Activate a Shape control
I just realize my mistake.
I didn't change the checkbox06 to checkbox01.
Sorry
Ephraim Feldman
Sender: vantage@yahoogroups.com
Date: Mon, 05 Jul 2010 22:05:04
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Subject: [Vantage] Re: Activate a Shape control
Hi Sean
This is the code i did but it doesnt work maybe im missing something
'// Custom VB.NET code for POEntryForm
'// Created: 2007-07-18 5:32:26 PM
Imports System
Imports System.Data
Imports System.Diagnostics
Imports System.Windows.Forms
Imports System.ComponentModel
Imports Microsoft.VisualBasic
Imports Epicor.Mfg.UI
Imports Epicor.Mfg.UI.FrameWork
Imports Epicor.Mfg.UI.ExtendedProps
Imports Epicor.Mfg.UI.FormFunctions
Imports Epicor.Mfg.UI.Customization
Imports Epicor.Mfg.UI.Adapters
Imports Epicor.Mfg.UI.Searches
Imports Epicor.Mfg.BO
Module Script
'// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added Module Level Variables' Comments! **
'// Begin Wizard Added Module Level Variables **
Private WithEvents edvPODetail As EpiDataView
'// End Wizard Added Module Level Variables **
'// Add Custom Module Level Variables Here **
Sub InitializeCustomCode()
'// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Variable Initialization' lines **
'// Begin Wizard Added Variable Initialization
edvPODetail = CType(oTrans.EpiDataViews("PODetail"), EpiDataView)
AddHandler edvPODetail.EpiViewNotification, AddressOf edvPODetail_EpiViewNotification
AddHandler PODetail_Column.ColumnChanged, AddressOf PODetail_AfterFieldChange
'// End Wizard Added Variable Initialization
'// Begin Wizard Added Custom Method Calls
'// End Wizard Added Custom Method Calls
End Sub
Sub DestroyCustomCode()
'// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Object Disposal' lines **
'// Begin Wizard Added Object Disposal
RemoveHandler edvPODetail.EpiViewNotification, AddressOf edvPODetail_EpiViewNotification
edvPODetail = Nothing
RemoveHandler PODetail_Column.ColumnChanged, AddressOf PODetail_AfterFieldChange
'// End Wizard Added Object Disposal
'// Begin Custom Code Disposal
'// End Custom Code Disposal
End Sub
Sub SetVisibility()
Dim [edvVarName] As EpiDataView = CType(oTrans.EpiDataViews("ListView"),EpiDataView)
Dim MyEpiShape as EpiShape
MyEpiShape = CType(csm.GetNativeControlReference("36c307ad-b9b0-4ed2-87bf-c9160c64e808"),EpiShape)
try
MyEpiShape.Enabled = [edvVarName].dataView([edvVarName].Row)("CheckBox06")
Catch ex as Exception
MyEpiShape.Enabled = false
End try
End Sub
Private Sub edvPODetail_EpiViewNotification(ByVal view As EpiDataView, ByVal args As EpiNotifyArgs)
'** Argument Properties and Uses **
'view.dataView(args.Row)("[FieldName]")
'args.Row, args.Column, args.Sender, args.NotifyType
'NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
If (args.NotifyType = EpiTransaction.NotifyType.Initialize) Then
If (args.Row > -1) Then
SetVisibility()
End If
End If
End Sub
Private Sub PODetail_AfterFieldChange(ByVal sender As Object, ByVal args As DataColumnChangeEventArgs)
'args.Row("[FieldName]")
'args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Select Case args.Column.ColumnName
Case "CheckBox01"
SetVisibility()
Case Else
End Select
End Sub
End Module
--- In vantage@yahoogroups.com, "Sean McDaniel" <smcdaniel@...> wrote:
> In the wizard tab you will need to set up an EpiViewNotification for the
> view that contains the information to turn the shape on/off (this will
> be used to set the shape visibility when the record is initially
> displayed), and an onFieldChange event for when the field changes (this
> will be used to change the shape visibility when someone makes a change
> to the form).
> Create a procedure like this:
> Sub SetVisibility()
> EpiDataView)
> MyEpiShape = CType(csm.GetNativeControlReference("<Your GUID Here>
> "),EpiShape)
> try
> MyEpiShape.Visible =
> MyEpiShape.Visible = false
> End catch
> End Sub
> In the EpiViewNotification, change the "AddNew" to "initialize" and have
> it call the above procedure.
> In the OnFieldChange do the same thing.
> Of efyf_1999
> Sent: Friday, July 02, 2010 3:50 PM
> Thanks for you reply
> I was able to set the form load but when it comes to setting it enabled
> and disable by a checkbox i couldnt do it
> Maybe you can explain a bit better since im a newbie.
> Thanks
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "bw2868bond" <bwalker@> wrote:
> > In your Form Load event, define the text for the 2 states of the shape
> control, define the color of the control when enabled and set the
> initial status:
> > shpMailInvoice.EnabledCaption = "Do Not Mail Invoice"
> > shpMailInvoice.DisabledCaption = "Invoice is Mailed"
> > shpMailInvoice.Status = StatusTypes.Warning
> > shpMailInvoice.Enabled = False
> > find the event you want to use to change the status of the control and
> make it enabled or disabled:
> > shpMailInvoice.Enabled = view.dataView(args.Row)("CheckBox04")
> > bw
> "Mark Taylor" <mark.taylor@> wrote:
> > > I have the same problem.
> > > I was thinking I would need to use the event wizard, but I just
> don't
> > > know the code needed to enter in here to make it work.
> > > I just need one of our IT geeks to look at it when they have the
> time.
> > > Mark Taylor
> > > Senior Document Controller
> > > Hansatech EMS provides value manufacturing through engineering and
> > > quality
> > >________________________________
> > > Hansatech EMS Limited
> > > Benson Road
> > > Nuffield Industrial Estate
> > > Poole
> > > Dorset BH17 0RY
> > > United Kingdom
> > > Tel:
> > > Fax:
> > > DDI:
> > > +44 (0)1202 338200
> > > +44 (0)1202 338202
> > > +44 (0)1202 338228
> > > Mark.Taylor@
> > > www.HansatechEMS.com
> > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > > Of efyf_1999
> > > Sent: 01 July 2010 21:27
> > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > Subject: [Vantage] Activate a Shape control
> > > I have a checkbox on the screen and i want a shape control should be
> > > active or not based on this checkbox how do i do it
> > > thanks
> > >__________________________________________________________
> > > This email has been scanned by the MessageLabs Email
I have a checkbox on the screen and i want a shape control should be active or not based on this checkbox how do i do it
thanks
I was thinking I would need to use the event wizard, but I just don't
I just need one of our IT geeks to look at it when they have the time.
Mark Taylor
quality
Benson Road
Poole
Dorset BH17 0RY
United Kingdom
Tel:
Fax:
DDI:
+44 (0)1202 338200
+44 (0)1202 338202
+44 (0)1202 338228
Mark.Taylor@...
Of efyf_1999
thanks
______________________________________________________________________
In your Form Load event, define the text for the 2 states of the shape control, define the color of the control when enabled and set the initial status:
find the event you want to use to change the status of the control and make it enabled or disabled:
bw
> Mark Taylor
> quality
> Benson Road
> Poole
> Dorset BH17 0RY
> United Kingdom
> Tel:
> Fax:
> DDI:
> +44 (0)1202 338200
> +44 (0)1202 338202
> +44 (0)1202 338228
> Mark.Taylor@...
> Of efyf_1999
> thanks
Here's a code snippet/explanation:
Looking at the code for the EpiShape you don't set the colors directly,
rather you set the "Status" Property in code.
The four StatusTypes are:
StatusTypes.Warning
StatusTypes.Global
StatusTypes.OK
StatusTypes.Stop
shpEpiCustom1.Status = StatusTypes.Warning
The following code snippet from the EpiShape control shows which colors
are associated with a particular status:
switch(status)
case StatusTypes.Warning:
color1 = Color.Yellow;
color2 = Color.LightYellow;
enabledTextColor = Color.Black;
break;
case StatusTypes.Global:
color1 = Color.MediumBlue;
color2 = Color.LightBlue;
enabledTextColor = Color.LightBlue;
break;
case StatusTypes.OK:
color1 = Color.Green;
color2 = Color.LightGreen;
enabledTextColor = Color.LightGreen;
break;
case StatusTypes.Stop:
color1 = Color.Red;
color2 = Color.MistyRose;
enabledTextColor = Color.AntiqueWhite;
break;
Of Mark Taylor
Sent: Friday, July 02, 2010 5:03 AM
Subject: RE: [Vantage] Activate a Shape control
Mark Taylor
quality
Benson Road
Poole
Dorset BH17 0RY
United Kingdom
Tel:
Fax:
DDI:
+44 (0)1202 338200
+44 (0)1202 338202
+44 (0)1202 338228
Mark.Taylor@... <mailto:Mark.Taylor%40HansatechEMS.com>
Behalf
Of efyf_1999
thanks
I was able to set the form load but when it comes to setting it enabled and disable by a checkbox i couldnt do it
> bw
> > Mark Taylor
> > quality
> > Benson Road
> > Poole
> > Dorset BH17 0RY
> > United Kingdom
> > Tel:
> > Fax:
> > DDI:
> > +44 (0)1202 338200
> > +44 (0)1202 338202
> > +44 (0)1202 338228
> > Mark.Taylor@
> > Of efyf_1999
> > thanks
to the form).
Sub SetVisibility()
EpiDataView)
"),EpiShape)
try
End catch
End Sub
Of efyf_1999
initial status:
> bw
don't
time.
> > Mark Taylor
> > quality
> > Benson Road
> > Poole
> > Dorset BH17 0RY
> > United Kingdom
> > Tel:
> > Fax:
> > DDI:
> > +44 (0)1202 338200
> > +44 (0)1202 338202
> > +44 (0)1202 338228
> > Mark.Taylor@
Behalf
> > Of efyf_1999
> > thanks
Thanks Sean I appreciate the detailed information.
I will try it monday.
Ephraim
Ephraim Feldman
Date: Fri, 2 Jul 2010 16:40:33
Subject: RE: [Vantage] Re: Activate a Shape control
to the form).
Sub SetVisibility()
EpiDataView)
"),EpiShape)
try
End catch
End Sub
Of efyf_1999
initial status:
> bw
don't
time.
> > Mark Taylor
> > quality
> > Benson Road
> > Poole
> > Dorset BH17 0RY
> > United Kingdom
> > Tel:
> > Fax:
> > DDI:
> > +44 (0)1202 338200
> > +44 (0)1202 338202
> > +44 (0)1202 338228
> > Mark.Taylor@
Behalf
> > Of efyf_1999
> > thanks
Hi Sean
Imports System
Imports System.Data
Module Script
End Sub
End Sub
Sub SetVisibility()
try
End try
End Sub
SetVisibility()
End If
End If
End Sub
Case "CheckBox01"
SetVisibility()
Case Else
End Select
End Sub
End Module
> to the form).
> Sub SetVisibility()
> EpiDataView)
> "),EpiShape)
> try
> End catch
> End Sub
> Of efyf_1999
> Thanks
> initial status:
> > bw
> don't
> time.
> > > Mark Taylor
> > > quality
> > > Benson Road
> > > Poole
> > > Dorset BH17 0RY
> > > United Kingdom
> > > Tel:
> > > Fax:
> > > DDI:
> > > +44 (0)1202 338200
> > > +44 (0)1202 338202
> > > +44 (0)1202 338228
> > > Mark.Taylor@
> Behalf
> > > Of efyf_1999
> > > thanks
