NO. I just found out that I had to delete all the cached files related to that user on the PC in the application data folder.
--- In vantage@yahoogroups.com, "Jeff Stockard" <jeff.stockard@...> wrote:
> Does that user get the message when they log on to a different PC?
> Jeff
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> Michael McWilliams
> Sent: Thursday, April 02, 2009 12:06 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] 8.03 Root Element Missing
> Anyone ever see this error. A user keeps getting this over & over
> I log in as someone else into Vantage on the Same PC & do not get it.
> Error Detail
> Root element is missing.
> Stack Trace
> at System.Xml.XmlTextReaderImpl.Throw(Exception e)
> at System.Xml.XmlTextReaderImpl.ThrowWithoutLineInfo(String res)
> at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
> at System.Xml.XmlTextReaderImpl.Read()
> at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean
> preserveWhitespace)
> at System.Xml.XmlDocument.Load(XmlReader reader)
> at Epicor.Mfg.UI.FrameWork.FormFunctions.ReadXmlDocument(Object Sender,
> XmlDocument& xDoc, String FileName, String Type, Boolean allUsers, String&
> FilePath)
> at Epicor.Mfg.UI.FrameWork.FormFunctions.CacheUserGlobalOptions(Object
> sender, String typeCode, String key1, String key2, String key3)
