hi,
Anyone is using APM in Epicor 10 ?
In my case APM was isntalled on Epicor Sql Server.
Since I started working on recipients, routing list and other staff I have some weird issues.
APM rules are working fine and documents are distributed.
I needed install few physical printers on the server. Every time when I'm adding drivers APM is crashing after that and I not able login any more.
Pretty much login screen is frozen with white spaces and no information on it.
I still have connection to DB but application is pretty useless.
I tried turn off/on services but no effect. Looks like something is lock up and prevent app from start.
Solution for me is restart whole box. That is pretty bad because it is sql live box.
I see error in event log:
Exception: No connection could be made because the target machine actively refused it......:5555
That is solved after server reboot.
Any similar experience ?
thank
henry
thank
henry
