We thought we had problems until we discovered that the records weren't
sorting by customer. Someone had changed the sort in search results,
saved the layout, and that caused us to 'think' we weren't seeing the
right results. After we reset the layouts, it seems to work for us. Hope
this helps.
Randy Weber
Of Kerry_Muntz
Sent: Tuesday, May 26, 2009 4:05 PM
Subject: [Vantage] Re: 407c Bugs
We've been getting the same kind of sort/filter problems with 8.03.405A
The problems are worse for some users than others - and sometimes occur
for any user on particular machines.
Some of the problems have temporarily gone away after following this
fix/advice supplied by Epicor (via Cogita):
"...have you had the user delete the temporary files for vantage on
their computer yet? If no please follow the directions below and let me
know if this helps at all.
Browse to the following Directory location on the PC having the problem:
C:\Documents and Settings All Users\Application Data\Epicor\Vantage ...
Remove the Local Cache Files from your local PC:
Delete All of the versional labelled folders in these directories. i.e.
[8.03.xxx] including your current version folder It is possible that you
could have several folders of previous versions in this location
including the current version.
These are temporary cache files and will be regenerated by the
application if required
Once the folders are removed, launch the application again and you will
now have access without error."
...So this above fix does seem to work on some of our users...
But something does seem to still be wrong with certain filtering still
screwing up - and we have this logged.
Hope this helps.
Kerry.
Steven Gotschall <sgotschall@...> wrote:
However, if I return all rows I can use the filter option and it works
fine. Tech Support has suggested editing the .mfgsys too to return all
rows or 1000 at a time, however, sometimes we do want to search for only
a handful of records when we know what we are looking for and it
currently randomly returns records not within the search criteria.
version 9...yeah, I'll get right on that install! I'm pushing them to
release a one-off for us...either that or convert our database back to
8.03.404 :-)
criteria other than the default.
this helps.
Randy Weber
Of Kerry_Muntz
Hope this helps.
Kerry.
><vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
> I saw this glitchy filter thingy starting with 407.
> From: Michelle de la Vega <mdelavega@...>
> To: "vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> "
> Sent: Tuesday, May 26, 2009 3:04:06 PMrecords is glitchy, it doesn't return the 100 records I'm expecting.
> Subject: RE: [Vantage] Re: 407c Bugs
> I just upgraded to 407C this weekend and the filter for 100 customer
>Behalf Of Karl Dash
> Michelle de la Vega
> Business Applications Manager
> Cold Jet, LLC
> 455 Wards Corner Road
> Loveland, Ohio 45140
> USA
> +1 513-716-6400 (office)
> +1 513-382-3281 (mobile)
> +1 513-831-1209 (fax)
> www.coldjet. com<http://www.coldjet. com>
> [cid:image001.jpg@ 01C9DE12. 98E82CA0]
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
> Sent: Tuesday, May 26, 2009 1:49 PMimprovement if you update default.mfgsys and change entry:
> To: vantage@yahoogroups .com
> Subject: Re: [Vantage] Re: 407c Bugs
> Jennifer,
> Regarding the searches returning only 100 results, is there any
> <DefaultSearchPageS ize value="1000" />changed based on user preference.
> This will bring back 1000 entries at a time. Obviously this can be
>age.com<mailto:jmesiano% 40waltonsignage. com>> wrote:
> -Karl
> --- On Tue, 5/26/09, Jennifer <jmesiano@waltonsign
> From: Jennifer <jmesiano@waltonsign age.com<mailto:jmesiano%
> Subject: [Vantage] Re: 407c Bugsfound this out on Monday. Support keeps telling me it is fixed in
> To: vantage@yahoogroups .com<mailto:vantage% 40yahoogroups. com>
> Date: Tuesday, May 26, 2009, 9:50 AM
> It IS true that you cannot do negative subcontract job adjustments. I
8.03.404 :-)
>This stinks when you are trying to do a full record search based on sort
> Other issues
> -cannot adjust labor records, but there is a fix for that.
> -doing searches/lookups suck.. It only shows 100 records at a time.
>that
> --- In vantage@yahoogroups .com, "Dan Godfrey" <dgodfrey@ .> wrote:
> > I understand what you are say but we actually received an error when
> > trying to get a customer from the button. The error details said
> > it was on the GetListCustom method of the Customer Business Object.But
> > that method is not called when using the context menu option withthe
> > other search options.Behalf
> > ____________ _________ _________ __
> > From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On
> > Of Brian W. Spolarichthey
> > Sent: Tuesday, May 26, 2009 8:58 AM
> > Subject: RE: [Vantage] 407c Bugs
> > Dan, typically the reason that folks can't see customers is that
> > have assigned customers to Sales Territories, and they need tocreate
> > Workforce records that they associate with their Vantage logons, andsurprise.
> > give those Work Force IDs access to a given sales territory, or all
> > territories.
> > We're on .405 and had this problem a while after go-live.
> > The maintenance associated with customizations shouldn't be a
> > This is why we have strenuously avoided anything resembling customcode
> > from the start with our ERP selection and implementationrequirements.
> >Photonix /
> > -bws
> > Brian W. Spolarich ~ Manager, Information Services ~ Advanced
> > Picometrixcom> ] On
> > bspolarich@ ..
> > <mailto:bspolarich% 40advancedphoton ix.com> ~ 734-864-5618 ~
> > www.advancedphotoni x.com
> > -----Original Message-----
> > From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> > [mailto:vantage@ yahoogroups .com <mailto:vantage% 40yahoogroups.
> > Behalf Of Dan Godfreywould
> > Sent: Tuesday, May 26, 2009 11:53 AM
> > To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
> > We just installed 407c because we had a service call that Vantage
> > not look at until we upgraded TO 407C. We had immediate issues.basically
> > - We could not bring up any customers through the search button.
> > - So I created a BAQ and then attached a search to it and made it
> > the default search option. BUT,
> > - the Customer Search Button still does not work. We have to get
> > the new search through the right-click context menu option
> > - we also had Vantage create some custom components for us and found
> > out that we will have to pay Vantage $$ for every upgrade to
> > recompile the customization.brought
> > - there were two other major issues also that I have not been
> > in yet to fix or Vantage gave a work-around for them.com> ] On
> > Dan
> > BehalfJob
> > Of Rob Bucek
> > Sent: Tuesday, May 26, 2009 6:19 AM
> > I heard rumor of not being able to make negative adjustments on the
> > Adjustments form...if true..thats a bit scary..com/
> > Rob Bucek
> > Manufacturing Engineer
> > PH: 715-284-5376 ext 311
> > FAX: 715-284-4084
> > <http://www.dsmfg. com/ <http://www.dsmfg. com/> <http://www.dsmfg.
> > <http://www.dsmfg. com/> > >com>
> > (Click the logo to view our site)
> > <mailto:vantage% 40yahoogroups. com> ] Onon
> > Behalf
> > Of Michael McWilliams
> > Sent: Tuesday, May 26, 2009 8:08 AM
> > Subject: [Vantage] 407c Bugs
> > Any major issues with 407C I should watch out for. I am installing
> > our test server today to test all my customizations.must
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > have already linked your email address to a yahoo id to enableaccess. )
> > (1) To access the Files Section of our Yahoo!Group for ReportBuilder
> > and Crystal Reports and other 'goodies', please goto:[Non-text portions of this message have been removed]
> > http://groups. yahoo.com/ group/vantage/ files/.
> > <http://groups. yahoo.com/ group/vantage/ files/.>
> > http://groups. yahoo.com/ group/vantage/ messages
> > <http://groups. yahoo.com/ group/vantage/ messages>
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups. yahoo.com/ group/vantage/ linksYahoo
> > <http://groups. yahoo.com/ group/vantage/ linksYahoo> ! Groups Links
