ABL Code Error messages Help
Haha! Oh ok. I was wondering when you said that and thought maybe that was something Epicor regulated on this site.
Well I don't mind sharing at all. I basically needed a BPM to make the "To Bin" on the Handheld screen the primary bin for an item when someone wanted to create a new primary bin. We do hundreds of stock moves each day and about 20-30% require a new primary. We were making the stock moves with the HH and writing the item and new primary on a sheet and turning it into the office for someone to update the primary. That person would spend at least 2-3 hrs a day just doing primary updates. This is huge for what we do and might benefit someone out there. I customized the HH Move Inventory Screen with adding a checkbox for when the associate wants to make the "To Bin" the primary bin for that item. I then created the BPM under InvTrans.CommitTransfer with the following code;
/*Add source code that should be executed before the designed actions here*/
find first ttInvTrans where ttInvTrans.RowMod = "U" or ttinvtrans.RowMod = "A".
if available ttinvtrans then do:
Find first PlantWhse where PlantWhse.Company = ttinvtrans.company and PlantWhse.PartNum = ttinvtrans.PartNum and PlantWhse.WarehouseCode = "RACOMAIN" and ttinvtrans.ToWarehouseCode = "RACOMAIN" no-error.
if avail PlantWhse then do:
Run lib\UpdateTableBuffer.p(input BUFFER PlantWhse:HANDLE, 'PrimBin',ttinvtrans.ToBinNum).
end.
end.
/*Add source code that should be executed after the designed actions here*/
Enjoy and I want to thank all of you for all your help with this issue. I have gotten a lot of suggestions and all of them got me to it working. Thanks again guys and gals!!! This was my first BPM ever and it was a fun one.
--- In vantage@yahoogroups.com, brenda mohr <brenda@...> wrote:
> HAHA, No, sharing is very good, you just shouldn't modify your data w/out using the Business Objects. I am an "OLD" programmer and learned to code before we had objects and functions and such. Back when we still used punch cards..... Just didn't want to pass on bad habits <VBG>
> Brenda
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Drew
> Sent: Thursday, May 23, 2013 2:49 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: ABL Code Error messages Help
> I got it working. Is there a rule on here to not share code? You mentioned it being a sin.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@<mailto:brenda@>> wrote:
> > Well the Run lib commands are out of my league. I could give you the code to update the field directly, but the powers that be tell me it is a "Go To Hell" Sin....
> > Brenda
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Drew
> > Sent: Thursday, May 23, 2013 12:03 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > I hear what you are saying, but I need it to be tied to the InvTrans because we might have a item# is 20 locations, but want to change the primary because we need to move it to a larger bin. It needs to be a dictated by the user to determine when it should be set as the primary. We do stock moves all day and most don't require a primary update, but some do and this is suppose to eliminate someone else updating the primary on a desktop. I just can't imagine why Epicor doesn't have a function to make that change with the HandHelds. Annoying.
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@<mailto:brenda@>> wrote:
> > > I would maybe suggest trying this from another angle. That invTrans table gives me heartache too because it seems to act more like a view (to me anyway). I have a customization on the menu that auto populates the From info to the actual bin the part is in.
> > > So what I did was to set the ttCallContextBpmData.ShortChar01 to the iPartNum. Then execute some ABL code, setting ttCallContextBpmData fields to the values I got in the code and then allowing the BPM to do the update: Yours is a little different, but you can get the basic drift.
> > > Pre-Processing Directive "SetMe"
> > > Conditions - NONE
> > > Actions: set the ShortChar01 field of BPM Data to the iPartNum expression
> > > Post-Processing Directive "AssignWareHs"
> > > Conditions - the iPartNum argument begins with the "T-" expression
> > > Actions:
> > > synchronously execute ABL FIND FIRST ttCallContextBpmData exclusiv ... record nothing
> > > and set the InvTrans.FromWarehouseCode field of all rows to the ttCallContextBpmData.ShortChar02 expression
> > > and set the InvTrans.FromBinNum field of all rows to the ttCallContextBpmData.ShortChar03... expression
> > > and set the InvTrans.FromLotNumber field of all rows to the ttCallContextBpmData.ShortChar04... expression
> > > ABL CODE:
> > > FIND FIRST ttCallContextBpmData exclusive-lock.
> > > FIND FIRST Part WHERE (Part.Company = CUR-COMP) AND (Part.PartNum = ttCallContextBpmData.ShortChar01) no-error.
> > > IF AVAILABLE Part THEN DO:
> > > FIND FIRST PartBin WHERE (PartBin.Company = CUR-COMP) AND (PartBin.PartNum = Part.PartNum)no-error.
> > > IF AVAILABLE PartBin THEN DO:
> > > Assign ttCallContextBpmData.ShortChar02 = PartBin.WarehouseCode.
> > > ttCallContextBpmData.ShortChar03 = PartBin.BinNum.
> > > ttCallContextBpmData.ShortChar04 = PartBin.LotNum.
> > > END.
> > > Brenda
> > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Drew
> > > Sent: Thursday, May 23, 2013 9:04 AM
> > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > > This is what it looks like now and still getting same errors.
> > > FOR EACH ttInvTrans WHERE (ttInvTrans.RowMod = 'U') OR (ttInvTrans.RowMod =
> > > 'A') no-lock.
> > > FIND FIRST PlantWhse WHERE (PlantWhse.Company = CUR-COMP) AND (PlantWhse.PartNum=
> > > ttInvTrans.PartNum) AND (PlantWhse.WarehouseCode = "RACOMAIN") AND (ttInvTrans.ToWarehouseCode = "RACOMAIN") NO-ERROR.
> > > IF AVAILABLE PlantWhse THEN DO:
> > > FOR EACH ttCallContextBpmData WHERE ttCallContextBpmData.Checkbox01 = True.
> > > Run lib\UpdateTableBuffer.p(input BUFFER PlantWhse:HANDLE, 'PartWhse.PrimBinNum',
> > > END.
> > > END.
> > > end.
> > > end.
> > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@<mailto:brenda@>> wrote:
> > > > I would write it like this: (with a . (period) not a : (Colon) and FIND FIRST not just FIND
> > > > 'A') no-lock.
> > > > FIND FIRST PlantWhse WHERE (PlantWhse.Company = CUR-COMP) AND (PlantWhse.PartNum =
> > > > Brenda
> > > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Drew
> > > > Sent: Wednesday, May 22, 2013 5:02 PM
> > > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > > > for each ttInvTrans where ttInvTrans.RowMod = 'U' or ttinvtrans.RowMod =
> > > > 'A':
> > > > find PlantWhse where PlantWhse.Company = CUR-COMP and PlantWhse.PartNum =
> > > > ttinvtrans.ToWarehouseCode = "RACOMAIN" NO-ERROR.
> > > > END.
> > > > END.
> > > > {&CALL_DESIGNED_ACTIONS}
> > > > end.
> > > > end.
> > > > Error Detail
> > > > ** Cannot find NEXT LEAVE RETY or UNDO label on appropriate clock.(209)
> > > > ** Could not understand line 1.(196)
> > > > ** Unknown Field or Variable name - exceptionOccured__.(201)
> > > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@<mailto:brenda@>> wrote:
> > > > > Can you send the current code w/ all the changes?
> > > > > Brenda
> > > > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Drew
> > > > > Sent: Wednesday, May 22, 2013 2:58 PM
> > > > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > > > > I know get these errors
> > > > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "justincalbraze" <justint@<mailto:justint@>> wrote:
> > > > > > I've always wrote them like:
> > > > > > For Each Table WHERE ( Table.Field = True) no-lock.
> > > > > > Using the parenthesis and period at the end of the line.
> > > > > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "Drew" <ahsalloum@> wrote:
> > > > > > > Thanks Chris,
> > > > > > > Does True need to be in quotes? I get different errors when TRUE is in quotes or not.
> > > > > > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "Chris Robisch" <bluewine@> wrote:
> > > > > > > > add a period after 'true'.
> > > > > > > > ----- Original Message -----
> > > > > > > > From: "Drew" <ahsalloum@>
> > > > > > > > To: <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>>
> > > > > > > > Sent: Wednesday, May 22, 2013 9:17 AM
> > > > > > > > > Joshua,
> > > > > > > > > I really appreciate the help, but I am still getting a couple of errors
> > > > > > > > > with this code. Like I said, I don't know how to code so I can't figure
> > > > > > > > > this out.
> > > > > > > > > I am getting these errors;
> > > > > > > > > ** Unable to understand after -- "ttCallContextBpmData.Checkbox01". (247)
> > > > > > > > > ** C:\EpicorData\20915011212172376287237252138253242157.p Line
> > > > > > > > > 23 --Invalid FOR, DO, REPEAT, or EDITING statement. (194)
> > > > > > > > > The code is;
> > > > > > > > > here*/
> > > > > > > > > 'A':
> > > > > > > > > True
> > > > > > > > > END.
> > > > > > > > > END.
> > > > > > > > > end.
> > > > > > > > > end.
> > > > > > > > > here*/
> > > > > > > > > What do you think?
> > > > > > > > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Joshua Giese <jgiese@> wrote:
> > > > > > > > >> True
> > > > > > > > >> Joshua Giese
> > > > > > > > >> CTO
> > > > > > > > >> 920.437.6400 Ext. 337
> > > > > > > > >> Site ID: 27450-E905700B2-SQL64
> > > > > > > > >> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > > > > > > > >> Sent: Wednesday, March 27, 2013 10:49:45 AM
> > > > > > > > >> What would that where statement say?
> > > > > > > > >> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> , Jose Gomez <jose@> wrote:
> > > > > > > > >> > You are missing a where clause on your for each its FOR EACH
> > > > > > > > >> > ttCalContext
> > > > > > > > >> > "WHERE" et.c..
> > > > > > > > >> > *Jose C Gomez*
> > > > > > > > >> > *Software Engineer*
> > > > > > > > >> > *T: 904.469.1524 mobile
> > > > > > > > >> > E: jose@
> > > > > > > > >> > http://www.josecgomez.com
> > > > > > > > >> > < http://www.linkedin.com/in/josecgomez
> > > > > > > > >> > http://www.facebook.com/josegomez >
> > > > > > > > >> > < http://www.google.com/profiles/jose.gomez
> > > > > > > > >> > http://www.twitter.com/joc85 >
> > > > > > > > >> > < http://www.josecgomez.com/professional-resume/ >
> > > > > > > > >> > < http://www.josecgomez.com/feed/ >
> > > > > > > > >> > < http://www.usdoingstuff.com >
> > > > > > > > >> > *Quis custodiet ipsos custodes?*
> > > > > > > > >> > On Wed, Mar 27, 2013 at 11:46 AM, Drew <ahsalloum@> wrote:
> > > > > > > > >> > > Hey everyone. I have added a checkbox(CallContextBpmData.Checkbox01)
> > > > > > > > >> > > to
> > > > > > > > >> > > the Hand Held "Move Inventory" Screen in the "To" group. Once the
> > > > > > > > >> > > checkbox
> > > > > > > > >> > > is selected, I want a BPM to make the "To" Bin the primary
> > > > > > > > >> > > bin(PartWhse.PrimBinNum) for the part being transferred. I am getting
> > > > > > > > >> > > a
> > > > > > > > >> > > couple of errors and can't figure out how to fix them.
> > > > > > > > >> > > Please take in consideration that I got this from someone else. I
> > > > > > > > >> > > don't
> > > > > > > > >> > > know this language and this is my companies first BPM. Here is the
> > > > > > > > >> > > code and
> > > > > > > > >> > > error messages;
> > > > > > > > >> > > Error Detail
> > > > > > > > >> > > (247)
> > > > > > > > >> > > ** C:\EpicorData\20915011212172376287237252138253242157.p Line 23
> > > > > > > > >> > > Code
> > > > > > > > >> > > here*/
> > > > > > > > >> > > ttinvtrans.RowMod =
> > > > > > > > >> > > 'A':
> > > > > > > > >> > > PlantWhse.PartNum =
> > > > > > > > >> > > FOR EACH ttCallContextBpmData.Checkbox01 = True
> > > > > > > > >> > > END.
> > > > > > > > >> > > END.
> > > > > > > > >> > > end.
> > > > > > > > >> > > end.
> > > > > > > > >> > > here*/
> > > > > > > > >> > > Thanks,
> > > > > > > > >> > > Andrew
> > > > > > > > >> > [Non-text portions of this message have been removed]
> > > > > > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > > > > > > > > have already linked your email address to a yahoo id to enable access. )
> > > > > > > > > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > > > > > > > > Crystal Reports and other 'goodies', please goto:
> > > > > > > > > http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/>
> > > > > > > > > (2) To search through old msg's goto:
> > > > > > > > > http://groups.yahoo.com/group/vantage/messages
> > > > > > > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > > > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > > > > > > > > No virus found in this message.
> > > > > > > > > Checked by AVG - www.avg.com<http://www.avg.com>
> > > > > > > > > Version: 2013.0.3343 / Virus Database: 3162/6347 - Release Date: 05/22/13
Hey everyone. I have added a checkbox(CallContextBpmData.Checkbox01) to the Hand Held "Move Inventory" Screen in the "To" group. Once the checkbox is selected, I want a BPM to make the "To" Bin the primary bin(PartWhse.PrimBinNum) for the part being transferred. I am getting a couple of errors and can't figure out how to fix them.
Please take in consideration that I got this from someone else. I don't know this language and this is my companies first BPM. Here is the code and error messages;
Error Detail
** C:\EpicorData\20915011212172376287237252138253242157.p Line 23 --Invalid FOR, DO, REPEAT, or EDITING statement. (194)
Code
'A':
END.
END.
end.
end.
Andrew
You are missing a where clause on your for each its FOR EACH ttCalContext
"WHERE" et.c..
*Jose C Gomez*
*Software Engineer*
E: jose@...
<http://www.usdoingstuff.com>
> error messages;
> Error Detail
> Code
> here*/
> 'A':
> END.
> END.
> end.
> end.
> Thanks,
> Andrew
> "WHERE" et.c..
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > error messages;
> > Error Detail
> > Code
> > here*/
> > 'A':
> > END.
> > END.
> > end.
> > end.
> > Thanks,
> > Andrew
Erm... whatever you want? or you don't ahve to have one... it an just be
FOR EACH ttCalContextData:
Rest of code here;
END.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> > "WHERE" et.c..
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > <http://www.linkedin.com/in/josecgomezhttp://www.facebook.com/josegomez>
> > <http://www.google.com/profiles/jose.gomezhttp://www.twitter.com/joc85>
> checkbox
> code and
> > > error messages;
> > > Error Detail
> (247)
> > > Code
> > > here*/
> > > 'A':
> PlantWhse.PartNum =
> > > END.
> > > END.
> > > end.
> > > end.
> here*/
> > > Thanks,
> > > Andrew
Joshua Giese
CTO
> "WHERE" et.c..
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> < http://www.linkedin.com/in/josecgomez http://www.facebook.com/josegomez >
> < http://www.google.com/profiles/jose.gomez http://www.twitter.com/joc85 >
> > error messages;
> > Error Detail
> > Code
> > here*/
> > 'A':
> > END.
> > END.
> > end.
> > end.
> > Thanks,
> > Andrew
I forgot to say thanks guys. I appreciate the help.
> Joshua Giese
> CTO
> From: "Drew" <ahsalloum@...>
> > "WHERE" et.c..
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@
> > > error messages;
> > > Error Detail
> > > Code
> > > here*/
> > > 'A':
> > > END.
> > > END.
> > > end.
> > > end.
> > > Thanks,
> > > Andrew
Joshua,
I really appreciate the help, but I am still getting a couple of errors with this code. Like I said, I don't know how to code so I can't figure this out.
The code is;
'A':
END.
END.
end.
end.
What do you think?
> Joshua Giese
> CTO
> > "WHERE" et.c..
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@
> > > error messages;
> > > Error Detail
> > > Code
> > > here*/
> > > 'A':
> > > END.
> > > END.
> > > end.
> > > end.
> > > Thanks,
> > > Andrew
To: <vantage@yahoogroups.com>
> Joshua,
> this out.
> The code is;
> here*/
> 'A':
> True
> END.
> END.
> end.
> end.
> here*/
> What do you think?
>> True
>> Joshua Giese
>> CTO
>> > ttCalContext
>> > "WHERE" et.c..
>> > *Jose C Gomez*
>> > *Software Engineer*
>> > E: jose@
>> > > to
>> > > checkbox
>> > > a
>> > > don't
>> > > code and
>> > > error messages;
>> > > Error Detail
>> > > (247)
>> > > Code
>> > > here*/
>> > > ttinvtrans.RowMod =
>> > > 'A':
>> > > PlantWhse.PartNum =
>> > > END.
>> > > END.
>> > > end.
>> > > end.
>> > > here*/
>> > > Thanks,
>> > > Andrew
Thanks Chris,
> > Joshua,
> > this out.
> > The code is;
> > here*/
> > 'A':
> > True
> > END.
> > END.
> > end.
> > end.
> > here*/
> > What do you think?
> >> True
> >> Joshua Giese
> >> CTO
> >> > ttCalContext
> >> > "WHERE" et.c..
> >> > *Jose C Gomez*
> >> > *Software Engineer*
> >> > E: jose@
> >> > > to
> >> > > checkbox
> >> > > a
> >> > > don't
> >> > > code and
> >> > > error messages;
> >> > > Error Detail
> >> > > (247)
> >> > > Code
> >> > > here*/
> >> > > ttinvtrans.RowMod =
> >> > > 'A':
> >> > > PlantWhse.PartNum =
> >> > > END.
> >> > > END.
> >> > > end.
> >> > > end.
> >> > > here*/
> >> > > Thanks,
> >> > > Andrew
I believe you need a colon after the true.
FOR EACH ttCallContextBpmData WHERE ttCallContextBpmData.Checkbox01 = True:
John
--- In vantage@yahoogroups.com, "Drew" <ahsalloum@...> wrote:
> Thanks Chris,
> > > Joshua,
> > > this out.
> > > The code is;
> > > here*/
> > > 'A':
> > > True
> > > END.
> > > END.
> > > end.
> > > end.
> > > here*/
> > > What do you think?
> > >> True
> > >> Joshua Giese
> > >> CTO
> > >> > ttCalContext
> > >> > "WHERE" et.c..
> > >> > *Jose C Gomez*
> > >> > *Software Engineer*
> > >> > E: jose@
> > >> > > to
> > >> > > checkbox
> > >> > > a
> > >> > > don't
> > >> > > code and
> > >> > > error messages;
> > >> > > Error Detail
> > >> > > (247)
> > >> > > Code
> > >> > > here*/
> > >> > > ttinvtrans.RowMod =
> > >> > > 'A':
> > >> > > PlantWhse.PartNum =
> > >> > > END.
> > >> > > END.
> > >> > > end.
> > >> > > end.
> > >> > > here*/
> > >> > > Thanks,
> > >> > > Andrew
> Thanks Chris,
> > > Joshua,
> > > this out.
> > > The code is;
> > > here*/
> > > 'A':
> > > True
> > > END.
> > > END.
> > > end.
> > > end.
> > > here*/
> > > What do you think?
> > >> True
> > >> Joshua Giese
> > >> CTO
> > >> > ttCalContext
> > >> > "WHERE" et.c..
> > >> > *Jose C Gomez*
> > >> > *Software Engineer*
> > >> > E: jose@
> > >> > > to
> > >> > > checkbox
> > >> > > a
> > >> > > don't
> > >> > > code and
> > >> > > error messages;
> > >> > > Error Detail
> > >> > > (247)
> > >> > > Code
> > >> > > here*/
> > >> > > ttinvtrans.RowMod =
> > >> > > 'A':
> > >> > > PlantWhse.PartNum =
> > >> > > END.
> > >> > > END.
> > >> > > end.
> > >> > > end.
> > >> > > here*/
> > >> > > Thanks,
> > >> > > Andrew
Do I need to have a condition in the BPM if I am adding the ABL code? I am thinking the code has the same condition I will be adding.
> --- In vantage@yahoogroups.com, "Drew" <ahsalloum@> wrote:
> > Thanks Chris,
> > > > Joshua,
> > > > this out.
> > > > The code is;
> > > > here*/
> > > > 'A':
> > > > True
> > > > END.
> > > > END.
> > > > end.
> > > > end.
> > > > here*/
> > > > What do you think?
> > > >> True
> > > >> Joshua Giese
> > > >> CTO
> > > >> > ttCalContext
> > > >> > "WHERE" et.c..
> > > >> > *Jose C Gomez*
> > > >> > *Software Engineer*
> > > >> > E: jose@
> > > >> > > to
> > > >> > > checkbox
> > > >> > > a
> > > >> > > don't
> > > >> > > code and
> > > >> > > error messages;
> > > >> > > Error Detail
> > > >> > > (247)
> > > >> > > Code
> > > >> > > here*/
> > > >> > > ttinvtrans.RowMod =
> > > >> > > 'A':
> > > >> > > PlantWhse.PartNum =
> > > >> > > END.
> > > >> > > END.
> > > >> > > end.
> > > >> > > end.
> > > >> > > here*/
> > > >> > > Thanks,
> > > >> > > Andrew
I -think- if the condition is blank it just triggers your code anytime that process is called.
Can always add a {lib\PublishInfoMsg.i &InfoMsg = "'Fire! ' "}. to the code and see when/if anything is triggering.
> > > Thanks Chris,
> > > > > Joshua,
> > > > > this out.
> > > > > The code is;
> > > > > here*/
> > > > > 'A':
> > > > > True
> > > > > END.
> > > > > END.
> > > > > end.
> > > > > end.
> > > > > here*/
> > > > > What do you think?
> > > > >> True
> > > > >> Joshua Giese
> > > > >> CTO
> > > > >> > ttCalContext
> > > > >> > "WHERE" et.c..
> > > > >> > *Jose C Gomez*
> > > > >> > *Software Engineer*
> > > > >> > E: jose@
> > > > >> > > to
> > > > >> > > checkbox
> > > > >> > > a
> > > > >> > > don't
> > > > >> > > code and
> > > > >> > > error messages;
> > > > >> > > Error Detail
> > > > >> > > (247)
> > > > >> > > Code
> > > > >> > > here*/
> > > > >> > > ttinvtrans.RowMod =
> > > > >> > > 'A':
> > > > >> > > PlantWhse.PartNum =
> > > > >> > > END.
> > > > >> > > END.
> > > > >> > > end.
> > > > >> > > end.
> > > > >> > > here*/
> > > > >> > > Thanks,
> > > > >> > > Andrew
> > Thanks Chris,
> > > > Joshua,
> > > > this out.
> > > > The code is;
> > > > here*/
> > > > 'A':
> > > > True
> > > > END.
> > > > END.
> > > > end.
> > > > end.
> > > > here*/
> > > > What do you think?
> > > >> True
> > > >> Joshua Giese
> > > >> CTO
> > > >> > ttCalContext
> > > >> > "WHERE" et.c..
> > > >> > *Jose C Gomez*
> > > >> > *Software Engineer*
> > > >> > E: jose@
> > > >> > > to
> > > >> > > checkbox
> > > >> > > a
> > > >> > > don't
> > > >> > > code and
> > > >> > > error messages;
> > > >> > > Error Detail
> > > >> > > (247)
> > > >> > > Code
> > > >> > > here*/
> > > >> > > ttinvtrans.RowMod =
> > > >> > > 'A':
> > > >> > > PlantWhse.PartNum =
> > > >> > > END.
> > > >> > > END.
> > > >> > > end.
> > > >> > > end.
> > > >> > > here*/
> > > >> > > Thanks,
> > > >> > > Andrew
Brenda
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "justincalbraze" <justint@...<mailto:justint@...>> wrote:
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Drew" <ahsalloum@> wrote:
> > Thanks Chris,
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Chris Robisch" <bluewine@> wrote:
> > > To: <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
> > > > Joshua,
> > > > this out.
> > > > The code is;
> > > > here*/
> > > > 'A':
> > > > True
> > > > END.
> > > > END.
> > > > end.
> > > > end.
> > > > here*/
> > > > What do you think?
> > > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Joshua Giese <jgiese@> wrote:
> > > >> True
> > > >> Joshua Giese
> > > >> CTO
> > > >> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> , Jose Gomez <jose@> wrote:
> > > >> > ttCalContext
> > > >> > "WHERE" et.c..
> > > >> > *Jose C Gomez*
> > > >> > *Software Engineer*
> > > >> > E: jose@
> > > >> > > to
> > > >> > > checkbox
> > > >> > > a
> > > >> > > don't
> > > >> > > code and
> > > >> > > error messages;
> > > >> > > Error Detail
> > > >> > > (247)
> > > >> > > Code
> > > >> > > here*/
> > > >> > > ttinvtrans.RowMod =
> > > >> > > 'A':
> > > >> > > PlantWhse.PartNum =
> > > >> > > END.
> > > >> > > END.
> > > >> > > end.
> > > >> > > end.
> > > >> > > here*/
> > > >> > > Thanks,
> > > >> > > Andrew
'A':
END.
END.
end.
end.
Error Detail
> Brenda
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "justincalbraze" <justint@<mailto:justint@>> wrote:
> > > Thanks Chris,
> > > > > Joshua,
> > > > > this out.
> > > > > The code is;
> > > > > here*/
> > > > > 'A':
> > > > > True
> > > > > END.
> > > > > END.
> > > > > end.
> > > > > end.
> > > > > here*/
> > > > > What do you think?
> > > > >> True
> > > > >> Joshua Giese
> > > > >> CTO
> > > > >> > ttCalContext
> > > > >> > "WHERE" et.c..
> > > > >> > *Jose C Gomez*
> > > > >> > *Software Engineer*
> > > > >> > E: jose@
> > > > >> > > to
> > > > >> > > checkbox
> > > > >> > > a
> > > > >> > > don't
> > > > >> > > code and
> > > > >> > > error messages;
> > > > >> > > Error Detail
> > > > >> > > (247)
> > > > >> > > Code
> > > > >> > > here*/
> > > > >> > > ttinvtrans.RowMod =
> > > > >> > > 'A':
> > > > >> > > PlantWhse.PartNum =
> > > > >> > > END.
> > > > >> > > END.
> > > > >> > > end.
> > > > >> > > end.
> > > > >> > > here*/
> > > > >> > > Thanks,
> > > > >> > > Andrew
'A') no-lock.
Brenda
'A':
END.
END.
end.
end.
Error Detail
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@...<mailto:brenda@...>> wrote:
> Brenda
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "justincalbraze" <justint@<mailto:justint@>> wrote:
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "Drew" <ahsalloum@> wrote:
> > > Thanks Chris,
> > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "Chris Robisch" <bluewine@> wrote:
> > > > To: <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>>
> > > > > Joshua,
> > > > > this out.
> > > > > The code is;
> > > > > here*/
> > > > > 'A':
> > > > > True
> > > > > END.
> > > > > END.
> > > > > end.
> > > > > end.
> > > > > here*/
> > > > > What do you think?
> > > > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Joshua Giese <jgiese@> wrote:
> > > > >> True
> > > > >> Joshua Giese
> > > > >> CTO
> > > > >> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> , Jose Gomez <jose@> wrote:
> > > > >> > ttCalContext
> > > > >> > "WHERE" et.c..
> > > > >> > *Jose C Gomez*
> > > > >> > *Software Engineer*
> > > > >> > E: jose@
> > > > >> > > to
> > > > >> > > checkbox
> > > > >> > > a
> > > > >> > > don't
> > > > >> > > code and
> > > > >> > > error messages;
> > > > >> > > Error Detail
> > > > >> > > (247)
> > > > >> > > Code
> > > > >> > > here*/
> > > > >> > > ttinvtrans.RowMod =
> > > > >> > > 'A':
> > > > >> > > PlantWhse.PartNum =
> > > > >> > > END.
> > > > >> > > END.
> > > > >> > > end.
> > > > >> > > end.
> > > > >> > > here*/
> > > > >> > > Thanks,
> > > > >> > > Andrew
'A') no-lock.
END.
END.
end.
end.
> 'A') no-lock.
> Brenda
> 'A':
> END.
> END.
> end.
> end.
> Error Detail
> > Brenda
> > > > Thanks Chris,
> > > > > > Joshua,
> > > > > > this out.
> > > > > > The code is;
> > > > > > here*/
> > > > > > 'A':
> > > > > > True
> > > > > > END.
> > > > > > END.
> > > > > > end.
> > > > > > end.
> > > > > > here*/
> > > > > > What do you think?
> > > > > >> True
> > > > > >> Joshua Giese
> > > > > >> CTO
> > > > > >> > ttCalContext
> > > > > >> > "WHERE" et.c..
> > > > > >> > *Jose C Gomez*
> > > > > >> > *Software Engineer*
> > > > > >> > E: jose@
> > > > > >> > > to
> > > > > >> > > checkbox
> > > > > >> > > a
> > > > > >> > > don't
> > > > > >> > > code and
> > > > > >> > > error messages;
> > > > > >> > > Error Detail
> > > > > >> > > (247)
> > > > > >> > > Code
> > > > > >> > > here*/
> > > > > >> > > ttinvtrans.RowMod =
> > > > > >> > > 'A':
> > > > > >> > > PlantWhse.PartNum =
> > > > > >> > > END.
> > > > > >> > > END.
> > > > > >> > > end.
> > > > > >> > > end.
> > > > > >> > > here*/
> > > > > >> > > Thanks,
> > > > > >> > > Andrew
Ok, I got it to save without errors, but does not make the change to Primary when I perform the stock move.
'A'.
Find first PlantWhse where PlantWhse.Company = CUR-COMP and PlantWhse.PartNum =
end.
end.
end.
> 'A') no-lock.
> END.
> END.
> end.
> end.
> > 'A') no-lock.
> > Brenda
> > 'A':
> > END.
> > END.
> > end.
> > end.
> > Error Detail
> > > Brenda
> > > > > Thanks Chris,
> > > > > > > Joshua,
> > > > > > > this out.
> > > > > > > The code is;
> > > > > > > here*/
> > > > > > > 'A':
> > > > > > > True
> > > > > > > END.
> > > > > > > END.
> > > > > > > end.
> > > > > > > end.
> > > > > > > here*/
> > > > > > > What do you think?
> > > > > > >> True
> > > > > > >> Joshua Giese
> > > > > > >> CTO
> > > > > > >> > ttCalContext
> > > > > > >> > "WHERE" et.c..
> > > > > > >> > *Jose C Gomez*
> > > > > > >> > *Software Engineer*
> > > > > > >> > E: jose@
> > > > > > >> > > to
> > > > > > >> > > checkbox
> > > > > > >> > > a
> > > > > > >> > > don't
> > > > > > >> > > code and
> > > > > > >> > > error messages;
> > > > > > >> > > Error Detail
> > > > > > >> > > (247)
> > > > > > >> > > Code
> > > > > > >> > > here*/
> > > > > > >> > > ttinvtrans.RowMod =
> > > > > > >> > > 'A':
> > > > > > >> > > PlantWhse.PartNum =
> > > > > > >> > > END.
> > > > > > >> > > END.
> > > > > > >> > > end.
> > > > > > >> > > end.
> > > > > > >> > > here*/
> > > > > > >> > > Thanks,
> > > > > > >> > > Andrew
