8.03.403 Reason Codes
Here's what we have for DMR reason codes. We had to be specific on
the titles because they were all showing up in all forms no matter
which check boxes were selected in setup (e.g. DMR accept reasons
showing up in the Inspection Processing fail list). Apparently they
have fixed this in 8.03.304 and later versions though.
CRTM Cert of Conformance Missing
DMG Damaged
DIT Damaged in Transit
RGD DMR - Accept - Regrade
RPR DMR - Accept - Repair
RWK DMR - Accept - Rework
UAI DMR - Accept - Use As Is
SLVG DMR - Reject - Salvage
SCP DMR - Reject - Scrap
RTV DMR - Reject -Return to Vendor
LEX Lot Expiration
OBS Obsolete
OOS Out of Spec
--- In vantage@yahoogroups.com, "Paul Pachniak" <paul.pachniak@...>
wrote:
> We are in the process of loading fresh info into our new 8.03.403
> database for a 01/01/08 go live and I had a question as to how
others
> have set up their reason codes. In 6.1 we had a lot of codes that
> seemed to be redundant from reason type DMR and QA and it doesn't
seem
> right. I would appreciate if I could get a couple of samples as to
how
> others have set up their reason codes to either confirm that we are
OK
> as is or if we need to make some adjustments. A list of reason
> codes/descriptions by reason type would be greatly appreciated.
Either
> post on line or email to me.
> Thanks in advance.
> Paul E. Pachniak
> Accounting Manager
> Ace Precision Machining Corporation
> W146 N5714 Enterprise Avenue
> Menomonee Falls, WI 53051
> Phone: 262-252-4003 Ext. 1114
> Fax: 262-252-4974
> Email: paul.pachniak@...
> WWW: http://www.aceprecision.com
> NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL
INFORMATION OF ACE PRECISION MACHINING CORP. If you are an
unintended recipient, immediately (1) delete all copies of this
message and any attachments, and (2) contact the sender. If you are
an intended recipient, you are prohibited from deleting or
obstructing this or any other Ace Precision Machining Corp.
proprietary or confidentiality designation that appears on this
message or any attachments. All recipients are prohibited from
reproducing, publishing or disclosing the contents of this message
and any attachments to others, unless you first request and receive
written permission from Ace Precision Machining Corp.
database for a 01/01/08 go live and I had a question as to how others
seemed to be redundant from reason type DMR and QA and it doesn't seem
right. I would appreciate if I could get a couple of samples as to how
others have set up their reason codes to either confirm that we are OK
codes/descriptions by reason type would be greatly appreciated. Either
Thanks in advance.
Paul E. Pachniak
Accounting Manager
Fax: 262-252-4974
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF ACE PRECISION MACHINING CORP. If you are an unintended recipient, immediately (1) delete all copies of this message and any attachments, and (2) contact the sender. If you are an intended recipient, you are prohibited from deleting or obstructing this or any other Ace Precision Machining Corp. proprietary or confidentiality designation that appears on this message or any attachments. All recipients are prohibited from reproducing, publishing or disclosing the contents of this message and any attachments to others, unless you first request and receive written permission from Ace Precision Machining Corp.
You could look at the Training dataset and its various reason codes.
If you like them it is a simple copy and paste. - Monte Tomerlin
others
seem
how
OK
Either
> Thanks in advance.
> Paul E. Pachniak
> Accounting Manager
> Fax: 262-252-4974
