Hi Simon,
1480374PSC (Retro 97161 QM Font size causes error) Epicor - 9.05 700C SQL64
- Neil
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of s1mhall
Sent: Saturday, 3 August 2013 12:56 AM
Subject: [Vantage] Re: Windows 7 setting text size to 125% makes Opportunity/Quote Form throw errors
Thanks for all the replies. I must be going crazy, now I recall this is where I found the resolution to the problem a couple of weeks ago.
I clearly have been staring at the the screen for too long ;)
Good to hear about the fix. If you have a call number I can refer to that would be really helpful.
Cheers
Simon
- Neil
Cheers
Simon
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Neil Buckman <nbuckman@...<mailto:nbuckman@...>> wrote:
> We have a user with poor eyesight and were able to get a patch from Epicor for this.
> We are on 9.05.700C
> - Neil
> -----Original Message-----
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Scotty K.
> Sent: Friday, 2 August 2013 10:52 PM
> Subject: Re: [Vantage] Windows 7 setting text size to 125% makes Opportunity/Quote Form throw errors
> It has been reported several times and discussed in this forum. Search message #114269.
> On Fri, Aug 2, 2013 at 7:27 AM, s1mhall <s1mhall@...<mailto:s1mhall@...>> wrote:
> > Hi,
> > Just came across this one today and logged it with Epicor. If you are
> > using Windows 7 and set your screen text size to 125%, log out and
> > back in then attempt to open the Opportunity/Quote form you get three
> > error messages the first one being "Object Reference not and instance
> > of an object" error. This only appears to happen with the quote form
> > If anyone has seen this behavior before can you let me know the
> > workaround (apart from setting the text size back to 100%).
> > Once again I've logged this with Epicor.
> > You may not think this is a big thing. Yes we don't have many people
> > using that Windows feature (only one). But when that one is CEO you
> > really need a better fix than changing and logging out then in again.
> > I hope this helps someone if they are having the same issue. We are on
> > 9.05.701 64bit SQL.
> > Cheers
> > Simon
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> Notice:This e-mail and any attachments are confidential and are only for the use of the person to whom they are addressed. If you are not the intended recipient please advise the sender by return e-mail and delete the message and any attachments. Any use, interference with, disclosure or copying of this message or any attachments is unauthorised and prohibited. The sender does not warrant that the information is free of a virus or any other defect or error, and any views expressed herein, unless specifically indicated otherwise, are those of the individual sender.
> The DH Gibson Group of Companies - http://www.gibsonshopfitters.com.au
> P Please consider our shared environment before printing this communication.
