I hope I'm wrong and you find a solution but...
My experience has been that backflushing can drive inventory negative.
It does not look for onhand material.
I tried to get this quoted as a customization from Epicor a couple of years ago. At that time they said they didn't have a good way to modify this in 8.03.409C.
I haven't pursued it since then.
I just set up an end of day report to find any of these negative quantities.
--- In vantage@yahoogroups.com, "Kevin Simon" <simstrak@...> wrote:
> I am on Epicor 9.05.605, and we have AMM installed.
> Here's my problem. I have an operation (which is assigned a resource) where
> I need to backflush multiple parts from different bins. For this operation,
> some parts are being maintained on the line (which is set up as a bin), but
> other parts are kepts in our stores area (in one or more bins there).
> When this operation is complete, it appears to be going to the resource
> record, getting the backflush bin, and backflushing those parts out of that
> bin, regardless of whether there's inventory there or not. I thought AMM
> was designed to use a hierarchy, where it's looking for parts on hand, in
> order to backflush out of that bin. In fact, I've got a tech tip from
> Epicor that gave me that hierarchy. However, it's not functioning like as
> the document specifies, so I put in a support call.
> This morning, I got something from tech support that said: "The system is
> going to look first to the Resource Group setup
> If you have a Backflush Resource group setup on the resource group the
> system will create the backflush transaction from this Warehouse/bin even if
> there is no On hand quantity available". This flies in the face of the
> whole hierarchy concept.
> Does anyone else have their system configured so it can backflush from a
> hierarchy, and it takes into account whether there's anything on hand?
> Thanks in advance,
> Kevin Simon
> SimsTrak Consulting
