Recently I started getting this error in the BAQ designer.
Severity: Warning, Text: A secured or licensed column is referenced by a table relation from (PartRev Type: Table) to (PartOpr Type: Table). Associated data will not be returned
This happens when I add partrev and partop tables into my layout. I fix the issue by removing two of the pre-defined table relations. I remove AltMethod, and ProcessMfgID from the relations for both tables, and then the error goes away.
Epicor added a new field ProcessMfgID as part of the key structure, but you can’t access it if you don’t have it licensed. The “fix” is to go into the join criteria and remove it. I submitted a ticket to Epicor on this, is already a known issue PRB0250431. Probably will get fixed in a future release, but for now the “workaround” is pretty quick.
Thanks for posting the fix, @SimsTrak. This got me with PartRev today. Still not fixed in 2023.2. I can’t imagine Epicor wanting BAQ’s to crash with their auto-created joins is on Working As Designed. But yet here we are.
What % of Epicor customers have ProcessMfgID licensed anyways? We have most of the modules licensed, but not this one.
@Chris_Conn - Can you create a W.A.D. song to debut at Insights 2025?
I ran into this earlier this year, I didn’t get the full message about the licensed column though, it just returned zero rows until I removed that field. Weird.
Submit another ticket to the void
Another error message to avoid
“Have you tried turning it off and on?”
The same response since time unknown
CHORUS:
W! A! D!
Working as Designed!
Your suffering’s been pre-defined
W! A! D!
Trapped in digital chains that bind
Enterprise Resource Planning hell
Each module’s got its own story to tell
Click through screens of endless forms
“This behavior follows platform norms”
CHORUS:
W! A! D!
W! A! D!
BREAKDOWN:
Error code 5-0-9
They say the system’s working fine
Deadline’s breathing down my neck
Support just sent another tech
(Spoken with growing intensity)
“According to our documentation…
This is expected behavior…
The system is performing…
WORKING! AS! DESIGNED!”
CHORUS:
W! A! D!
W! A! D!
Forever trapped in ERP’s grind
Dumb question but how do you remove ProcessMfgID manually from the BAQ?
Update:
Nevermind, figured it out. It’s in the join itself. BAQ designer auto added that field. Which I didn’t notice but that makes sense. Removed the field and all is well.
