--- In vantage@yahoogroups.com, "vantage803" <bash100@...> wrote:
work after the upgrade. The XML being generated can't be opened by
Crystal reports even for a brand new report. If I tediously re-create
the customized RDD after the patch, then my reports work. This was
hard and prone to missing something...
you say you "recopied the Report Data Def files and everything worked
fine after that" how'd you do that?? are Report data Defs stored
outside the DB????
thanks,
David -
Peregrine Semiconductor
San Diego,CA
>after that.
> Mark,
> We have upgrade to 803.305D as well, found same issues with reporting.
> I recopied the Report Data Def files and everything worked fine
> <snip>We are having this problem... our Custom Report Data Definitions don't
> regards
> -Joe
outside the DB????
thanks,
David -
San Diego,CA
