I’m using APR to route to a server printer, but I’m receiving the below error message.
I can print manually to that server printer from the user that’s using the routing.
What am I missing?
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: Settings to access printer '\\isimke\Accounting' are not valid.
Stack Trace:
at System.Drawing.Printing.PrinterSettings.GetHdevmodeInternal(String printer)
at System.Drawing.Printing.PrinterSettings.GetHdevmode(PageSettings pageSettings)
at PdfPrintingNet.PdfPrint.Print(String fileName, String password)
at PdfPrintingNet.PdfPrint.Print(Byte[] pdfArray, String printerJobName)
at Ice.Core.SsrsReporting.PdfReportPrinter.Print(Byte[] reportBytes, String printerNameParameter, String reportDescription, EpiPrinterSettings printerSettings, EpiPageSettings pageSettings) in C:\_Releases\ICE\3.1.500.16\Source\Server\Internal\Lib\TaskLib\SsrsReporting\PdfReportPrinter.cs:line 32
at Ice.Core.RoutingAndBreaking.ServerPrintReportAction.PrintReport(ReportInstanceInformation reportInstance, RenderedSsrsReport renderedReport) in C:\_Releases\ICE\3.1.500.16\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ServerPrintReportAction.cs:line 152
at Ice.Core.RoutingAndBreaking.ReportPersister.Persist(ReportInstanceInformation reportInstance, Func`2 reportsRenderer, Action`1 fillSysRptLstRow, Action`2 processReport) in C:\_Releases\ICE\3.1.500.16\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ReportPersister.cs:line 47
at Ice.Core.RoutingAndBreaking.ReportPersister.Persist(IEnumerable`1 reportInstances, Func`2 reportsRenderer, Action`2 fillSysRptLstRow, Action`2 processReport) in C:\_Releases\ICE\3.1.500.16\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ReportPersister.cs:line 28
at Ice.Core.RoutingAndBreaking.ServerPrintReportAction.PrintReports(IEnumerable`1 reportsToRender) in C:\_Releases\ICE\3.1.500.16\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ServerPrintReportAction.cs:line 142
at Ice.Core.RoutingAndBreaking.ServerPrintReportAction.PrintReportsFromReportRequests() in C:\_Releases\ICE\3.1.500.16\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ServerPrintReportAction.cs:line 138
at Ice.Core.RoutingAndBreaking.ServerPrintReportAction.HandleProcess(Object sender, ProcessEventArgs e) in C:\_Releases\ICE\3.1.500.16\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ServerPrintReportAction.cs:line 73
at Ice.Core.RoutingAndBreaking.BaseNode.OnProcess(ProcessEventArgs e) in C:\_Releases\ICE\3.1.500.16\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\BaseNode.cs:line 172
at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
at Ice.Core.RoutingAndBreaking.Workflow.OnProcess(ProcessEventArgs e) in C:\_Releases\ICE\3.1.500.16\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\Workflow.cs:line 203
at Ice.Core.RoutingAndBreaking.Workflow.Run(ReportInstanceInformation reportInstance) in C:\_Releases\ICE\3.1.500.16\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\Workflow.cs:line 150
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder`1.RouteAndBreakReport(Func`2 executeCommand, Func`2 executeReader, SqlObjectsCreated sqlObjectsCreated) in C:\_Releases\ICE\3.1.500.16\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 254
at Ice.Core.RptBase.ReportDatabaseBuilder`1.XMLClose() in C:\_Releases\ICE\3.1.500.16\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 142
at Ice.Core.RptTaskBase`1.XMLClose() in C:\_Releases\ICE\3.1.500.16\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 130
at Erp.Internal.AR.ARInvForm.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:\_Releases\ERP\UD10.1.500.16\Source\Server\Internal\AR\ARInvForm\ARInvForm.cs:line 1227
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:\_Releases\ICE\3.1.500.16\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 93
at Ice.Hosting.TaskCaller.ExecuteTask() in C:\_Releases\ICE\3.1.500.16\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 54
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:\_Releases\ICE\3.1.500.16\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:\_Releases\ICE\3.1.500.16\Source\Server\Services\Lib\RunTask\RunTask.cs:line 526
at Ice.Services.Lib.RunTaskSvcFacade.RunTask(Int64 ipTaskNum) in C:\_Releases\ICE\3.1.500.16\Source\Server\Services\Lib\RunTask\RunTaskSvcFacade.cs:line 87
at SyncInvokeRunTask(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func`2 func) in C:\_Releases\ICE\3.1.500.16\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in C:\_Releases\ICE\3.1.500.16\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:\_Releases\ICE\3.1.500.16\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
