Adding a User Defined field to the Customer Shipment Entry throu
Good for you! The other idea is that you can make a BPM to add the Part.Character07 to ShiptDetail.Character07, when you retrieve the data in the form. I would use the tracing to find the exact method you want. Just another idea though.
Dan
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Drew
Sent: Tuesday, October 16, 2012 1:07 PM
Subject: [Vantage] Re: Adding a User Defined field to the Customer Shipment Entry through customization
Hey Dan,thanks. I actually looked around for the foreign key after you told me and found it. I played around and that is exactly what I needed. Thanks again Dan!
--- In vantage@yahoogroups.com, Dan Godfrey <dgodfrey@...> wrote:
> Sorry. So off the top of my head here is what you will want to do to add the Part table to the form.
> When you are in the Customization mode of the Customer Shipment Entry form:
> - select the Tools menu option and then Data Tools. This window shows you all of the Views.
> - Select the 'New Custom View' button.
> - To the right enter the name of this new view, something like Part, since you will connect to the Part table.
> - Enter the Parent View Name, this is the View that you want to join by. My suggestion is the ShipDetail view. The Foreign Key View Info below now will become enabled - Select the Column Name, PartNum.
> - Click the Add button and now you should be able to bind a control to the Part.Character07.
> Behalf Of Drew
> Sent: Tuesday, October 16, 2012 9:47 AM
> I don't know what that is Dan. Can you please elaborate further?
> --- In vantage@yahoogroups.com, Dan Godfrey <dgodfrey@> wrote:
> > What about the idea of adding aForeign KeyView to the ShipDetail view? That should give you the Part table that way.
> > Dan
> > Behalf Of Drew
> > Sent: Tuesday, October 16, 2012 8:28 AM
> > Subject: [Vantage] Adding a User Defined field to the Customer
> > Hey guys,
> > I need some help. We have determined what size box each of our items should ship in. I added that indo to a UD field (Part.Character07) under the Part Entry module and want to pull that info into the Customer Shipment Entry when we try and ship. Basically, I want the shipper to scan his item and the UD field (Part.Character07) will say item ABC should ship in box A. I do not have Part.Character07 as an option to choose to epibind it. Is this possible? If so, can you please help?
> > Thank,
> > Andrew
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > must have already linked your email address to a yahoo id to enable access.
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
Hey guys,
Thank,
Andrew
Dan
Subject: [Vantage] Adding a User Defined field to the Customer Shipment Entry through customization
Hey guys,
Thank,
Andrew
> Dan
> Hey guys,
> Thank,
> Andrew
> Dan
> Behalf Of Drew
> Hey guys,
> Thank,
> Andrew
> > Dan
> > Behalf Of Drew
> > Hey guys,
> > Thank,
> > Andrew
