LB"
โ
โโโ โก CheckForBackFlush
โโโ โ
PartPlant count > 0
โโโ ๐ Check BackFlush setting
โโโ ๐พ BackFlush: false
๐ฏ COMPLETION
โ
โโโ โ
Enable Details row
โโโ ๐พ Filter.PartNum: R1037
โโโ ๐ System Ready for User Interaction
โโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโโ
๐ SUMMARY STATISTICS:
โข Total API Calls: 8
โข Datasets Cleared: 4 (Part, KeyFields, KeyFieldParams, GlbPart, PartUOMPlasticTax)
โข Key Data Points Set: 15+
โข Plant: MfgSys
โข Part Number: R1037
โข UOM Conversion: 1 BTL = 1.0000000 LB
โข BackFlush: Disabled
โข Global Part: No
๐ง TECHNICAL NOTES:
โข All REST API calls completed successfully
โข No errors or warnings encountered
โข Part exists and is valid
โข System ready for part management operations
Havenโt done any Kinetic C# in VSCode but hope to try something like this plus Copilotโฆ
One obstacle to AI value in this space, IMO, is the fact that Epicor help is not publicly accessible and code samples not plentiful online. I find it makes things up re: Epicor while it doesnโt for many other tech. Surely this is due to lack of samples, blogs, etc.
If it werenโt for this site, AI wouldnโt know jack about Epicor.
If the corporate plan is to capitalize on this fact, making Prism the only product that โknowsโ, thatโs a failed model, IMO.
PS - One drawback to AI is my spelling is slipping ;-|
I donโt recall having to pay for the extension?
Extension is free. GH Copilot sub more more betterer ;-|
| Feature | Free Plan | Pro Plan | Pro+ Plan |
| Code Completions | 2,000/month | Unlimited | Unlimited |
| Chat Interactions | 50/month | Unlimited | Unlimited |
| Premium Requests (Agent Mode, etc.) | 50/month | 300/month | 1,500/month |
| Model Access | GPT-4o, Claude 3.5 | GPT-4.1, Claude 3.7, Gemini | All models incl. Claude Opus 4 |
| Multi-file Editing | |||
| Custom Instructions | |||
| Voice & Terminal Chat |
Given enough context, I still think you can get a lot of value. For example, I converted the Kinetic Inventory Transaction Hierarchy Guild to markdown and opened it in VSCode.
I uploaded the context and asked:
It takes a bit of work to overcome that obstacle but it isnโt as bad as it seems.
A few tips that I use (that have been applied to be able to do things like successfully generate a full EFT .cs based on a PDF specification) are as follows:
Build out a series of MCP tools that can be used by the models that you are using. These are what truly extend the capabilities of the models into more niche domains (kind of like how having a google search tool allows models with old knowledge cutoff dates to still answer questions about recent events). So as an example of one that I put together: There are XML files in the client directory that contain method signatures for nearly every single method within epicor for every single BO. After building a parser to convert these XML files into a more easy to use format (or stick with the xml files and add some additional info in your system prompt), you have a tool call that determines which BO you are asking about (part of my parsing process is to generate overviews of the BOโs based on the methods that they contain). So the model will have a tool call called โIdentifyTargetBusinessObjectโ or similar. Then after it knows which BO you are talking about, you can pull either your cleaned / parsed XML BO def into context in its entirety, or have an additional tool call to identify the method that you are asking about. With this information along with some clever prompting (only use c# features up to and including C# 7.2, no new types/classes/methods, only code that can run inside an existing method, declare helper functions as Func<> or Action<>, etc), you can then just feed it traces along with a request to convert it to a function and it works very reliably. Another way of accomplishing the aforementioned functionality differently is having a tool call dynamically pull the open API spec pages from the rest help which also works really well. Sprinkle in a few other tool calls to validate table and field names and youโll be golden
if you just want a bit of auto complete, part of that github action that I shared is to add the extensions that you want included by default in the github codespace, so you can just include github copilot as a dependency and it will auto-install.
You can tweak the set up script to include a bunch of code examples (as an alternative to the much more involved step 1) in a default c# file that is always included in the spun up project and copilot will pick it up and use it to guide its suggestions.
Build out a single comprehensive prompt that include a series of user requests/answers within it to help guide the model to answer in the format that you want. This makes things much more reliable
As an example:
User: Retrieve sales order records from the last month.
Assistant: Db.OrderHed.Where(o => .....).ToList()
More examples
User's request:
Iโve had the most success (obvious, I suppose) with option 1, but it also requires the most workโฆ
And hopefully this goes without saying, but NEVER blindly accept code generated by any AI models. Ensure that you fully review, understand, and make changes if the model is giving out garbage (which will happen plenty
I feel MCP usage should be clarified. Itโs a middle-man https server which could be used to orchestrate a single tool group for multiple agents (in different use cases or servers).
If you have 1 code base or 1 use case, tools are able to be called natively from the same application as the AI call. MCP isnโt a requirement, but an extension. Itโs like using microservices before you know you even have to scale. Sure, you can, but why?
Context is king. The more context that you can give an LLM, generally, better are the results.
For example, there is an MCP that pulls up-to-date documentation into prompts, which in theory, can reduce hallucinations. This MCP is called Context7.
So yes, we can use MCPs to answer questions for agents, but some have used MCP servers to improve the context of the prompts.
Tools = MCP
They are the same! MCPs are just remote tools.
In fact, tools like (github/ms) copilot, chatgpt, claude, etc all operate by severely limiting context windows. If youโre going to be making MCPs, you might consider your own agent strategy. Paying for chatgpt teams? 32k context window from the max 400k available by the model on GPT5.
^ MCPs do integrate with all of the above, though. Hence the multiple orchestration mention. It is useful if you donโt make your own tools - but if you start making your own MCPs, you are already there.
edit:
as an example, I have a tool exposed to my AI chatbot called epicor-sql when using the SQL Agent. The AI understands the intent, which tools to call, and provides you a call list. You execute the function and its results are placed into context. o4-mini, o3, claude-sonnet-3.5 and on were the best models for this. GPT 5 reasoning is probably the best now.
No MCP needed, I used Azure Relay to get the data from our servers behind infra to the public server hosting the AI chat. The AI used local tools to make those calls.
Correct, you donโt need MCP. But, building context retrieval tools that reside outside of an MCP server that are constrained to a specific providers response format or require tweaking to utilize with other applications is not fun to maintain in my experience. So, building the MCP servers along with those specific context retrieval tools to be able to use with any client that understands that protocol (there are lots
) is worth mentioning. Regardless, to anyone wishing to get the most out of their experience when working on subjects that were not prevalent in the training data of these LLMs: context is one of the most important things to use when aiming for the most accurate responses. Whether you provide that context through MCP, or by pasting a bunch of info into your request to the LLM, it does not matter as long as you provide context to the LLM (especially when dealing with topics of scarce training data such as epicor development). Hopefully that clarifies why I specifically used the term MCP tools in my original post.
