APM work with external web based email service?
Running 10.1.400.18 and we are getting ready to install APM. We don’t have a local exchange server but instead use a web based email service. Can APM work with the web based email service? If not how do we configure APM to work with it?
It is just SMTP it should work with anything as long as you can relay
Jose,
It is a web based email through google using IMAP. Can that be used?
If its just google apps (which I assume it is) you can use these SMTP settings to send email
Assuming that APM allows Authentication (I can’t remember). If it doesn’t you’ll have to relay locally and then pass to Google via something like Pegasus Mail but I am fairly certain APM will allow authenticated SMTP
http://www.pmail.com/downloads.htm
