I did tests with the GSP on 409c last week and no problem with the boards!!! Did you run the calculate order process before the global scheduling process?
--- In vantage@yahoogroups.com, melissa hietala <kevmel822@...> wrote:
> We are currently on 8.03.406, tested 409, and now testing 409C and want to
> upgrade this coming weekend.
> Any help on the following 2 issues would be appreciated:
> 1. When running global finite scheduling there are jobs that are not appearing
> on the scheduling boards, but are apparently in the system as the Shop Load
> report is showing some machines in an overload situation. If I load level in
> those machines the jobs that were 'invisible' show now on the boards. Did not
> have this problem when we were testing .409
> 2. When creating a new Customer Shipment packing list getting an
> Â 'ERROR condition: Parameter number 6 (table ttShipMisc) mismatch. Has 36 fields
> - client schema has 38 fields. (8030)(7211)'
> Any ideas on a db conversion we missed or a fix we need?
> I have been through a few more modules without issue and have a few more to go.
> Please let me know if there is anything else I should watch out for, ask Epicor
> for a fix for, or any other pertinent information.
> Thanks.
> Melissa Hietala
> UMC, Inc.
> melissah@...
