Add Customer User Defined Fields to InvHead
I finaly got this to work like it should Â… turns out that you need to add a
Sub Table View to your Foreign Key View
First do the FKV and after that click on the “New Custom View” again and
follow these steps:
View Name = TaxID (or anything you want)
Parent view = your FKV (from step 1)
View Type = Sub Table View
Sub Table Name = Customer
Then for each parent and child view columns click the middle Add button and
when you are done click the main add button.
Now you are ready to add EpiControls and assign EpiBindings and/or consume
the Dataviews inside .net layer.
De: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] En nombre de
Jesús Gonzalo Velázquez Ortega
Enviado el: lunes, 08 de abril de 2013 11:25 a.m.
Para: vantage@yahoogroups.com
Asunto: RE: [Vantage] Re: Add Customer User Defined Fields to InvHead
I submit a support ticket last week but no one has put in contact with me,
IÂ’m stuck for the moment, but IÂ’ll let you know how it went.
De: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] En
nombre de
millermw7
Enviado el: lunes, 08 de abril de 2013 10:58 a.m.
Para: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Asunto: [Vantage] Re: Add Customer User Defined Fields to InvHead
Did you get this working?
I ask because I'm in a similar situation on Vantage 8.03. On the DMR
processing screen I added a custom field for RMA number, but can't figure
out how to use FKV to link the DMRHead & NonConf tables, which should be
able to join on the DMRNum.
I've set DMRHead as the Parent View Name but the only columns that show that
I can link on have nothing in common with the NonConf table (there IS
PartNum, but using that just links to the Part table). Can't really find
anything explaining how to do this very well.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> , Jesús
Gonzalo Velázquez Ortega <jesus.velazquez@...> wrote:
> I did it and still the same, maybe it's time to submit a support ticket.
> Thanks Jose
> -----Mensaje original-----
nombre de
> Jose Gomez
> Enviado el: jueves, 04 de abril de 2013 02:14 p.m.
> Para: Vantage
> Asunto: Re: [Vantage] Add Customer User Defined Fields to InvHead
> Looks right, it sould be working. Did you close out of Epicor and back
in/>
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez>
<http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Thu, Apr 4, 2013 at 4:01 PM, Jesús Gonzalo Velázquez Ortega <
> > In the custom views tree I have FKV: Customer nested in NV:InvcHead
> > and the following data:
> > Custom View Info
> > View Name: Customer
> > Parent View Name: InvcHead
> > View Type: Foreign Key View
> > Foreign Key View Info
> > Column Name: InvcHead.CustNum
> > Like Column Value: Customer.CustNum
> > Adapter Name: CustomerAdapter
> > Get By Type: IntegerGetByID
> > Validation Adapters: <none>
> > Am I right?
nombre
> > de Jose Gomez Enviado el: jueves, 04 de abril de 2013 01:43 p.m.
> > Para: Vantage
> > There should be no special code inside the editor, are you sure you
> > liked the DataView Correctly? the Foreight Key View?
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > On Thu, Apr 4, 2013 at 3:39 PM, Jesús Gonzalo Velázquez Ortega <
> > > I found the forein key view tab under Data Tools Did a new custom
> > > view and put a new epitextbox, the new Customer dataview was there
> > > and I was able to set EpiBinding to Customer.ResaleId save and test
> > > that customization but it just shows a blank field and I'm sure
> > > there is data in the field, I'd also notice that the Field help is
> > > correct and there is no special code inside the script editor.
> > > Any suggestion?
> > > nombre de Jesús Gonzalo Velázquez Ortega Enviado el: jueves, 04 de
> > > abril de
> > > 2013 01:21 p.m.
> > > Asunto: RE: [Vantage] Add Customer User Defined Fields to InvHead
> > > Thanks for your response but I have no clue on how to do that...
> > > sorry to bother you again.
> > > En
> > > nombre de
> > > Jose Gomez
> > > Enviado el: jueves, 04 de abril de 2013 12:36 p.m.
> > > Para: Vantage
> > > Sure just bring in the Customer DataView as a Foreign Key View in a
> > > Customizatin,.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@... <mailto:jose%40josecgomez.com>
> > > http://www.josecgomez.com <http://www.linkedin.com/in/josecgomez>
> > > On Thu, Apr 4, 2013 at 2:31 PM, jvel4zquez
> > > <jesus.velazquez@... <mailto:jesus.velazquez%40igsa.com.mx>
> > > >wrote:
> > > > Hello Fellows, and thank you for let me be a part of this group:
> > > > I'm using Epicor 9.07.701 with SQL and I was wondering if there is
> > > > a way to add the user defined fields in customer table to use them
> > > > inside AR Invoice Tracker.
> > > > Regards.
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > > must have already linked your email address to a yahoo id to enable
> access.
> > > (1) To access the Files Section of our Yahoo!Group for Report
> > > Builder and Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
I'm using Epicor 9.07.701 with SQL and I was wondering if there is a way to add the user defined fields in customer table to use them inside AR Invoice Tracker.
Regards.
Customizatin,.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Invoice Tracker.
> Regards.
Jose Gomez
Para: Vantage
Customizatin,.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Regards.
I found the forein key view tab under Data Tools Did a new custom view and
put a new epitextbox, the new Customer dataview was there and I was able to
set EpiBinding to Customer.ResaleId save and test that customization but it
just shows a blank field and IÂ’m sure there is data in the field, IÂ’d also
notice that the Field help is correct and there is no special code inside
the script editor.
Any suggestion?
Enviado el: jueves, 04 de abril de 2013 01:21 p.m.
nombre de
Jose Gomez
Para: Vantage
Customizatin,.
*Jose C Gomez*
*Software Engineer*
> Regards.
There should be no special code inside the editor, are you sure you liked
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Apr 4, 2013 at 3:39 PM, Jes�s Gonzalo Vel�zquez Ortega <
> just shows a blank field and I�m sure there is data in the field, I�d also
> the script editor.
> Any suggestion?
> nombre de
> Jose Gomez
> Para: Vantage
> Customizatin,.
> *Jose C Gomez*
> *Software Engineer*
> > Regards.
In the custom views tree I have FKV: Customer nested in NV:InvcHead and the
following data:
Custom View Info
View Name: Customer
Am I right?
Jose Gomez
Para: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@...
> and put a new epitextbox, the new Customer dataview was there and I
> was able to set EpiBinding to Customer.ResaleId save and test that
> customization but it just shows a blank field and IÂ’m sure there is
> data in the field, IÂ’d also notice that the Field help is correct and
> Any suggestion?
> de Jesús Gonzalo Velázquez Ortega Enviado el: jueves, 04 de abril de
> 2013 01:21 p.m.
> En
> nombre de
> Jose Gomez
> Para: Vantage
> Customizatin,.
> *Jose C Gomez*
> *Software Engineer*
> > Regards.
Looks right, it sould be working. Did you close out of Epicor and back in/>
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Apr 4, 2013 at 4:01 PM, Jes�s Gonzalo Vel�zquez Ortega <
> following data:
> Custom View Info
> View Name: Customer
> Am I right?
> Jose Gomez
> Para: Vantage
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > customization but it just shows a blank field and I�m sure there is
> > data in the field, I�d also notice that the Field help is correct and
> > Any suggestion?
> > de Jes�s Gonzalo Vel�zquez Ortega Enviado el: jueves, 04 de abril de
> > 2013 01:21 p.m.
> > En
> > nombre de
> > Jose Gomez
> > Para: Vantage
> > Customizatin,.
> > *Jose C Gomez*
> > *Software Engineer*
> > > Regards.
Thanks Jose
Jose Gomez
Para: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Custom View Info
> View Name: Customer
> Am I right?
> Para: Vantage
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > that customization but it just shows a blank field and IÂ’m sure
> > there is data in the field, IÂ’d also notice that the Field help is
> > Any suggestion?
> > abril de
> > 2013 01:21 p.m.
> > En
> > nombre de
> > Jose Gomez
> > Para: Vantage
> > Customizatin,.
> > *Jose C Gomez*
> > *Software Engineer*
> > > Regards.
access.
I ask because I'm in a similar situation on Vantage 8.03. On the DMR processing screen I added a custom field for RMA number, but can't figure out how to use FKV to link the DMRHead & NonConf tables, which should be able to join on the DMRNum.
I've set DMRHead as the Parent View Name but the only columns that show that I can link on have nothing in common with the NonConf table (there IS PartNum, but using that just links to the Part table). Can't really find anything explaining how to do this very well.
--- In vantage@yahoogroups.com, Jesús Gonzalo Velázquez Ortega <jesus.velazquez@...> wrote:
> Thanks Jose
> Jose Gomez
> Para: Vantage
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Custom View Info
> > View Name: Customer
> > Am I right?
> > Para: Vantage
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Any suggestion?
> > > abril de
> > > 2013 01:21 p.m.
> > > En
> > > nombre de
> > > Jose Gomez
> > > Para: Vantage
> > > Customizatin,.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > > Regards.
> access.
millermw7
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Jesús
> Thanks Jose
nombre de
> Jose Gomez
> Para: Vantage
in/>
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Custom View Info
> > View Name: Customer
> > Am I right?
nombre
> > Para: Vantage
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Any suggestion?
> > > abril de
> > > 2013 01:21 p.m.
> > > En
> > > nombre de
> > > Jose Gomez
> > > Para: Vantage
> > > Customizatin,.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > > Regards.
> access.
