Todd,
I am not sure about v6, as I am running 8 (so even more recource hoggy than
your situation.
I simply have a laptop with the client installed on it and inside my net I
have a windows 2k machine with VPN enabled. The VPN server is a domain
member, so authentication is through AD.
I simply connect to vpn from laptop and then launch vantage. Works very
well, as long as server and notebook meet std. v 8 reqs and there is a good
pipe into the server, and at client location.
I know someone else mentioned a methodoldgy of emailing pdf files to
themselves over TS.
There is a product called thinprint that makes a print redirector for
printers and scanners. Install is easy, and then TS clients can print to
their local printers without having to worry about installing printers and
drivers on the server, and making sure printer IDS in insall inf files match
across OS versions, etc. Works like a champ.
However, I have not tested this with v8 and crystal engine yet.
Carey
your situation.
themselves over TS.
Carey
>From: "Todd Caughey" <caugheyt@...>
>Reply-To: vantage@yahoogroups.com
>To: <vantage@yahoogroups.com>
>Subject: [Vantage] [6.1] Very Small Remote Site
>Date: Fri, 30 Jun 2006 11:06:21 -0500
>I need a little advice from the TS people or others with very small remote
>operations. I have been co-opted from my regular duties to support a new
>startup company one of our owners is creating. Very small operation
>(probably 3 people max to start with) making weatherproof outdoor bars for
>pool/patio/yacht etc.. They want me to set them up in Vantage. Trouble is
>the way they want to do it is flawed in a dozen ways. Idea is to have our
>stamping operation people in Woodbury, MN doing all the Vantage work from
>info faxed and emailed from Homestead, FL.
>I can see oodles of ways this will consume too much time up here while
>leaving things in chaos down there. Not good. Much better I think to link
>them to our system up here and run Vantage from one PC down there where
>they have a better idea of what is going on. We can still take orders up
>here and process payments and financials....but let them do their own shop
>related activities.
>So....what's the best way to link one remote PC to Vantage? Do I really
>need TS? Can it run on that PC (server and client in one)? Will our T1 at
>this and and a DSL conenction at that end be sufficient? I need to reduce
>costs as much as possible in order to get this to fly and avoid the weak
>fax/email link method from being adopted.
>Thanks,
>Todd Caughey
>Harvey Vogel Mfg. Co. (and Paradise Bar Inc. too)
>[Non-text portions of this message have been removed]
