Attachments - Default saved location
<!-- #ygrps-yiv-2005236026 _filtered #ygrps-yiv-2005236026 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-2005236026 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-2005236026 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-2005236026 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} _filtered #ygrps-yiv-2005236026 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} #ygrps-yiv-2005236026 #ygrps-yiv-2005236026 p.ygrps-yiv-2005236026MsoNormal, #ygrps-yiv-2005236026 li.ygrps-yiv-2005236026MsoNormal, #ygrps-yiv-2005236026 div.ygrps-yiv-2005236026MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-2005236026 a:link, #ygrps-yiv-2005236026 span.ygrps-yiv-2005236026MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-2005236026 a:visited, #ygrps-yiv-2005236026 span.ygrps-yiv-2005236026MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-2005236026 p {
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-2005236026 code
font-family:“Courier New”;}
#ygrps-yiv-2005236026 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-2005236026 tt
#ygrps-yiv-2005236026 span.ygrps-yiv-2005236026cat
#ygrps-yiv-2005236026 span.ygrps-yiv-2005236026ct
#ygrps-yiv-2005236026 span.ygrps-yiv-2005236026HTMLPreformattedChar
font-family:Consolas;}
#ygrps-yiv-2005236026 p.ygrps-yiv-2005236026attach, #ygrps-yiv-2005236026 li.ygrps-yiv-2005236026attach, #ygrps-yiv-2005236026 div.ygrps-yiv-2005236026attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-2005236026 p.ygrps-yiv-2005236026bold, #ygrps-yiv-2005236026 li.ygrps-yiv-2005236026bold, #ygrps-yiv-2005236026 div.ygrps-yiv-2005236026bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-2005236026 p.ygrps-yiv-2005236026green, #ygrps-yiv-2005236026 li.ygrps-yiv-2005236026green, #ygrps-yiv-2005236026 div.ygrps-yiv-2005236026green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-2005236026 p.ygrps-yiv-2005236026replbq, #ygrps-yiv-2005236026 li.ygrps-yiv-2005236026replbq, #ygrps-yiv-2005236026 div.ygrps-yiv-2005236026replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-2005236026 p.ygrps-yiv-2005236026ad, #ygrps-yiv-2005236026 li.ygrps-yiv-2005236026ad, #ygrps-yiv-2005236026 div.ygrps-yiv-2005236026ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-2005236026 p.ygrps-yiv-2005236026underline, #ygrps-yiv-2005236026 li.ygrps-yiv-2005236026underline, #ygrps-yiv-2005236026 div.ygrps-yiv-2005236026underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-2005236026 span.ygrps-yiv-2005236026yshortcuts
#ygrps-yiv-2005236026 p.ygrps-yiv-2005236026ad1, #ygrps-yiv-2005236026 li.ygrps-yiv-2005236026ad1, #ygrps-yiv-2005236026 div.ygrps-yiv-2005236026ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-2005236026 p.ygrps-yiv-2005236026ad2, #ygrps-yiv-2005236026 li.ygrps-yiv-2005236026ad2, #ygrps-yiv-2005236026 div.ygrps-yiv-2005236026ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-2005236026 p.ygrps-yiv-2005236026underline1, #ygrps-yiv-2005236026 li.ygrps-yiv-2005236026underline1, #ygrps-yiv-2005236026 div.ygrps-yiv-2005236026underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-2005236026 span.ygrps-yiv-2005236026yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-2005236026 span.ygrps-yiv-2005236026yshortcuts2
font-weight:normal;}
#ygrps-yiv-2005236026 span.ygrps-yiv-2005236026EmailStyle36
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-2005236026 .ygrps-yiv-2005236026MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-2005236026 div.ygrps-yiv-2005236026WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-2005236026 ol
{margin-bottom:0in;}
#ygrps-yiv-2005236026 ul
Does anyone know where the save file location is stored when uploading attachments in the Maintenance screens such as Supplier Maintenance? We do have document management also and do not have the file system enabled in company config. I’m looking at where the attachments are saved once attached in Epicor or does it retrieve it from its original location wherever it was uploaded from?
E10
<Company Maintenance><Attachments>
E9
<Company Maintenance><Company><System><Attachments>
Brenda
Sent: Monday, February 01, 2016 1:18 PM
Subject: [Vantage] Attachments - Default saved location
Epicor itself adds for us:  10\<TableName>\ to the folders.  In E9 it was Live\<TableName>\
Perhaps check the root?  We use service connect to attach signed invoices as they are emailed back.  We had to place a copy into the 10\InvcHead\ folder so that the attachment could be viewed.
Brenda
Sent: Monday, February 01, 2016 1:30 PM
Subject: RE: [Vantage] Attachments - Default saved location
I checked in Company Config. under the Attachments for E9 but we do not have anything enabled or a URL set up.  Seems odd that if it is not enabled, we shouldn’t be able to upload attachments but we can.  We are adding attachments through the attachment icon and not dragging it into the screen.
Sent: Monday, February 01, 2016 12:28 PM
E10
E9
Brenda
I don’t believe EPICOR stores attachments into the DB, it is just a link for the file locations.
So my C:\TEMP is different from your C:\TEMP
We store our documents on a shared server drive, everyone must have the same mapped drive.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Monday, February 1, 2016 10:30 AM
E10
E9
Brenda
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
On 9.05.702A it is storing a link to where the file resides when attached. The location is saved into the "XFileRef" table. We recently had to update all of our attachments to our purchase orders to point to a new folder so I had created an updateable BAQ to do this. The 2 tables used were XFileAttch and XFileRef
Good point Sarah,  You also have to set up document types and such, not sure I remember how anymore, but I did write some code to verify that there was an attachment connected to an Invoice before we allowed it to be posted.  Here is the code just in case it helps find the attachments:
Ice.Tables.XFileAttch XFileAttch;
Ice.Tables.XFileRef XFileRef;
callContextBpmData.Checkbox01 = false;
foreach (var ttInvcHead_Recs in(from ttInvcHead_Row in ttInvcHead
select ttInvcHead_Row))
   var ttInvcHeadRow = ttInvcHead_Recs;
   foreach (var XFileAttch_Recs in (from XFileAttch_Row in Db.XFileAttch
        where XFileAttch_Row.Key1 == SqlFunctions.StringConvert((double)ttInvcHeadRow.InvoiceNum).Trim()
        && (string.Compare(XFileAttch_Row.RelatedToFile,"InvcHead",true)==0)
        select XFileAttch_Row))
      XFileAttch = XFileAttch_Recs;
      if (XFileAttch != null)
         var XFileRef_Recs = (from XFileRef_Row in Db.XFileRef
                             where XFileRef_Row.Company == Session.CompanyID
                             && XFileRef_Row.XFileRefNum == XFileAttch.XFileRefNum
                             && (string.Compare(XFileRef_Row.DocTypeID,"SIGNPACK",true)==0)
                             select XFileRef_Row).FirstOrDefault();
            XFileRef = XFileRef_Recs;
            if (XFileRef != null)
               callContextBpmData.Checkbox01 = true;
Brenda
Sent: Monday, February 01, 2016 1:38 PM
To: Vantage List
Subject: Re: [Vantage] Attachments - Default saved location
