BAQ Calculated field for Year-Quarter
I should know this one but am having issues. Hopefully easy for you experts out there…
I want a calculated field to display year-quarter for Customer.Estdate as follows:
2018-Q1
2018-Q2
2018-Q3
2018-Q4
Thanks in advance
Couldyou do something like
Case
when (DATEPART(quarter, Customer.EstDate) = ‘1’ and DATEPART(year, Customer.EstDate) = ‘2018’) then ‘2018-Q1’
when …
end
You could also concatenate the dateparts so that it;'s more flexible in the future too
Hi Randy,
This should give you exactly what you want:
CAST(YEAR(Customer.EstDate) AS VARCHAR) + ‘-Q’ + CAST(DATEPART(QUARTER, Customer.EstDate) AS VARCHAR)
Thanks. By the way I only work 2 days per week here hence the delay in my replies.
Maybe someone could explain why this gives me an error - trying to get a 2 digit month. I am a newbie at this syntax.
If DATEPART(MONTH, LaborDtl.ClockInDate) > 9 then
Else
‘0’ + DATEPART(MONTH, LaborDtl.ClockInDate)
I assume it is due to the fact that you are not casting the returned DATEPART functions to string, as this function returns an integer value.
IF DATEPART(MONTH, LaborDtl.ClockInDate) > 9
THEN CAST(DATEPART(MONTH, LaborDtl.ClockInDate) AS VARCHAR)
ELSE ’0’ + CAST(DATEPART(MONTH, LaborDtl.ClockInDate) AS VARCHAR)
