Finally got an answer from Epicor Support on this, its a bug with a TBD fix date. Order Management SCR 79061.
Epicor's work around is to Custom Map the field but that doesn't work either. Still working with support on a workaround that works...
Chris Wineinger
ERP Specialist
Interior Systems Inc.
Chris Wineinger
ERP Specialist
--- In vantage@yahoogroups.com, Stelios Zoumis <s.zoumis@...> wrote:
> You can do it using a BPM.
> [Description: Description: Description: Description: cid:image002.png@...]
> Stelios Zoumis <mailto:s.zoumis@...> | EBS - Enterprise Business Solutions | Sr Business Consultant |
> Tel: +30 210 6874300 (ext. 314) | Fax: +30 210 6855564 | www.atc.gr<http://www.atc.gr/>
> [Description: Description: Description: Description: cid:image009.jpg@...]<https://dunsregistered.dnb.com/DunsRegisteredProfileAnywhere.aspx?Key1=3100369&PaArea=email>
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Cathy
> Sent: Monday, March 25, 2013 8:40 PM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Re: 905.700b2 - copying UD fields from Quote Header to Order Header
> Is there a Customization for the Quote Screen? Through Customization, check
> the Script Editor for any custom code.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
> redrhyno13
> Sent: Monday, March 25, 2013 11:35 AM
> Subject: [Vantage] Re: 905.700b2 - copying UD fields from Quote Header to
> Order Header
> Yes that module is there but no link to QuoteHed from OrderHed.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> , Karen
> Schoenung <kschoenung@<mailto:kschoenung@>> wrote:
> > Not being on your version, I am not sure it is the same...But, in version
> 8.03.409C there is a "Custom Field Map" under utilities...This can map some
> of those fields...In version 8 it does not look like there is a link between
> quote and sales order though...
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of redrhyno13
> > Sent: Monday, March 25, 2013 12:48 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] 905.700b2 - copying UD fields from Quote Header to
> Order Header
> > I need help trying to find out what is running that copies all short
> character and character fields from Quote Header to Sales order Header.
> > I've disabled all BPM's Method & Data and any updateable BAQs.
> > When I load a new BLANK Sales order from quote, all the UD fields still
> copy over from Quote and go into the wrong fields. They are copying to the
> like named field in Order Header from Quote Header. ie: character10 in Sales
> order Header copies from Quote Header Character10 instead of Character04
> like I have programmed in a BPM (that is disabled)
> > I ran a trace file with BPM's on and Off and they look almost identical
> > Any ideas tthat will help me locate what is doing this would be helpful.
> > Thanks,
> > Chris Wineinger
> > ERP Specialist
> > Interior Systems, Inc.
