Ok, that's another problem.
Apparently Progress is manipulated by 4GL language.
Consequently, 4GL allows writing more data than the field size is
defined for.
If you try to import this data using any SQL engine you will get errors.
The only solution is to adjust field width. I am doing this using data
dictionary.
Adam Gwizdz
Database Manager
Main Tape Company
Sent: Thursday, December 01, 2005 1:58 PM
Subject: RE: [Vantage][6.1] ODBC
Okay I created the view but now SQL is basically saying the ROW size is
too big! How do I get around that oh wise one!
Joe Luster
Network Administrator
Cold Jet, LLC
513-831-3211 ext. 308
513-831-1209 FAX
<http://www.coldjet.com>
_____
Of Gwizdz, Adam
Sent: Thursday, December 01, 2005 12:30 PM
Try to create a view using Progress SQL Explorer Tool, and then use DTS
again.
Although we do not use MERANT 3.60 driver but DataDirect 4.20 for
Progress 10.0B, it should not matter.
Usually what I do is:
Create View odbcuser.Customer_view As SELECT * From Pub.Customer;
commit;
Then I import it from odbcuser.Customer_view to Access or I suppose it
should work with SQL Server.
Adam Gwizdz
Database Manager
Main Tape Company
Sent: Thursday, December 01, 2005 12:20 PM
Subject: [Vantage][6.1] ODBC
When trying to pull tables from Progress into MS SQL 2000 using DTS and
the MERANT 3.60 driver, I get an error on certain tables, something like
they have too many indexes. This even happens in MS Access on certain
tables such as the customer table. I know that I can delete indexes
using one of the tools provided by Progress. (I would try it on a test
database first.) Has anyone else ran across this error when trying to
get tables out of Progress into SQL or Access?
Joe Luster
Cold Jet, LLC
513-831-1209 FAX
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
_____
SPONSORED LINKS
Manufacturing software
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
Database management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
_____
YAHOO! GROUPS LINKS
_____
_____
YAHOO! GROUPS LINKS
_____
defined for.
dictionary.
Adam Gwizdz
Database Manager
Main Tape Company
Joe Luster
Cold Jet, LLC
513-831-1209 FAX
_____
Of Gwizdz, Adam
again.
commit;
Adam Gwizdz
Database Manager
Main Tape Company
Joe Luster
Cold Jet, LLC
513-831-1209 FAX
_____
YAHOO! GROUPS LINKS
_____
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
_____
YAHOO! GROUPS LINKS
_____
