We are running Terminal Services. And you do install directly onto the Terminal Server. When installing go to your Control Pannel - Add/Remove Programs - Add New Programs on the left hand side of the screen and install from there. Choose the location where you want it stored and you should be good to go.
Casey
----- Original Message ----
To: "Vantage@Yahoogroups. Com" <vantage@yahoogroups.com>
Sent: Wednesday, February 13, 2008 12:49:28 PM
Subject: [Vantage][6.1]Crystal Reports and Terminal Server
I'm new to using Terminal Server at a remote location, and I need to use
Crystal Reports to create reports for the company. Where does CR need to be
installed? - on the Terminal Server? An IT consultant the company uses says
installing software on Terminal Server is different than on a normal PC -
doesn't seem to make sense to me, but like I said, I'm new to Terminal
Server - any comments/advice would be appreciated.
thanks,
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
Casey
thanks,
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
