On Thu, Mar 31, 2016 at 12:21 PM, brandonanderson7979@... [vantage]<vantage@yahoogroups.com> wrote:Â<div id="ygrps-yiv-1266967454ygrp-text"> <p></p><p class="ygrps-yiv-1266967454ygrps-yiv-2067207942MsoPlainText">Â Â Â Â Â Â Â(Input and Backflush warehouses referred to below are linked to the
Related Operation in the Job Material Detail sequence screen)Â
1)Â Â Â Â Â Â Â Â Â Â Â
From scheduled Input Resource if Warehouse/bin are configured and the
Qty On Hand is bigger than zero. If not.   ( Note: Not the Resource
GROUP) Where is this?2)           From Input Resource GROUP if Warehouse/bin are configured and the Qty On Hand is bigger than zero. If not. resource group set to gen 1- qty is 0
3)Â Â Â Â Â Â Â Â Â Â Â From Backflush Resource GROUP if Warehouse and bin are defined no matter the Qty On Hand. If not… this is different than what's in help, and maybe why it's not working. We want it to pull from the primary bin before is goes the the "no matter the qty" on the backflush group.
4)Â Â Â Â Â Â Â Â Â Â Â
From Primary Bin for the Warehouse defined in the Material (Job entry
form) No matter the Qty On Hand. If the Bin is not defined.5)Â Â Â Â Â Â Â Â Â Â Â From the First Bin WITH Qty on Hand for the warehouse defined in the Material. If there is no qty on hand
6)Â Â Â Â Â Â Â Â Â Â Â From the first Bin in the warehouse defined in the material.
Â
Â
   Â
This is the hierarchy that the Job Entry form logic follows to assign
the warehouse/bin to a Material Backflush Transaction created thru the
Job Closing process:1)           From Input Resource GROUP if Warehouse/bin are configured and the Qty On Hand is bigger than zero. If not. Â
2)Â Â Â Â Â Â Â Â Â Â Â From Backflush Resource GROUP if Warehouse and bin are defined no matter the Qty On Hand. If not…
form) No matter the Qty On Hand. If the Bin is not defined.4)Â Â Â Â Â Â Â Â Â Â Â From the First Bin WITH Qty on Hand for the warehouse defined in the Material. If there is no qty on hand
5)Â Â Â Â Â Â Â Â Â Â Â From the first Bin in the warehouse defined in the material.
So if I remove the resource group bins (input and backflush), and the scheduled input resource (wherever that is) then it will start pulling from the primary bin correct? Then if I were to not define a primary bin, it would pull from anywhere that has inventory in a bin?
</div> <div style="color:#fff;height:0;"></div></div>
Brandon
(Input and Backflush warehouses referred to below are linked to the Related Operation in the Job Material Detail sequence screen)
1) From scheduled Input Resource if Warehouse/bin are configured and the Qty On Hand is bigger than zero. If not. ( Note: Not the Resource GROUP)
3) From Backflush Resource GROUP if Warehouse and bin are defined no matter the Qty On Hand. If not..
4) From Primary Bin for the Warehouse defined in the Material (Job entry form) No matter the Qty On Hand. If the Bin is not defined.
5) From the First Bin WITH Qty on Hand for the warehouse defined in the Material. If there is no qty on hand
6) From the first Bin in the warehouse defined in the material.
This is the hierarchy that the Job Entry form logic follows to assign the warehouse/bin to a Material Backflush Transaction created thru the Job Closing process:
2) From Backflush Resource GROUP if Warehouse and bin are defined no matter the Qty On Hand. If not..
3) From Primary Bin for the Warehouse defined in the Material (Job entry form) No matter the Qty On Hand. If the Bin is not defined.
4) From the First Bin WITH Qty on Hand for the warehouse defined in the Material. If there is no qty on hand
5) From the first Bin in the warehouse defined in the material.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Thursday, March 31, 2016 7:55 AM
Subject: [Vantage] backflush bins issue e-10
We are having an issue where materials aren't being backflushed out of the primary bin. Instead the default bin is going negative. Looking at the help files, the backflushing should run through the various defaults and if there isn't enough get the bin that
has enough to cover the demand, which would be the primary bin. I've been manually transferring inventory to correct the negative, but according to the documentation I shouldn't have to to that. It doesn't look like everything is using the wrong bin, but a
lot of them are, which is even more frustrating because it works correctly sometimes. Can anyone tell me what would make the system make a bin go negative instead of using the qty in the primary bin?
Brandon
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
1)
3) From Backflush Resource GROUP if Warehouse and bin are defined no matter the Qty On Hand. If not.. this is different than what's in help, and maybe why it's not working. We want it to pull from the primary bin before is goes the the "no matter the qty" on the backflush group.
