BAQ Calculated field returns empty inconsistently
Hello,
I have a BAQ with the following calculated field:
’ + Part.PartNum + ’ - ’ + Part.PartDescription + ’ is a ’ + Type + ’ part within the ’ + PartClass.Description + ’ part class.
On Hand Qty: ’ + convert(varchar, PartBin.OnhandQty)
It returns a value when I pass the PartNum (which is criteria to the BAQ) of 1000021 but not when I pass 10000164. The BAQ is returning data as Part.PartNum is a field that is returned and it displays correctly.
It doesn’t make any sense to me. Anyone have any ideas?
In Part Tracker, does 10000164 have any bins? A null can really mess up character concatenation.
Mark W.
Hi Mark,
Thanks for the reply. My onhandqty is null, that must be it. Just need to figure out how to put that logic into the concatenation.
I was able to fix it by creating a user defined field for onhandqty that checks for null, supplies 0.00 if true, otherwise returns a converted string of the actual onhandqty value. The message field now displays the string.
