David,
Yes, that is what he means.
Manually attempt to run the report.
Notice where you input dates, you can select the DYNAMIC check boxes so that you select values like EVERY FRIDAY, 1st OF THE MONTH, etc...this way the report substitutes automatic dates.
Then, near the bottom of the report program, you will see a checkbox that says SCHEDULE and defaults to "now".
If there are no other options available in the dropdown, you will have to first set up a schedule...For us, we run a list of reports every friday afternoon.
So, I set up a schedule called Friday Afternoon, and tell it to run every Friday at 5pm.
Then, once set up, go back as if you are manually running the report. Select your dynamic date selections, and click on the dropdown named SCHEDULE.
In my case, I select the schedule called Friday Afternoon.
Hit Submit.
That should be all you need to do.
Carey
To: vantage@yahoogroups.comFrom: pixelbend@...: Fri, 14 Sep 2007 21:14:08 +0000Subject: [Vantage] Re: Automatic report running in 8.0
When you say "Go to your report", do you mean in the menu? Where is"Dynamic"?Thanks,David--- In vantage@yahoogroups.com, Fons van der Beek<fons.vanderbeek@...> wrote:>> in 803 it can be done by (i don't know if it's simulair in8.0.............)> > first creating a task> -utilities> -System Agent> -Select the standard agent> -Create a new schedule "print report"> create the schedule in the interval as you like it> > Now go to your report> -Enter dates as "Dynamic"> -select at the field "schedule" the previously created schedule> -Submit the job........ to the schedule> > that's it> You can check wether the job was submitted by checking your systemagent.> > Beware that when changing your report options, it's wise first todelete > the previously created schedule, I had some issues with it> > > dtgreen01 schreef:> > Does anyone know how to set a report to run automatically to a network> > printer at a specific time in Vantage 8.0?> >> > Thanks,> > David G> > Magna-Tel, Inc.> >> >> >> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: Youmust have already linked your email address to a yahoo id to enableaccess. )> > (1) To access the Files Section of our Yahoo!Group for ReportBuilder and Crystal Reports and other 'goodies', please goto:http://groups.yahoo.com/group/vantage/files/. > > (2) To search through old msg's goto:http://groups.yahoo.com/group/vantage/messages> > (3) To view links to Vendors that provide Vantage services goto:http://groups.yahoo.com/group/vantage/links > > Yahoo! Groups Links> >> >> >> >>
_________________________________________________________________
Can you find the hidden words? Take a break and play Seekadoo!
http://club.live.com/seekadoo.aspx?icid=seek_wlmailtextlink
Hit Submit.
Carey
