Thanks for all your help. We will call the tech support and try and get this one
off.
 Melissa Hietala
UMC, Inc.
melissah@...
Sent: Tue, May 24, 2011 8:40:31 AM
Subject: [Vantage] Re: 8.03.409C Vantage Admin tools - Run coversion program
Â
Wow, good thing I was sitting down, but I almost fell off my chair! I want to
say that is the stupidest thing I have ever heard, but it can't quite beat
"working as designed"...
off.
 Melissa Hietala
UMC, Inc.
melissah@...
Â
--- In vantage@yahoogroups.com, Steven Gotschall <sgotschall@...> wrote:
> I was once told, Are you sitting down? That it was for security purposes.
> From: Virginia Joseph <vjoseph@...>
> Sent: Monday, May 23, 2011 6:23 PM
> ÂÂ
> Yep, that was it. Do you know why we have to contact Epicor to get a new file
>each time this happens? What a waste of time. Would be nice if they could
>provide us with one file we could use each time we need it.
> Thanks,
> Virginia Jospeh
> --- In vantage@yahoogroups.com, Steven Gotschall <sgotschall@> wrote:
> > This might be related to a problem I see every once and a while. It has
>to do with the conversion log file being to large (or an entry that is to
>large). Epicor has a one time fix for this (you have to ask for a new
>one each time the problem pops up).
> > From: Virginia Joseph <vjoseph@>
> > Sent: Friday, May 20, 2011 8:44 AM
> > ÂÂÂ
> > We are experiencing the same error except under a slightly different
>scenario. My conversion list seems to be complete and I can select conversion
>8920 from the list and run the conversion. It allows me to put in the company,
>the employee ID and when I click on Get Detailed Transactions the labor details
>appear and then it displays the following error.
> > Attempt to update CnvProgs record data exceeding 32000 (12370). When I click
>ok, I get the next error:
> > Unable to update CnvProga field (142).
> > In addition, now I am in this continuous loop of errors and it won't let me
>out of the 8920 conversion so I cannot access any of the other admin tools.
> > Any ideas?
> > Thanks,
> > Virginia Joseph
> > Deep Hole Specialists, LLC
> > vjoseph@
> > --- In vantage@yahoogroups.com, melissa hietala <kevmel822@> wrote:
> > > All of a sudden my list of conversion programs cuts off at 8910 and I
>get this
> > > message:
> > > 'ERROR
> > > Attempt to update "dbo"."cnvprogs" record dara excedding 32000(12370) '
> > > then I get
> > > 'Error
> > > Unable to read record bufferr because it is empty (455)'
> > > Of course I need 8920 program for a user. I've used this a hundred times
>now I
> > > can't get to it.
> > > Thanks for any ideas
> > >  Melissa Hietala
> > > UMC, Inc.
> > > melissah@
