Add Column to Part Transaction History Tracker - V8.03
Thank Jose.  I'm really appreciate your advice and am fine with the BAQ (apart from I can't put the running total in there that's shown on the tracker?) but it's the customization \ coding I'm struggling with.
I'm not totally sure where to put your code - if it incorporates into what I had or is on a new customisation?  Or whether it will just add the columns in that I need or replace the current grid?  DO I use code in addition to what you have given me to replace 'MYPART' with the part number?  I have tried adding your code to 'EpiViewNotification', and added the relevant Custom Assemblies, however I get a compiling error:
 Error: BC30451 - line 71 (115) - Name '_session' is not declare
I'm also unsure how to get 'Myval'?  Sorry for all the questions :/
Hi.  I want to add a couple of columns to the Part Transaction History Tracker - one is the Employee ID, which in theory should be available but Vantage doesn't seem to populate it!  However, I have the data I require in the JobHead table along with the Employee Name :)
I have used information from this group before to perform a similar update on the TimePhas Form but although I've tried using the same code it's not working (see my adapted code below) - AddEmployeeID() doesn't seem to be firing but I am unsure where else to place it?  I have tried moving it to before the If (args.NotifyType) line but then I just get an exception error saying Invalid Query?
I can add the JobHead table through FKV but am unsure then if I can use that as an alternative to add the data to the column in the grid?
Thank you!
'// Custom VB.NET code for PartTranHistForm
'// Created: 08/06/2016 13:32:32
Imports System
Imports System.Data
Imports System.Diagnostics
Imports System.Windows.Forms
Imports System.ComponentModel
Imports Microsoft.VisualBasic
Imports Epicor.Mfg.UI
Imports Epicor.Mfg.UI.FrameWork
Imports Epicor.Mfg.UI.ExtendedProps
Imports Epicor.Mfg.UI.FormFunctions
Imports Epicor.Mfg.UI.Customization
Imports Epicor.Mfg.UI.Adapters
Imports Epicor.Mfg.UI.Searches
Imports Epicor.Mfg.BO
Module Script
    '// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added Module Level Variables' Comments! **
    '// Begin Wizard Added Module Level Variables **
    Private WithEvents edvPartTranHist As EpiDataView
    Private WithEvents edvFilter As EpiDataView
    '// End Wizard Added Module Level Variables **
    '// Add Custom Module Level Variables Here **
    Sub InitializeCustomCode()
        '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Variable Intialization' lines **
        '// Begin Wizard Added Variable Intialization
        edvPartTranHist = cType(oTrans.EpiDataViews("PartTranHist"), EpiDataView)
        edvFilter = cType(oTrans.EpiDataViews("Filter"), EpiDataView)
        '// End Wizard Added Variable Intialization
        '// Begin Custom Method Calls
        If Not (edvPartTranHist.dataView.Table.Columns.Contains("EmployeeID")) Then
            edvPartTranHist.dataView.Table.Columns.Add(new DataColumn("EmployeeID"))
        End If
        If Not (edvPartTranHist.dataView.Table.Columns.Contains("EmployeeName")) Then
            edvPartTranHist.dataView.Table.Columns.Add(new DataColumn("EmployeeName"))
        End If
        '// End Custom Method Calls
    End Sub
    Sub DestroyCustomCode()
        '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Object Disposal' lines **
        '// Begin Wizard Added Object Disposal
        edvPartTranHist = Nothing
        edvFilter = Nothing
        '// End Wizard Added Object Disposal
        '// Begin Custom Code Disposal
        '// End Custom Code Disposal
    End Sub
    Private Sub edvPartTranHist_EpiViewNotification(view As EpiDataView, args As EpiNotifyArgs) Handles edvFilter.EpiViewNotification
        '// ** Argument Properties and Uses **
        '// view.dataView(args.Row)("[FieldName]")
        '// args.Row, args.Column, args.Sender, args.NotifyType
        '// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
        MsgBox("edvPartTranHist_EpiViewNotification-1 Fired")
        AddEmployeeID()
        If (args.NotifyType = EpiTransaction.NotifyType.AddRow) Then
            If (args.Row > -1) Then
                MsgBox("edvPartTranHist_EpiViewNotification-2 Fired")
'                AddEmployeeName()
            End If
        End If
    End Sub
    Private Sub AddEmployeeID()
        MsgBox("AddEmployeeID Fired")
        For Each dr As DataRow in edvPartTranHist.dataView.Table.Rows
            If Not IsDBNull(dr("JobNum")) Then
                dr("EmployeeID") = "DATA"
                'edvPartTranHist.DataView(edvPartTranHist.Row)("EmpID")
            End If
        Next
    End Sub
'    Private Sub AddEmployeeName()
'        For Each dr As DataRow in edvPartTranHist.dataView.Table.Rows
'            If Not IsDBNull(dr("JobNum")) Then
'                dr("EmployeeName") = getEmployeeName(dr("JobNum"))
'            End If
'        Next
'    End Sub
End Module
I have tried this multiple ways and if I can't add these columns then I am probably going to have to make all the Employees have separate Windows and Vantage logons to allow me to use the Entry person that already exists on the grid - the only problem is it still doesn't show the User ID correctly on Backflush records.  I'm sure I am pretty close the resolution but just can't see what I'm missing on here.  Thanks in advance.
I have tried using a BPM to update the EmpID field that already exists in the PartTran table.  Even though it exists on the table, it doesn't exist on the grid and I am getting this error:
System.ArgumentException: EmpID is neither a DataColumn nor a DataRelation for table PartTranHist.
I have also tried using an adapter to link to JobHead I have the following problem:
************** Exception Text **************
Epicor.Mfg.Common.BusinessObjectException: Record not found.
   at Epicor.Mfg.Proxy.JobEntryImpl.GetByID(String jobNum)
   at Epicor.Mfg.UI.Adapters.JobEntryAdapter.GetByID(String jobNum)
   at Script.getEmployeeID(String job)
   at Script.AddEmployeeInfo()
   at Script.edvPartTranHist_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
   at Epicor.Mfg.UI.FrameWork.EpiViewNotification.Invoke(EpiDataView view, EpiNotifyArgs args)
   at Epicor.Mfg.UI.FrameWork.EpiDataView.Notify(EpiNotifyArgs args)
   at Epicor.Mfg.UI.App.PartTranHistTracker.Transaction.GetPartTranHistRows()
Imports System
Imports System.Data
Module Script
        End If
        End If
    End Sub
    End Sub
    Private Sub edvPartTranHist_EpiViewNotification(view As EpiDataView, args As EpiNotifyArgs) Handles edvPartTranHist.EpiViewNotification
        'MsgBox("edvPartTranHist_EpiViewNotification-1 Fired")
                AddEmployeeInfo()
            End If
        End If
    End Sub
    Private Sub AddEmployeeInfo()
        'MsgBox("AddEmployeeInfo Fired")
                dr("EmployeeID") = getEmployeeID(dr("JobNum"))
            End If
        Next
    End Sub
    Private Function getEmployeeID(ByVal job As String) As String
        Dim EmployeeID As String
        Dim myGrid As EpiUltraGrid = cType(csm.GetNativeControlReference("f83d6262-a7d9-4fb5-a7d0-54644a9bb66b"), EpiUltraGrid)
        Dim adpJobEntry As JobEntryAdapter = New JobEntryAdapter(PartTranHistForm)
        adpJobEntry.BOConnect()
        Dim edvPartTranHist As EpiDataView = CType(oTrans.EpiDataViews("PartTranHist"), EpiDataView)
        Dim result As Boolean = adpJobEntry.GetByID(job)
        Dim dsJobInfo As DataSet = adpJobEntry.JobEntryData
        MsgBox("getEmployeeID Fired")
        Dim recordSelected As Boolean
        Dim showSearch As Boolean = False
        Dim whereClause As String = "'JobNum = '" + job + "'"
            If recordSelected = True And adpJobEntry.JobEntryData.JobHead(0)("JobNum") <> "" Then
                EmployeeID = adpJobEntry.JobEntryData.JobHead(0)("ShortChar04")
            Else
                EmployeeID = ""
            End If
        Return EmployeeID
    End Function
End Module
I have this working :)  But it is very slow :(  Any pointers on improving my code?
Would it work faster using FKV?  If so, how do I reference an FKV to add it to the column created?
Imports System
Imports System.Data
Module Script
        End If
        End If
    End Sub
    End Sub
                AddEmployeeID()
                AddEmployeeName()
            End If
        End If
    End Sub
            If (dr("JobNum")) > "A" Then
            End If
        Next
    End Sub
            End If
        Next
    End Sub
'            If recordSelected = True Then
'            MsgBox("getEmployeeID recordSelected " & adpJobEntry.JobEntryData.JobHead(0)("JobNum"))
'            Else
'                EmployeeID = ""
'            End If
        Return EmployeeID
    End Function
    Private Function getEmployeeName(ByVal job As String) As String
        Dim EmployeeName As String
                EmployeeName = adpJobEntry.JobEntryData.JobHead(0)("ShortChar05")
        Return EmployeeName
    End Function
End Module
You might be better off replacing the grid with a baq
On Thursday, June 16, 2016, tracy.smith@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><p>I have this working :)  But it is very slow :(  Any pointers on improving my code?</p><p><br></p><p>Would it work faster using FKV?  If so, how do I reference an FKV to add it to the column created?  </p><p><br></p><p><br></p><p>&#39;//**************************************************<br>&#39;// Custom <a rel="nofollow" target="_blank" href="http://VB.NET">VB.NET</a> code for PartTranHistForm<br>&#39;// Created: 08/06/2016 13:32:32<br>&#39;//**************************************************<br>Imports System<br>Imports System.Data<br>Imports System.Diagnostics<br>Imports System.Windows.Forms<br>Imports System.ComponentModel<br>Imports Microsoft.VisualBasic<br>Imports Epicor.Mfg.UI<br>Imports Epicor.Mfg.UI.FrameWork<br>Imports Epicor.Mfg.UI.ExtendedProps<br>Imports Epicor.Mfg.UI.FormFunctions<br>Imports Epicor.Mfg.UI.Customization<br>Imports Epicor.Mfg.UI.Adapters<br>Imports Epicor.Mfg.UI.Searches<br>Imports <a rel="nofollow" target="_blank" href="http://Epicor.Mfg.BO">Epicor.Mfg.BO</a></p><p><br>Module Script </p><p><br>    &#39;// ** Wizard Insert Location - Do Not Remove &#39;Begin/End Wizard Added Module Level Variables&#39; Comments! ** <br>    &#39;// Begin Wizard Added Module Level Variables ** </p><p>    Private WithEvents edvPartTranHist As EpiDataView</p><p>    &#39;// End Wizard Added Module Level Variables ** </p><p><br>    &#39;// Add Custom Module Level Variables Here ** </p><p><br></p><p>    Sub InitializeCustomCode() </p><p><br>        &#39;// ** Wizard Insert Location - Do not delete &#39;Begin/End Wizard Added Variable Intialization&#39; lines ** <br>        &#39;// Begin Wizard Added Variable Intialization <br>        <br>        edvPartTranHist = cType(oTrans.EpiDataViews(&quot;PartTranHist&quot;), EpiDataView)<br>        <br>        &#39;// End Wizard Added Variable Intialization <br>        &#39;// Begin Custom Method Calls </p><p>        If Not (edvPartTranHist.dataView.Table.Columns.Contains(&quot;EmployeeID&quot;)) Then<br>            edvPartTranHist.dataView.Table.Columns.Add(new DataColumn(&quot;EmployeeID&quot;))<br>        End If<br>        <br>        If Not (edvPartTranHist.dataView.Table.Columns.Contains(&quot;EmployeeName&quot;)) Then<br>            edvPartTranHist.dataView.Table.Columns.Add(new DataColumn(&quot;EmployeeName&quot;))<br>        End If<br>        <br>        &#39;// End Custom Method Calls <br>    End Sub </p><p><br></p><p>    Sub DestroyCustomCode() </p><p><br>        &#39;// ** Wizard Insert Location - Do not delete &#39;Begin/End Wizard Added Object Disposal&#39; lines ** <br>        &#39;// Begin Wizard Added Object Disposal </p><p>        edvPartTranHist = Nothing<br>        <br>        &#39;// End Wizard Added Object Disposal <br>        &#39;// Begin Custom Code Disposal </p><p>        &#39;// End Custom Code Disposal <br>    End Sub </p><p>    <br>    Private Sub edvPartTranHist_EpiViewNotification(view As EpiDataView, args As EpiNotifyArgs) Handles edvPartTranHist.EpiViewNotification<br>        &#39;// ** Argument Properties and Uses **<br>        &#39;// view.dataView(args.Row)(&quot;[FieldName]&quot;)<br>        &#39;// args.Row, args.Column, args.Sender, args.NotifyType<br>        &#39;// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes<br>                AddEmployeeID()              <br>                AddEmployeeName()       <br>        If (args.NotifyType = EpiTransaction.NotifyType.AddRow) Then<br>            If (args.Row &gt; -1) Then<br>                                          <br>            End If<br>        End If<br>    End Sub</p><p><br>    Private Sub AddEmployeeID()<br>        For Each dr As DataRow in edvPartTranHist.dataView.Table.Rows<br>            If (dr(&quot;JobNum&quot;)) &gt; &quot;A&quot; Then<br>                dr(&quot;EmployeeID&quot;) = getEmployeeID(dr(&quot;JobNum&quot;))<br>            End If<br>        Next<br>    End Sub<br>    <br>    <br>    Private Sub AddEmployeeName()<br>        For Each dr As DataRow in edvPartTranHist.dataView.Table.Rows<br>            If (dr(&quot;JobNum&quot;)) &gt; &quot;A&quot; Then<br>                dr(&quot;EmployeeName&quot;) = getEmployeeName(dr(&quot;JobNum&quot;))<br>            End If<br>        Next<br>    End Sub<br>    </p><p>    Private Function getEmployeeID(ByVal job As String) As String<br>        Dim EmployeeID As String<br>        Dim myGrid As EpiUltraGrid = cType(csm.GetNativeControlReference(&quot;f83d6262-a7d9-4fb5-a7d0-54644a9bb66b&quot;), EpiUltraGrid)<br>        Dim adpJobEntry As JobEntryAdapter = New JobEntryAdapter(PartTranHistForm)<br>        adpJobEntry.BOConnect()<br>        <br>        Dim edvPartTranHist As EpiDataView = CType(oTrans.EpiDataViews(&quot;PartTranHist&quot;), EpiDataView)<br>        Dim result As Boolean = adpJobEntry.GetByID(job)<br>        <br>        Dim dsJobInfo As DataSet = adpJobEntry.JobEntryData<br>        Dim recordSelected As Boolean<br>        Dim showSearch As Boolean = False<br>        Dim whereClause As String = &quot;&#39;JobNum = &#39;&quot; + job + &quot;&#39;&quot;<br>&#39;            If recordSelected = True Then<br>&#39;            MsgBox(&quot;getEmployeeID recordSelected &quot; &amp; adpJobEntry.JobEntryData.JobHead(0)(&quot;JobNum&quot;))<br>                EmployeeID = adpJobEntry.JobEntryData.JobHead(0)(&quot;ShortChar04&quot;)<br>&#39;            Else<br>&#39;                EmployeeID = &quot;&quot;<br>&#39;            End If<br>        <br>        Return EmployeeID      <br>        <br>    End Function</p><p><br>    Private Function getEmployeeName(ByVal job As String) As String<br>        Dim EmployeeName As String<br>        Dim myGrid As EpiUltraGrid = cType(csm.GetNativeControlReference(&quot;f83d6262-a7d9-4fb5-a7d0-54644a9bb66b&quot;), EpiUltraGrid)<br>        Dim adpJobEntry As JobEntryAdapter = New JobEntryAdapter(PartTranHistForm)<br>        adpJobEntry.BOConnect()<br>        <br>        Dim edvPartTranHist As EpiDataView = CType(oTrans.EpiDataViews(&quot;PartTranHist&quot;), EpiDataView)<br>        Dim result As Boolean = adpJobEntry.GetByID(job)<br>        <br>        Dim dsJobInfo As DataSet = adpJobEntry.JobEntryData<br>        Dim recordSelected As Boolean<br>        Dim showSearch As Boolean = False<br>        Dim whereClause As String = &quot;&#39;JobNum = &#39;&quot; + job + &quot;&#39;&quot;<br>                EmployeeName = adpJobEntry.JobEntryData.JobHead(0)(&quot;ShortChar05&quot;)<br>        <br>        Return EmployeeName      <br>        <br>    End Function</p><p>End Module<br></p><p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
Thanks for replying.  If it was any other grid I probably would but I'm really not sure I could get the running total working in a BAQ.
ah I see you are on 8.03... bummer unfortunately your best solution is the lookup you could try and run a BAQ from code that returns ALL the transactions for the given part with the info you need then the lookup is just in RAM and not a DB lookup every time
Jose C Gomez
Software Engineer
On Thu, Jun 16, 2016 at 7:58 AM, tracy.smith@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>Thanks for replying.  If it was any other grid I probably would but I&#39;m really not sure I could get the running total working in a BAQ.</p>
</div><span class="ygrps-yiv-1000751094">
Thanks Jose.  Think that might be a bit beyond me... I appreciate the advice though.
You know how to write a BAQ I assume? Write a BAQ that looks at part tran and does the Job Employee Linkn
Give the BAQ a condition WHERE PartNum='MYPART' (hard code) then you can use this code to excecute the BAQ and replace 'MYPART' with whichever part you want
Dim dq As New Epicor.Mfg.BO.DynamicQuery(_session.ConnectionPool)
Dim qds As Epicor.Mfg.BO.QueryDesignDataSet = dq.GetByID("YourQuery")
Dim dqds As Epicor.Mfg.BO.DynamicQueryDataSet = New Epicor.Mfg.BO.DynamicQueryDataSet()
dqds.Merge(qds, True, MissingSchemaAction.Ignore)
dqds.QueryWhereItem(0).RValue = "Myval"
Dim ds AS DataSet = dq.Execute(dqds)
Jose C Gomez
Software Engineer
On Thu, Jun 16, 2016 at 8:30 AM, tracy.smith@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>Thanks Jose.  Think that might be a bit beyond me... I appreciate the advice though.</p>
</div><span class="ygrps-yiv-1837702650">
